HiTech stg2 cams - Page 5
LinkBack (4) Thread Tools
Old January 28th, 2009, 08:47 PM   4 links from elsewhere to this Post. Click to view. #81
Sweet35th is on a distinguished road
Originally Posted by Jakashh View Post
I know this is a stoopid question, but how much gas mileage will i lose with these cams only?
and is it recommended to get 3.55 or bigger gears with this cam?
Ok, well since I work for Hitech and do most of the tuning, Ill answer what questions I can.
Jakashh, one of my customers on a highway trip from Minneapolis to Chicago got 24mpg in his 03 GT with 3.73 gears, bolts ons, long tubes, and Hitech Stage 2 cam shafts.. I have not had anyone report back noticable losses in fuel economy with the stage 2s at all when driven "normally."
Someone asked about blower cams. Yes we have a variety of blower cams for centrifugal blowers as well and KB/whipples. Below is a dyno graph of an 01 GT with the fallowing mods.
-DSS long block with ported heads
-Long tube headers
-P1SC (aprox 12#s boost)
-P51 intake
-AFM power pipe
The before run was with comp 270s, and the after run was with Hitech stage 2.5 blower cams. The car was fully tuned with both sets of cams, and timing was the same with both sets of cams as well.
[IMG][/IMG]
Someone else asked about if headers were needed, and how would the stage 2s react with stock manifolds.
Now I have personaly never done a 5speed car with stock manifolds and stage 2 cams. However I recently received a call from a customer with a 99-04 car (cant recall for sure) with bolt ons, stock manifolds x-pipe (do not know if off road of catted), that made 280rwhp, which through the stock manifolds I would quite impressed with.
I have personally done an 04 GT with JBA shorty headers, a catted x-pipe, pullies, plenum/tb, CAI and Hitech stage 2s that made 291rwhp 308rwtq.
Most of the cars done in house with long tube headers Hitech stage 2 cams, and full bolt ons (generally ran with a pro-chamber off-road) made 300-318rwhp (318rwhp being the best example that I have personally tuned in house).
Below is a post of an automatic GT. I dyno'd and tuned the car in 3 stages.
Stage 1. Off-road x-pipe, CAI, welded in flow master mufflers. Then custom tuned.
Stage 2. The same as stage # but with the addition of stage 2 camshafts and re-tuned.
Stage 3. The addition of long tube headers and prochamber off-road pipe and re-tuned.
As you can see the gains with the Stage 2 cams alone were quite good (37rwhp at peak) and 40+ at 5900rpm. Then with the addition of the long tube headers and the prochamber, the car really came alive, picking up power across the entire power curve for an additional making an additional 30rwhp peak over stage 2 cams alone, and 64rwhp!!! over the stock camshafts, stock manifolds and an off-road x-pipe.
[IMG][/IMG]
Feel free to ask me any other questions, I have quite a data base on cars we have tested with these cams, and our blower cams. I may not be able to match every possible combo but I can do my best to show you what I have.
Old January 28th, 2009, 09:19 PM   #82
sxynerd's Avatar
sxynerd is on a distinguished road
Jims my Hero...
Old January 28th, 2009, 11:59 PM   #83
12.16 @ 112
Trevor04GT is on a distinguished road
Send a message via AIM to Trevor04GT
Nice Casey, glad you chimed in!
Trevor 2004 GT
HiTech Motorsports Stage 2 Cams
300/309 12.16@112
Old January 29th, 2009, 12:04 AM   #84
Imran's Avatar
01
Imran has much to be proud ofImran has much to be proud ofImran has much to be proud ofImran has much to be proud ofImran has much to be proud ofImran has much to be proud ofImran has much to be proud ofImran has much to be proud of
I'm liking these cams...
My trans will be able to support the power at 93K, right?
Old January 29th, 2009, 12:04 AM   #85
moosenuk17's Avatar
2000 ford mustang GT
moosenuk17 is a jewel in the roughmoosenuk17 is a jewel in the roughmoosenuk17 is a jewel in the rough
Send a message via AIM to moosenuk17 Send a message via MSN to moosenuk17 Send a message via Yahoo to moosenuk17
great info!!
2000 kenne bell GT (440HP-432TQ)
Tuned by Joe at http://www.tricktuners.com
dyno vid:http://youtu.be/lr3xpxw2_v8
2011 escape
MUSTANG TAT CREW
Old January 29th, 2009, 12:31 AM   #86
UnixHH's Avatar
2003 Saleen S281
UnixHH is a glorious beacon of lightUnixHH is a glorious beacon of lightUnixHH is a glorious beacon of lightUnixHH is a glorious beacon of lightUnixHH is a glorious beacon of light
Send a message via Yahoo to UnixHH
hmm made 20 more hp and 30 more torque with 3 psi more than me
480RWHP 450RWTQ 15psi @ 15* on 91 octane
Old January 29th, 2009, 12:34 AM   #87
UnixHH's Avatar
2003 Saleen S281
just for comparison..
stock block
stock heads
stock manifolds
stock intake manifold
hp 292 cams
d1sc procharger @9psi
o/r x and flowmasters
Old January 29th, 2009, 02:06 PM   #88
Hawaiianbro will become famous soon enough
Send a message via AIM to Hawaiianbro
Originally Posted by ShapeShifter View Post
id toss on an frpp 31 spline posi unit and some moser 31 spline axles as cheap insurance...the kit can be purchased for 500 or so.
axles and posi unit kit is 500?
where at?
