Cold starts
Ok obviously I'm no expert but when my car is left to sit in the cold for a while (this seems to be the only time this occurs) it doesn't want to start. I'll keep the gas pedal down n then eventually the car will stay on but the idle stays very low, around 500ish rpm. Eventually if I keep the car on long enough or if I drive around a little the idle starts to be normal at 1000 rpm? Any ideas? Iac? Idk
Whatever it originally would be
hmm it could be just the cold, but it could be a bunch of other things too. I had a problem similiar to that once. It would start at first but i had to crank it a few times and it did. Bad spark maybe. You do a tune up in ever?
![]() MILITARY CREW ANTI ILLEGALS CREW FOUNDER |
sounds very IAC ish to me... how many miles are on the car?
![]() 480RWHP 450RWTQ 15psi @ 15* on 91 octane |
108000 miles approx. N no I've never had the car tuned as Long as I've had it other than a diablotune
holy jezuz man!!!! replace EVERY filter on that thing and clean your IAC .. if you have a hanes manual check the tune up section... you have alot of work to do boss
not tuned, like tune up. spark plugs changed, oil, filter, battery checked, alternator checked, fuel system checked or replaced, anything like that, that you did or know of?
the best way to keep your car in working order, is preventitive maintenence. Get to the potential problems before they become a problem.
+1 AMEN!!
Oh I feel like an idiot LOL that kind of tune up. Ya filters have been replaced n I have been keeping it in order I just know I've never replaced the iac.
no need to replace dude!! check it out click here http://www.moddedmustangs.com/cleaning-your-iac.html
N I have cleaned out the iac a few times but since the problem comes back I thought it might b just that I need to replace it completely
#12 | |
Safud: MM's Resident Hadji
But im having the exact same issues as you. If my car sits a while in the cold it refuses to start no matter what. I got some new spark plugs and will be putting them in really soon...hopefully that fixes my problem |
hmmmmmm..
the mechanics of vehicles, shit gets tricky sometimes
does your idle ever surge a little bit while sitting at a stop sign or redlight or something?
Yea Im actually replacing my plugs soon. I'll try cleaning out the iac again n see what happens
could be a vacuum leak
make sure no hoses are loose too
I wouldn't call it a surge but it isn't always stable
go buy some starter fluid and start your car and pop the hood and start spraying vacuum lines and the base of the plenum and intake manifold... anywhere air could get in... if the engine revs up then you have found your leak
Threads Similar to: Cold starts
| Starts | Gt98 | 96-98 | 6 | October 2nd, 2008 12:26 AM |
| Race Tune and Cold Starts | adam0421 | 2005 - 2010 | 3 | November 29th, 2007 09:45 AM |
| hard starts | steve505gt | 99-04 | 13 | October 23rd, 2007 07:56 PM |
| starts then shuts off | sean97gt | 96-98 | 2 | January 18th, 2007 12:45 PM |
| starts then shuts off | sean97gt | 96-98 | 3 | January 18th, 2007 01:00 AM |
