Forced Induction (FAQs) 2 Contd...
Types of Superchargers:
When you begin to search for the best supercharger for your vehicle, the choices can sometimes seem overwhelming. With so many manufacturers, it's sometimes difficult to know where to start. This guide is designed to give you an overview of each supercharger manufacturer and will hopefully help you decide which brand is the best choice for you. Often we are asked which supercharger is the best. This question is impossible to answer as each make of supercharger has its own set of characteristics (price, low end power, high end power, ease of installation, reliability, etc.) that make it unique. The combination of these characteristics may make a particular supercharger the "best" or the "worst" choice for your application depending on your requirements. With the help of this guide you will get a feel for which brand will most likely best suit your needs. The feature that most separates the different brands of superchargers is the type of compressor that is used. There are three different types of supercharger compressors - centrifugal, twin-screw, and roots (click to learn more on each type of supercharger). It will be helpful to familiarize yourself with these three types of superchargers before deciding which supercharger is best for your application. In many cases you will find that there is only one type of supercharger available for your vehicle. In general, this indicates that there is one type of supercharger compressor that is clearly the best choice for your vehicle by most standards. Roots vs. Centrifugal vs. Screw Type Supercharging The most effective performance enhancement that you will ever do to your car or truck is definitely a supercharger. That is why it is very important that you choose the right type of supercharger to get the right kind of power for the type of conditions that you will put your vehicle through. This is a guide to help understand it's not just about forcing more air down the throat of your motor. There are different ways to get the air to the motor and these different ways create different type of power curves. -------------------------------------------------------------------------- Centrifugal Type Supercharging Centrifugal Supercharging compresses the air inside the case of the supercharger using an impeller. Then, discharges the air out of a scroll to the motor. This design is similar to turbo-charging except for centrifugal superchargers don't use the exhaust to build pressure, they use a belt, driven by the crank pulley to spin the impeller. Centrifugal supercharging is definitely one of the more user-friendly ways to supercharge your motor. The ability to change the impeller sizes and to spin the impeller at different speeds creates a more inexpensive way to have flexibility in your power curve. Centrifugal superchargers have become the standard for street use and light-duty racing and far outsell all other types of superchargers. Recommended Usage: Street Use - Commercial Use - Road Racing - Drag Racing Positive Points: 1) Lots of Flexibility for Power Adjustments 2) Lower Discharge Temperatures 3) Great Reliability 4) Easy to install Negative Points: 1) Not as much power at low RPMs as Roots or Screw type superchargers Manufacturer Availability: Paxton - Powerdyne - ProCharger - Vortech Vortech's Centrifugal Type Supercharger Roots Type Supercharging The Roots Type Supercharger is the first style supercharger that was ever used and can be dated back to the 1880s when the Roots brothers designed it as an air conveyor for mine shafts. Roots blowers act like air pumps (not compressors), and In general, Roots blowers have a two or three lobe rotor design, depending on the size of the case. Roots blowers will give you positive pressure to your motor from just a crack of the throttle, and will give all that they have to offer at full throttle no matter what the rpm of the motor. Roots Type Superchargers may look awesome hanging out of the hood and are great for those looking for drastic power increases at lower RPMs. Roots blowers are also extremely reliable and require very little maintenance, which is why Ford, GM, Mercedes, Jaguar, and Austin Martin have all featured Roots blowers as original equipment on select high performance vehicles. Recommended Usage: Street Use - Towing - Extreme Drag Racing - Show Vehicles