![]() ![]() ![]() ![]() ![]() iTrader: 13 reviews
Why wont my car start?
Today i went to go start it. i start it about once a week. its been extremely cold the last 2 weeks so maybe stuff is all freezed up, i dont know. but i connected the battery and all the electronics work but the engine wont even crank. i just turn the key and nothing happends, quite as a mouse. what could be wrong?
2011 Caddy cts, 09 Jag XJ
just a shot in the dark but did you try jumping it?
![]() 2000 GT- Gone but not forgotten |
13.00 @ 105
![]() iTrader: 1 reviews
any gauge cluster lights come on when you turned the key?
check ur battery.make sure u have a good connection.ur battery may have enough to make ur electronics work but not ur car....how old is ur battery.the cold will kill them dead if there old..if its the battery nows a good time to get a optima
I agree with 00redgt. I know that I'm too new to truly appreciate this but, Optima is the power 24/7 fukkers.
1999 Mustang GT
13.8
easy way to tell if its the battery. on mine when it went dead it was to the point of it not even clicking but my idiot lights and guages moved, when i tryed cranking it my guages tried to sweep over and bad but were very erratic, also my theft light was really slow and nearly not blinking at all when it was too dead to crank
99 forrest green vert: -Diablosport Predator & Tune (removed for cheap gas use) -Motive 3.90 gears -MRT Catted H -Flowmaster American Thunder catback -Eibach Sportlines -Tokico D-Spec shocks & struts My Garage |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 4 reviews
Check the battery. Its possible it may have enough juice to turn on the electronics but not enough to actually turn the engine over.
13.00 @ 105
this is what I was getting at... if you battery is drained, when you turn the key, the gauges will do a sweep to each side
2011 Mustang GT
12.1 @ 116
Cold weather is HARD on batteries. We had a spout of nights in the teens down here and every morning that week my car would struggle to crank over. This week it's been somewhat warmer with lows in the high 30s and she cranks right on over...
My guess is that the cold weather is just taking it's toll. Try to let the system prime up as well by click it twice before actually cranking it up. If it doesn;t crank by the 3rd time trying, don't try it for a little bit and call someone.
Mods in garage. Built suspension and gears since posted times. |
Mustang GT 2002 & 1993
Almost %100 its the batt.
get a new one and the higher the amps the better.
2002 Mustang GT + 1993 Mustang GT |
Safud: MM's Resident Hadji
Mine has the same problem, and its NOT the battery. I've been trying to figure out this problem for a couple weeks. The guy at advanced auto says it could be the starter going on its way out
MM.s Used Car Whore
2011 F150 XLT 4x4 5.0
14.89
could be the starter.?
or drained battery.. or loose ground some where |
ok i was thinking it was the battery too, Its been 0 to -25 degrees here the last couple of days. didnt know cold had anything to do with the battery. But yeah all the guys at work told me to try and jump it. ill have to do that tomorrow i guess.
thanks for everyones help. ill let you guys know if it doesn't work. Edit** the battery is brand new pretty much. Drove 1,000 or 2000 miles on it.
#14 | |
MM.s Used Car Whore
14.89
bad ground on starter... or! bad starter... our starters suck
2000 Ford Mustang GT
probably pretty insulting of me to ask, but did you press the clutch in?
#17 | |
#18 | |
MM.s Used Car Whore
14.89
#19 | |
Resident DJ
'01 Cobra Vert.
Threads Similar to: Why wont my car start?
| car wont start... | DeMello | 99-04 | 27 | May 28th, 2008 03:24 PM |
| car wont start | 1BADSTANG | 5.0 Mustangs | 12 | January 14th, 2008 01:01 AM |
| car wont start.. | soop7 | V6 Mustangs | 3 | December 1st, 2007 03:18 PM |
| Car wont start!?!? | SantanielloITA | V6 Mustangs | 70 | November 7th, 2007 04:24 PM |
| Car wont start | 99v6stang | V6 Mustangs | 41 | February 20th, 2007 10:08 PM |
