kenne bell dealers?
Does kenne bell sell through distributors or do they sell direct? If they go through distributors is there anyone on here that sells em? thanks guys
True blue crew founder/member #1378/442 rwhp/rwtq*on a Mustang dyno * looking for block busting power...cms stage 3 blower cams on the horizon..[/
2003 Mustang GT
if you go to there website, i believe it says they only sell direct to the customer.
They do mostly factory direct but a company out of canada called Sean Hyland sells them. That is where i got mine
Patriot stage III heads, 5.1L forged Stroker shortblock, Crane Stage III cams, 90mm MAF with 4'' cold air intake, Dragon 75mm throttle body, Kenne bell ignition, BBK shorty headers with x-pipe and 40 series flowmaster and a Custom Tune. |
they sell direct and will be buggers if you try to buy from anyone but them if you need support. Some vendors will buy the tuner KB kit then add their own parts to make a kit. Bad move in my book. They built it ...they should know what works best. But THEIR kit.
![]() 2002 Sonic Blue GT : Manual, FRPP 3.73's, Ram HDX Clutch, Pypes Violator Cat-Back, Pypes catted X-Pipe, Mach1 Chin, SCT Livewire, PLX SM-AFR as Analog input to LW |
KB'd GT
If you want to install it yourself, you need to buy it from them. The only other place you can buy them is at shops that will install them for you. Depending on your future goals buying the tuner kit may be a better and cheaper option. They charge a ton for some basic parts, but its a great start if thats your last engine mod. Otherwise you may be better off with a better maf, better fuel pump, larger injectors, custom tune, etc.
You beat me to it.
+1 on the custom tune. Last edited by Black Bullitt; January 15th, 2009 at 04:08 PM. |
I plan on doin the install myself.....I also plan to run a 90mm MAF and an svt focus or cobra pump......someday down the road it'l get heads and cams and a forged bottom end....the 2.1 is good for 14psi so it should be fine. I will eventually get a custom tune and when I pull the bottom end Ill probable have to go with bigger injectors to handle more boost....thanks guys
Threads Similar to: kenne bell dealers?
| Kenne Bell | Emay | General Tech | 16 | October 16th, 2007 12:52 PM |
| Kenne Bell ??? | silverstang0988 | General Tech | 17 | April 7th, 2007 12:38 PM |
| kenne bell | punkafi888 | General Tech | 43 | April 4th, 2007 04:52 PM |