Positive Points: 1) Boost throughout the entire RPM range, right off of idle 2) Highest Potential for Gain (A must-have for all-out drag racing) 3) Excellent Reliability 4) Great Appearance & Stature (Most common supercharger type for show vehicles) Negative Points: 1) Sometimes Violent Throttle Response 2) Lower boost ratings at higher RPMs 3) Higher Than Normal Discharge Temperatures 4) Lengthy installation times Manufacturer Availability: Allen Engine Development - BDS - Magna Charger - B&M- Holley - Littlefield - Mooneyham - Weiand Holley's Roots Type Supercharger [img]http://ckjuice.com/svt/holley_roots.gif Screw Type Supercharging Screw type superchargers are derived from the Roots type concept but with vast improvements for street use. Although from the out side, screw type superchargers may look a lot like Roots type superchargers, on the inside you will find a twin-screw design that compresses air unlike Roots type superchargers which pump the air into the motor. Screw type superchargers have an axial-flow design that compresses the air as it moves between the screws to create positive pressure without creating the heat that Roots type superchargers can create. The Screw type supercharger's ability to produce a dramatic increase of power from idle and through out the rest of the power curve make them a great choice for heavy vehicles, towing or commercial use. Recommended Usage: Street Use - Towing - Road Racing - Drag Racing Positive Points: 1) Great Power at Low RPMs (Great for Towing) 3) Factory Fit & Appearance 4) Great Reliability Negative Points: 1) The Power Doesn't Keep Climbing in the High RPMs (Power curve is very flat) 2) Challenging To Achieve High Boost Levels or CFMs 3) Lengthy installation times Manufacturer Availability: Kenne Belle - Whipple Whipple's Screw Type Supercharger Allen Engine Development Supercharger Type: Roots (Eaton) Overview: Allen Engine Development is a small manufacturer of a select few roots supercharger systems for the Ford 4.6L Mustang / Thunderbird engine. Pros: • OEM quality • Excellent power at lower rpms • Very complete system - no additional modifications required • Integrated intercooler system included with every system • Self contained - no need to tap the oil pan for lubrication Cons: • Kits available for few vehicles • Kits are fairly expensive, but reasonably priced considering intercooler is included • REV I kits have lengthy install times (new REV II kits are much easier) Systems Available For: • 4.6L GT Mustang • 4.6L Thunderbird Paxton Automotive Supercharger Type: Centrifugal (Paxton) Overview: Paxton Automotive is the first aftermarket automotive supercharger manufacturer. Paxton makes high-end centrifugal superchargers for a variety of Dodge, Ford, Lincoln, and GM vehicles. Pros: • High quality compressor and components • Very complete system - no additional modifications required • High peak boost capabilities - great for racing • Excellent installation instructions • 100% maintenance free - no oil to change Cons: • Not self contained - tapping the oil pan is required • Little boost / small power gains below 3000 rpm Systems Available For: • Dodge Ram • Plymouth Prowler • Ford 4.6L Mustang and Cobra • Ford 5.0L Mustang and Cobra • Ford 6.8L Truck/SUV • Ford F-Series Truck 4.6/5.4L • Lincoln Navigator 5.4L • GM Truck/SUV 4.8/5.3/6.0L • GM Truck/SUV 7.4L Powerdyne Automotive Supercharger Type: Centrifugal (Powerdyne) Overview: Powerdyne Automotive manufactures a complete line of centrifugal supercharger systems for many GM, Ford, and Dodge cars and trucks. Known for being one of the only self contained centrifugal superchargers and for being a low-cost leader, Powerdyne Automotive has proved itself to be a powerful player in this industry. Pros: • Excellent value - low cost and good performance • Very complete systems - no/few additional modifications required • Super quiet "SilentDrive" belt driven internals make almost no noise • Self contained - no need to tap the oil pan (except for XB-1A systems) Cons: • Internal belt needs to be replaced every 50,000 miles (except for XB-1A systems) and must be sent to Powerdyne • Installation instructions need improvement • Not capable of high boost outputs above 12psi • Little boost / small power gains below 3000 rpm Systems Available For: • Dodge Ram 5.2/5.9L • Dodge Dakota 5.2/5.9L • Dodge Durango 5.2/5.9L • Ford 