king cobra HD clutch kit? - Forums at Modded Mustangs
post #1 of 21 Old January 25th, 2009, 01:21 PM Thread Starter
03gtfirered's Avatar
has anyone used this clutch? do you like it? do i need the bolt and dowel pin kit like they said or will i be safe using the old ones? will this kit fit my 2002gt windsor 8bolt? thanks Ford Racing M-7560-C302N - Ford Racing Clutch Kits - JEGS
______________________________
summit racing catback, bassani o/r x pipe, RAM HDX,jlt intake, mach grill delete, tinted headlights and tail lights!!
Originally Posted by TwirtleNutZ270 View Post
Dude not having a tuner is kinda like having a cake without a fork.
03gtfirered is offline
post #2 of 21 Old January 25th, 2009, 02:22 PM
Joebert's Avatar
i have this clutch in my car(99 GT) and i love it. very stiff, and grabs very well. you should always replace bolt and dow pin with new, cause it wouldnt hurt. dont see why it wouldnt fit your 02 GT
Joebert is offline
post #3 of 21 Old January 25th, 2009, 03:20 PM
jivepepper's Avatar
If you have a mild to moderately modded car it's a decent clutch.
665/541 WHP/WTQ 4.6L SOHC 2V ON 93 OCTANE PUMP GAS.
NO METH INJ., NO E85, NO RACE GAS, N2O BABY BOTTLES!
TRAP=POWER: 11.01 @135, IN SUMMER HEAT, 1350' TRACK, 315/35/17 DR'S
jivepepper is offline
post #4 of 21 Old January 25th, 2009, 03:43 PM Thread Starter
thanks guys. just want a reliable decent clutch.
post #5 of 21 Old January 25th, 2009, 03:56 PM
99mustanggtman's Avatar
iTrader: 7 reviews
Send a message via AIM to 99mustanggtman
2002 GTs don't have a windsor, they have Romeo 6 bolts....
Single 67mm turbo, ported pi heads, edelbrock vic jr. manifold w/HPP plenum, terminator shortblock, return fuel system... Goal 600+ rwhp.
99mustanggtman is offline
post #6 of 21 Old January 25th, 2009, 06:19 PM Thread Starter
ur right i made a mistake. its a romeo not a windsor.
post #7 of 21 Old January 25th, 2009, 09:30 PM
iTrader: 7 reviews
Go with a Centerforce, great clutch pedal feel, and grabs great
post #8 of 21 Old January 25th, 2009, 10:08 PM
XectriK's Avatar
That clutch wont fit your transmission. It's meant for the T45 whereas you have a T3650.
XectriK is offline
post #9 of 21 Old January 25th, 2009, 10:24 PM
jivepepper's Avatar
It's not the tranny that keeps it from fitting it's the flywheel. 10.5" for 2000 down and a 11.5" for 2001+.
I'm using a 2000 gt 8 bolt flywheel and 10.5" clutch with a tr3650 right now on a Cobra crank.. The main spline spline count on the main shaft is the same for both. I have also used a 11.5" clutch/flywheel with a T-45.
post #10 of 21 Old January 25th, 2009, 10:26 PM
mm's nitrous mod
SWEET2KSTANG's Avatar
iTrader: 8 reviews
^11 in, not 11.5
wagon burner built! track times coming soon!(04 lightning)
follow shop builds on facebook at: MP2 Performance
SWEET2KSTANG is offline
post #11 of 21 Old January 25th, 2009, 10:30 PM
jivepepper's Avatar
Originally Posted by SWEET2KSTANG View Post
^11 in, not 11.5
W/E Your right
post #12 of 21 Old January 25th, 2009, 10:35 PM
03MachMe's Avatar
did you spec stage 1 take a crap on you too? mine is going out but its prolly from the 5500rpm launches i have been doing at the track lol
mostly stock
8.2@83 1/8th
03MachMe is offline
post #13 of 21 Old January 26th, 2009, 12:02 AM Thread Starter
yeah my spec is garbage. shakes on take off and downshifts and my tob sings like a mofo. and that king cobra clutch is 10.5in and it said it will fit the 99-04 gt w/ tr3650. your thinking of the other king cobra clutch. look at the specs in the link i posted. thanks for all your help guys.
post #14 of 21 Old January 26th, 2009, 12:04 AM Thread Starter
Notes:
Clutches have NO warranty!
All clutch discs have 1.0625"-10 spline hub.
Fits all 1986-01 Mustang GT, 1993-98 Cobra with T-5 or T45 Transmissions. 2001-04 Mustang GT with 3650 transmission and 1999-03 Cobra uses an 11" clutch. OK to mix and match Ford Racing clutch discs and pressure plates but do NOT install a FRPP pressure plate with a stock disc or vice-versa as disengagement problems may occur. Installation of 10.5" clutch assemblies on 1979-85 vehicles equipped with 10" clutch requires new flywheel. Metric fasteners and dowel pins must be used with 10.5" clutches.
Requires metric pressure plate bolts N602549-S51M and alignment dowel pins D1FZ-6397-B, Ford Racing kit M-6397-A302.
*edit i guess this is wrong then cause the clutch has to be an 11in to fit then right?
post #15 of 21 Old January 26th, 2009, 12:12 AM Thread Starter
could i use this flywheel with that clutch kit? sorry for questions i just want to find a nice setup within my budget. thanks
Ford Racing M-6375-D46 - Ford Racing Flywheels - JEGS
post #16 of 21 Old January 26th, 2009, 02:13 AM Thread Starter
bump
post #17 of 21 Old January 26th, 2009, 02:19 AM
iTrader: 7 reviews
That will fit, but why not just your stock one resurfaced for like $60?
post #18 of 21 Old January 26th, 2009, 10:47 AM Thread Starter
i got it resurfaced once already and i dont know how many times you can safely do it. plus i dont want do the whole job again for the machining to be off on the flywheel. you think its alright to resurface again? again sorry for all the newb questions i just wanna make sure its done right this time. thanks
post #19 of 21 Old January 26th, 2009, 11:06 AM
The UPS guy
MikeD05GT's Avatar
Send a message via AIM to MikeD05GT
its a good clutch...ive been through a few...and when all else failed, just went back to ford racing..replaced the tob, and bearing retainer...and resurfaced the flywheel...all with upr quadrant and steeda adjustable cable..
MikeD05GT is offline
post #20 of 21 Old January 26th, 2009, 01:15 PM
Insurmountable Lead
Draidin's Avatar
Summit Racing, also based in Ohio, sells the same kit for $205
Ford Racing M-7560-A302N - Ford Racing Clutch Kits - summitracing.com
Jegs tends to be pricey.
MAC axle-back | 3:73 gears | Wheels: 18x9 deep dish Bullitt | Tires (255/45/18): front - Continental DSW, rear - Continental DW Extreme Contact + 1" wheel spacer | BMR lower control arms
<br>
Draidin is offline
Human Verification
