mishimoto radiator info
Old January 16th, 2009, 12:17 AM   #1
ajm
For lefty and those of you that were interested in it I dropped the mishimoto radiator in today. It fits but definetly not like an oem would but still only took about an hour or so to put in including filling mixing the antifreeze to where I wanted it and filling the trans. Ill post pics tomorrow but w/o making this a book heres a few things about putting this thing in.
Preparing to go in
1. You have to remove the plastic clip holding the lines together on the front of the traction control module
2. You have to cut/modify the rubber mounts both upper and lower.
3. You have to cut a chunk off of the fan assembly
4. Transmission lines dont seal real well so teflon isnt a bad idea
Putting it in.
1. You cannot put the fan on the radiator and then drop it in like the factory one
2. You must remove the battery and battery tray to allow for room for the fan to go in as you have to go around and under the upper hose inlet/outlet, removing the drain cock on the radiator also makes it easier to put in
3. The upper trans line runs BETWEEN the fan assmebly and radiator not behind/outside it like oem
Im sure someone will ask why all this is needed so; the radiator is much thicker than oem. Because of this the fan assembly has a TIGHT fit between the traction control lines and the radiator removing the clip allows the lines to move out of the way some. Cutting the rubber mounts is pretty straight foward the dowels dont drop right in like the oem for whatever reason they made them fit RIGHT up against the metal circle the mount sits in. As for the fan assembly modifying its the same deal, the radiator is thicker so it pushes the fan closer to the engine bc of this theres a spot that hits the powersteering line and there is no place for the powersteering line to be moved so there you have it and once again same thing with the upper transmission line it cannot strech around the fan assembly and then thread into the radiator its about 1/2" too short so it must go between the fan assembly and radiator meaning you have to put the radiator in, connect the trans lines, then drop the fan in. The trans lines didnt seal too well I had them fairly tight (w/o trying to rip out the aluminum threads) and they both leaked pretty bad. After some teflon and going a bit tighter they worked fine. As some of you may know I do this crap for a living, when the body business was good I was doing atleast 5-6 radiators a week in various vehicles and id have to say this one tops it for being the most pain in the ass as far as things fitting goes, you couldnt just drop it in it was like putting together a puzzle. As I said ill post pics tomorrow and I did take pics of how the mounts had to be cut, fan assembly had to be cut, etc. As far as performance goes ill let you guys know tomorrow as well since I didnt drive it tonight.
Old January 16th, 2009, 12:21 AM   #2
njstang's Avatar
13.58 @ 102.31
njstang has a spectacular aura aboutnjstang has a spectacular aura about
iTrader: 5 reviews
i have heard bad things about mishimotos, some of my buddys had them in their drift cars (240sx) and they ended up going back to stock
Originally Posted by Jazzer The Cat View Post
Jazzer says heat your meat so it sticks to the street
NEW JERSEY STANG OWNERS :
http://njnewedge.forums-free.com/
Old January 16th, 2009, 12:55 AM   #3
ajm
Seems like these things are real hit/miss. Some people have them and love them others have them and have nothing but trouble. I guess ill find out one way or the other lol. Quality wise it seems quite nice but it fits like any other aftermarket part does...shitty.
Old January 16th, 2009, 08:21 AM   #4
Resident DJ
Lefty's Avatar
'01 Cobra Vert.
iTrader: 12 reviews
Ha, hurry up with those
Old January 16th, 2009, 11:01 AM   #5
njstang's Avatar
13.58 @ 102.31
iTrader: 5 reviews
+1 my buddys had prototypes and they were having trouble with leaking
Old January 16th, 2009, 03:02 PM   #6
1999 Mustang GT
hardhitter has a spectacular aura abouthardhitter has a spectacular aura abouthardhitter has a spectacular aura about
Send a message via AIM to hardhitter
Go with Fluidyne
Vortech V2 Si
Old January 16th, 2009, 05:50 PM   #7
ajm
Originally Posted by hardhitter View Post
Go with Fluidyne
I hate to be a dick but do you actually read? I wasnt asking which one to go with I was posting up info about the mishimoto for people that were interested in it but couldnt find any info...lefty in particular, and as far as I know (from what ive read) the fluidynes seem to be a hit and miss as well as far as leaking goes
Old January 16th, 2009, 05:52 PM   #8
njstang's Avatar
13.58 @ 102.31
iTrader: 5 reviews
Originally Posted by ajm View Post
I hate to be a dick but do you actually read? I wasnt asking which one to go with I was posting up info about the mishimoto for people that were interested in it but couldnt find any info...lefty in particular.
haha sorry thats funny
Old January 16th, 2009, 05:53 PM   #9
Resident DJ
Lefty's Avatar
'01 Cobra Vert.
iTrader: 12 reviews
Old January 16th, 2009, 06:28 PM   #10
njstang's Avatar
13.58 @ 102.31
iTrader: 5 reviews
i talked to my buddy today he had it in his 08 Si. he said that hes not sure how much colder it helped the car run because he has those digital gauges, but he said like 2 or 3 "clicks" on his temp gauge, he told me that he took his out because it would leak but he said from the hoses not the rad itself
Old January 16th, 2009, 09:26 PM   #11
ajm
Thats about how much it helped for me, right around 2 little marks cooler than what it was running with the factory one. Im also somewhat sure I could have wigged the power steering line over a bit after looking at it today with some better light but in the end it was much easier and faster to wack a piece of the fan assembly off w/ a cutoff wheel & 90* die grinder w/ a 60grit roll loc to smooth things out
Threads Similar to: mishimoto radiator info
mishimoto radiator ajm 99-04 10 January 12th, 2009 12:44 AM
Mishimoto Aluminim Radiator rasalibre 5.0 Mustangs 9 December 21st, 2008 11:36 AM
Mishimoto Radiator RX Bandit 2005 - 2010 12 October 26th, 2008 12:19 AM
Mishimoto Radiator 97GT4.6 96-98 4 March 13th, 2008 10:43 PM
Mishimoto Radiator And V2 SQ LM4600 99-04 3 November 15th, 2007 07:46 PM