4.6L Mustang • Ford 5.0L Mustang and Cobra • Ford Explorer • Ford F-Series Truck 4.6/5.4L • Ford F-Series Truck 5.0/5.8L • Ford Lightning • GM Camaro / Firebird / TransAm • GM 4.3L Truck / SUV • GM 4.8/5.3/6.0L Truck / SUV • GM 5.7L Truck / SUV ATI ProCharger Supercharger Type: Centrifugal (ATI) Overview: ProCharger is known as a leading centrifugal supercharger brand and has established a reputation for its high quality intercooled supercharger systems that are capable of putting out incredibly high levels of boost. ProCharger is a strong believer in the benefits of intercooling and include an intercooler in almost every system they sell. Their P-1SC and D-1SC supercharger compressors are the only gear-driven centrifugal compressors available, and are very easy to install. Pros: • Very high performance - cool (intercooled) discharge • Self contained - no need to tap the oil pan (P-1SC and D-1SC only) • Very upgradable - compressors capable of high boost outputs Cons: • Lots of compressor noise (whine) • Fairly expensive, but reasonable considering intercooler is included • Little boost / small power gains below 3000 rpm Systems Available For: • Ford 4.6L Mustang • Ford 4.6L Cobra • Ford 5.0L Mustang • Ford 5.0L Cobra • Ford V6 Mustang • Ford F-Series Truck 4.6/5.4L • GM Corvette C5/ZO6 • GM LT1 Corvette • GM TPI Corvette • GM Camaro / Firebird / TransAm • GM TPI Camaro / Firebird / TransAm • GM Carbureted Big Block / Small Block • GM 5.7L Truck / SUV EFI • GM 5.7L Truck / SUV TBI • GM 4.8/5.3/6.0L Truck / SUV • GM 7.4L Truck / SUV Vortech Engineering Supercharger Type: Centrifugal (Vortech) Overview: Vortech sets the industry standard with their huge line of automotive and truck superchargers. Vortech sells more superchargers than any other single manufacturer - and for good reason. Vortech quality is second-to-none and their impressive manufacturing plant is the best in the industry. Their high quality supercharger systems have enjoyed years of success on the race track and are capable of incredibly high boost output levels. Pros: • Very high performance - capable of high outputs - aftercoolers available on some models • Reliable, high quality compressor and components • Very upgradable - compressors capable of high boost outputs • SQ line of compressors are "Super Quiet" Cons: • Tapping the oil pan is required • Little boost / small power gains below 3000 rpm Systems Available For: • Ford 2.5L Contour • Ford 4.6L Mustang • Ford 4.6L Cobra • Ford 5.0L Mustang • Ford Lightning • Ford 4.6/5.4L F-Series Truck / SUV • Ford 5.0/5.8L F-Series Truck / SUV • Ford 4.0L Truck / SUV • Ford 6.8L Truck / SUV • Ford 7.4L Truck / SUV • Lincoln Navigator • GM Camaro / Firebird / TransAm • GM Corvette • GM 4.3L Truck / SUV • GM 4.8/5.3/6.0L Truck / SUV • GM 5.7L Truck / SUV • GM 7.4L Truck / SUV • Dodge Durango • Dodge Dakota • Dodge Ram • Honda Civic • Honda S2000 • Acura Integra Whipple Industries Supercharger Type: Twin Screw (Lysholm) Overview: Whipple Industries is rapidy emerging as a leading manufacturer of twin-screw supercharger systems for many truck and marine applications. Utilizing only the best quality Lysholm twin screw compressors, Whipple supercharger systems are completely self contained and provide amazing power gains even at very low engine rpms. Ideal for trucks and towing vehicles, these supercharger systems are truly a cut above. Pros: • Excellent power at lower rpms and great for towing • Very complete system - no additional modifications required • Easy to install • Self contained - no need to tap the oil pan for lubrication • Very high quality Cons: • Kits are fairly expensive • Installation manuals need improvement Systems Available For: • GM 4.8/5.3/6.0L Truck / SUV • GM 5.0/5.7L Truck / SUV • GM 7.4L Truck / SUV • GM 8.1L Truck / SUV • Ford 6.8L Truck / SUV • Chrysler 2.4L PT Cruiser • Mercruiser Marine
![]() 480RWHP 450RWTQ 15psi @ 15* on 91 octane |
Threads Similar to: Forced Induction (FAQs) 2 Contd...
| Forced Induction (FAQs) | UnixHH | 99-04 | 16 | April 15th, 2010 02:43 PM |
| a/c forced induction | 2000ranger | V6 Mustangs | 4 | January 6th, 2008 01:47 AM |
| Got Forced Induction | rxnodoze02 | 2005 - 2010 | 18 | November 24th, 2007 12:13 AM |
| Forced Induction | rxnodoze02 | 2005 - 2010 | 28 | November 18th, 2007 02:15 PM |
| forced induction | Elder | 96-98 | 10 | October 24th, 2007 09:37 PM |
