Just FYI(Helps bad gas mileage too)
Old January 14th, 2009, 06:46 PM   #1
Nossit's Avatar
1999 Mustang GT
8.65@72.5mph 1/8th
Nossit will become famous soon enough
Send a message via AIM to Nossit
My cousin works at BMW and gets all the latest information on the tests they run. So far K&N air filters, full synthetic Castrol oil, and Napa gold oil filters are what they tested to be the "best."
I'm sure other companies have ran tests as well with different results but my cousin gets free synthetic oil and all so I roll what BMW says lol.
Also, most the master techs there like Marvels Mystery Oil better than Seafoam because MMO does all that Seafoam does plus lubricates the engine at the same time. It calls for MM oil to be put in the oil and gas but you can pour some in your air intake and its fine. Although if you pour some in your intake, it is oil substitute so it smokes like a train for about 4-5 min.
My personal experience is that I was getting about 11-12 mpg in my car when I bought it. Terrified that something was wrong, poured that MMO stuff in my intake and used it for about a quart of oil, changed my oil, installed a K&N filter, a NAPA Gold oil filter, and put a hose clamp a possible vacuum leak.
I just filled my car up the other day and figured that I had 19.89 mpg. IMO something worked if not all of it. So its good money to invest if your car is getting bad gas mileage or just needs the carbon cleaned out.
Edit:
BTW the master techs are Ford master techs. Its a dual garage.
1999 Mustang GT - K&N drop in, Mac Prochamber, Mac CB, 555r's, 31 spline Strange axles, and 4.10's
Old January 14th, 2009, 06:47 PM   #2
ajm
I always wondered if the MMO was worth trying as im not a big fan of seafoam.
Old January 14th, 2009, 06:48 PM   #3
Nossit's Avatar
1999 Mustang GT
8.65@72.5mph 1/8th
I will personally use all of these things again. Obviously I had good luck with something by getting almost 9 mpg gained lol.
Old January 14th, 2009, 07:56 PM   #4
UnixHH's Avatar
2003 Saleen S281
UnixHH is a glorious beacon of lightUnixHH is a glorious beacon of lightUnixHH is a glorious beacon of lightUnixHH is a glorious beacon of lightUnixHH is a glorious beacon of light
Send a message via Yahoo to UnixHH
+1 for MMO my buddy had an old f100 with a 460 in it that had been sitting under a tree for about 5 years...(without starting or moviing) engine was full of water and siezed... pulled the valve covers and plugs out.. poured some mmo in the cylinders and soaked the heads... grabbed the crank pulley and went to town.. and IT UNSEIZED IT!!! holy shit lol neat stuff man .. a must for any mechanics garage
480RWHP 450RWTQ 15psi @ 15* on 91 octane
Old January 14th, 2009, 08:38 PM   #5
Nossit's Avatar
1999 Mustang GT
8.65@72.5mph 1/8th
Yea I didn't mention that my cousin garage had a seized up something come in and thats what the master techs used to unseize it. Apparently its the best kept secret.
Threads Similar to: Just FYI(Helps bad gas mileage too)
Bad gas mileage? KevinJ99GT 99-04 53 September 6th, 2008 04:10 AM
bad gas mileage, what to check for? snakey5138999 V6 Mustangs 19 January 19th, 2008 04:38 PM
bad gas mileage mscribellito V6 Mustangs 9 December 28th, 2007 07:45 AM
Bad Gas Mileage, Need Help stang300a V6 Mustangs 40 December 8th, 2007 01:18 AM
Flex-Fan (Non-Electric) Bad For Gas Mileage cobraetti 5.0 Mustangs 9 November 26th, 2006 05:41 AM
