Plenum and Throttle Body
Old January 16th, 2009, 09:35 PM   #1
scxc15's Avatar
2003 Mach 1
12.7@107
scxc15 is on a distinguished road
So I have someone wanting to sell me an Accufab Plenum and 75mm throttle body for a very good deal. Only thing is seems like I recall a 75mm throttle body being too much for a stock GT... What mods would you need so that it wouldn't hurt it?
2003 Azure Blue Mach 1 5-Speed
BBK LTs, o/r X-Pipe,FRPP 4.30 Gears, MGW Shifter, JLT Ram Air, AJE K-member, Eibach Sportline Springs,
Moroso Wet Sump Street/Strip Oil Pan, Nitto 555Rs, Steeda Clutch Adjuster, SCT X-Cal 3, NGK TR55ix Plugs
Old January 16th, 2009, 09:40 PM   #2
DARKHORSE02's Avatar
2002 MUSTANG GT
DARKHORSE02 is on a distinguished road
I Just Asked This Question From A Rep At American Muscle. It Wont Hurt Anything You Just Wont See The Advertised 7-11 Hp Gain. I Believe Big Mods (cams, Lt, Blower) Is Where You See The Benefit Of A Larger Tb. I Cant Tell You This From Experience And I Hope Someone With Hands On Know Can Be More Helpful.
Old January 16th, 2009, 10:59 PM   #3
April 2012 ROTM
wishIhada5.0's Avatar
2002 GT, True Blue, Stick
wishIhada5.0 is a jewel in the roughwishIhada5.0 is a jewel in the roughwishIhada5.0 is a jewel in the roughwishIhada5.0 is a jewel in the rough
Send a message via AIM to wishIhada5.0
I run a C&L/BBK 75mm tb/ JLT fenderwell setup and I can tell you first hand that its not to much. F/I will really make it shine though
True blue crew founder/member #1
378/442 rwhp/rwtq*on a Mustang dyno* cams are in..#'s coming this summer
Old January 17th, 2009, 12:04 PM   #4
Trick Tuners's Avatar
KB'd GT
On a near stock car the hp gains will be near 0. 7hp is hardly enough to measure on a dyno and that is probably with a 400+hp car.
Old January 17th, 2009, 12:06 PM   #5
RALVAREZ26's Avatar
2000 MUSTANG GT
RALVAREZ26 will become famous soon enough
when i put mine i wasn't expecting any HP gains really i just wanted a better throttle response when i step on it, which is exactly what happened!
http://smokinperformance.com
Slowmatic 2000 GT
Old January 17th, 2009, 12:10 PM   #6
03gtfirered's Avatar
2002 MUSTANG GT
14.2@100
03gtfirered is on a distinguished road
plus the real restriction is in the plenum. you'll see more of a diff in the plenum swap then TB.
______________________________
summit racing catback, bassani o/r x pipe, RAM HDX,jlt intake, mach grill delete, tinted headlights and tail lights!!
Originally Posted by TwirtleNutZ270 View Post
Dude not having a tuner is kinda like having a cake without a fork.
Old January 17th, 2009, 01:32 PM   #7
njstang's Avatar
13.58 @ 102.31
njstang has a spectacular aura aboutnjstang has a spectacular aura about
iTrader: 5 reviews
+1, tb and plenums wont net you much hp, the rule of thumb seems to be 70mm for n/a cars and 75mm for sprayers or boost. im sure if you have some radical cams and head work that a 75mm would work better than a 70mm but for you adverage mustang with bolt ons 70mm is plenty. it is a fact that the stock plenum is the restrictive part of the intake, not as much the TB
Originally Posted by Jazzer The Cat View Post
Jazzer says heat your meat so it sticks to the street
NEW JERSEY STANG OWNERS :
http://njnewedge.forums-free.com/
Old January 17th, 2009, 05:55 PM   #8
bullitt ak's Avatar
2001 mustang bullitt
bullitt ak will become famous soon enough
there not gunna do much unless you have forced induction basically...
Old January 17th, 2009, 08:34 PM   #9
Abe02GT's Avatar
Abe02GT is on a distinguished road
Accufab/JLT combo looks mean. I smile every time I open my hood.
Check my garage for pics and mods!
Originally Posted by svtkidd23
if my gears were a vagina.. id beat it up!
Old January 17th, 2009, 09:17 PM   #10
00gtCoolGuy's Avatar
13.67 @ 99.3..5000 ft D.A.
00gtCoolGuy is on a distinguished road
i recently installed a jlt, 75 mm tb, and plenum on my basically stock GT and knocked off .3 of my ET and gained about 2 mph on on my trap
just get a 75 mm, it won't hurt and allows room to grow
2000 Mustang GT- 4.10's, Hoosier DR's, JLT, 75 mm TB, Plenum, MAC LT's, VRS O/R X-pipe, MAC Catback
13.671 @ 99.11 (1.80 60')
5000+ ft above sea level - in El Paso, TX
http://www.youtube.com/watch?v=U2l4JdEg3hg
Old January 18th, 2009, 02:30 AM   #11
UnixHH's Avatar
2003 Saleen S281
UnixHH is a glorious beacon of lightUnixHH is a glorious beacon of lightUnixHH is a glorious beacon of lightUnixHH is a glorious beacon of lightUnixHH is a glorious beacon of light
Send a message via Yahoo to UnixHH
my 75 mm accufab plenum and throttle body made me looose low end torque and gain like 1 hp up top. (so the dyno tells me) but it did help alot when i put the cams and blower on it
480RWHP 450RWTQ 15psi @ 15* on 91 octane
Old January 18th, 2009, 04:25 AM   #12
Hasselm8's Avatar
'99 Mustang Gt
IDK
Hasselm8 is on a distinguished road
+1 Too bad shes totaled now, But I had the 70mm Accufab tb and plenum + JLT and the set up was mean. 75 mm wont net you much in hp but if you got cam work scheduled than it is worth it, otherwise 70mm is fine.
"A wise man can learn more from a foolish question than a fool can learn from a wise answer. "
Old January 18th, 2009, 08:03 AM   #13
jivepepper's Avatar
jivepepper is just really nicejivepepper is just really nicejivepepper is just really nicejivepepper is just really nice
Exactly +1
It won't help more than a 70mm but won't hurt either.
665/541 WHP/WTQ 4.6L SOHC 2V ON 93 OCTANE PUMP GAS.
NO METH INJ., NO E85, NO RACE GAS, N2O BABY BOTTLES!
TRAP=POWER: 11.01 @135, IN SUMMER HEAT, 1350' TRACK, 315/35/17 DR'S
Old January 18th, 2009, 10:49 AM   #14
KB'd GT
Quick tip: You don't need extra intake volume for nitrous. The "air" is in liquid form and injected thru the N2O system. It may slightly increase the VE, but i would be really surprised to see more than a 2% increase in air flow at the maf.
Old January 18th, 2009, 11:49 AM   #15
jivepepper's Avatar
It might not be measured at the maf but there has to be more volume or there wouldn't be more power.
Old January 19th, 2009, 12:09 PM   #16
KB'd GT
The extra air "volume" comes in the form of liquid N2O
Old January 19th, 2009, 12:56 PM   #17
jivepepper's Avatar
Which releases it's O2 from the nitrous molecule when it's introduced into the warm engine. It is still a pressurized volume of oxygen which is easier and safer to deliver to the engine attached to a nitrogen molecule.
You're adding an additional volume of oxygen or you wouldn't be making more power. It's canned O2. The reason you can't use just pressured O2 not already attached to a nitrogen molecule is that it's to flammable and would blow your head off in that form.
Again my point is that you can not increase power in an internal combustion engine with out increasing the air flow. So there for nitrous has to increase airflow.
Old January 19th, 2009, 01:04 PM   #18
KB'd GT
There is no increase in air flow, only in the (O2) "air" in the combustion chamber. (well maybe if you spray the N2O pre maf, which is stupid if you ask me). You got the basics of N2O down, but i think you are confused on where the "air" is coming from.
Old January 19th, 2009, 01:17 PM   #19
jivepepper's Avatar
It's coming from the the 1000lbs+ psi compressed nitrogen being shoved in the motor and releasing O2 when it hits the hot combustion chamber.
There is an increase in oxygen volume. Might not have the same volume as a Sc or turbo because the O2 in the atmosphere is at a lower concentration but it is still an increased in volume of O2 or there wouldn't be an increase of power.
A supercharger/turbo might have to move more for the same effect, but in a different way it's doing the same thing.
Old January 19th, 2009, 01:24 PM   #20
KB'd GT
I think we are a little off topic. My original comment was this.
Threads Similar to: Plenum and Throttle Body
Throttle body and plenum jem02 99-04 16 January 20th, 2009 08:23 AM
Throttle Body + Plenum xXJayManZXx17 99-04 6 September 15th, 2008 11:19 AM
plenum/throttle body Jucostud 96-98 11 February 19th, 2008 12:19 AM
PP Throttle body/plenum ? auburntiger7231 99-04 10 October 12th, 2007 08:56 PM
throttle body and plenum HP Cantbeatblack 99-04 16 October 1st, 2007 10:51 AM