B&M Short Shifter / Ford Heavy Duty Clutch / 3.73 gears / Nitto Drag Radials / Steeda CAI / Diablo Tuned / Mac LT Headers / Lethal Cated Xpipe / Pypes Exhaust / Smoked headlights and Tail lights / GT floor mats / PP 70mm TB / Accufab Plenum
Old January 29th, 2009, 03:41 PM   #89
stock block
stock heads
stock manifolds
hp 292 cams
I do notice that you do have a D1SC however. The graph I posted was a P1SC car, and believe me at those power levels the differance between a P1 and D1 even with compairable boost levels is NOT even compairable.
For example, below is a graph of an 03 Mach1 with a built bottom end, stock heads, crower cams. The before is with a P1SC making aprox 13#s (with a 3.0 pulley)boost, and the after is with a D1SC that made 14#s boost with a 3.4 pulley.
The GT who's dyno graph I posted for the cam compairison is coming back this spring upgraded to a D1SC, I will post the differance between on the P1 and the D1 on that combo as well when I can.
Now I may have been able to push a lil more power out of the P1 on that car, but I could not get anywhere remotely close to the 100+rwhp differance that was found when upgrading to the D1 at the same boost! Now this was a 4V car with a very agressive camshaft profile.
The dyno below is probably a better example of how the stage 2.5 hitech blower cams work with a D1SC.
Mods are:
-03 cobra short block
-Stoch heads
-Stock intake
-Long tubes with high flow cats
-75mm TB and plenum
-10% over drive crank
-3.4in blower pulley
-Hitech stage 2.5 blower cams
Car made aprox 15#s of boost at 6300rpm
Old January 30th, 2009, 07:19 PM   #90
06z28eaTer's Avatar
2006 GT / 1999 Cobra
06z28eaTer is on a distinguished road
Send a message via AIM to 06z28eaTer
i def want these now!
-2000 GT Vert-
Grabber Blue Paint, Cervini Stalker Hood, Xenon Front/Saleen Rear Bumpers, Bullitt Side Scoops, 18"FR500 Wheels, CDC Bar And Much More!
Old January 30th, 2009, 07:56 PM   #91
PapaSmurf's Avatar
2003 Mustang GT
12.28 @ 116
PapaSmurf has a spectacular aura aboutPapaSmurf has a spectacular aura about
iTrader: 13 reviews
Casey,
Do you have any dynographs of full bolton gt's with your stage 2 cams running nitrous? Ive heard that these cams love nitrous and ive been considering picking up a set of your cams just for this reason. Thanks
2003 Sonic Blue GT---SLP Longtubes, SLP X, Magnaflow Magnapack CB, 75mm TB/Plenum, MP2 Performance stage 2 heads, MHS Stage 3R cams, Built rear w/4.30's
Old January 30th, 2009, 08:06 PM   #92
BakerFX4's Avatar
BakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud of
iTrader: 14 reviews
why does the d1 and p1 make a "HUGE" difference in the close to 500 range? If its the same boost then its the same boost huh? What makes them so completely different?
4.75 MMR 900se
Livernois ported heads
HP 292s blower cams
Procharger D1sc at 20+ psi
IW 15% OD pulley
(and more bolt ons)
E85
Tune/numbers coming shortly!!
Old January 30th, 2009, 08:11 PM   #93
slow02gt's Avatar
2002 mustang gt
11.38@119
slow02gt is a jewel in the roughslow02gt is a jewel in the roughslow02gt is a jewel in the roughslow02gt is a jewel in the rough
Send a message via AIM to slow02gt
its a better blower, bigger,more efficant blower more cfm at the same boost that why it makes more power....
built motor,trickflow heads,logan intake,80mm comp turbo on the way..
Old January 30th, 2009, 08:17 PM   #94
BakerFX4's Avatar
iTrader: 14 reviews
oh....
4.75 MMR 900se
HP 292s blower cams
IW 15% OD pulley
(and more bolt ons)
E85
Old January 30th, 2009, 08:20 PM   #95
Boomer is on a distinguished road
Send a message via AIM to Boomer Send a message via Yahoo to Boomer
A smaller blower has to work harder to make the same boost. The downfall to a blower is that is uses horsepower to make horsepower. It is all about efficiency, take a turbo at 6 lbs and it will make more than the average blower at the same pressure or more in most cases. Boost is only a measure of resistance/pressure, a engine that breaths better will take less boost to make the same or more power.
I am not trying to lecture anyone rather trying to put things in understandable terms.
Engine A. (smaller blower) is going to makes more power at a lower rpm/boost than engine B. (larger blower). This is due to the larger blower using taking more power to make power. Engine B. makes more power at full boost due to two things, it doesn't work as hard and doesn't heat the inlet charge.
This is the easiest way I can describe it without getting to technical, reading it I feel like I am leaving something out. But i think I made my point understandable for the most part.
Old January 30th, 2009, 08:21 PM   #96
BakerFX4's Avatar
iTrader: 14 reviews
gotcha boomer!!!
4.75 MMR 900se
HP 292s blower cams
IW 15% OD pulley
(and more bolt ons)
E85
Old January 30th, 2009, 11:09 PM   #97
johnr2001's Avatar
2001 GT
johnr2001 is on a distinguished road
Originally Posted by PapaSmurf View Post
Casey,
I run a 125 shot with them and have no complaints.
03 Mach 1 full eaton swap, 18" chrome bullitts, H&R springs, 5.0 shifter, slp2, mac catted H, FRP 4.10's,
443 RWHP/ 386 TQ
Old February 1st, 2009, 10:35 AM   #98
Casey,
Yes I do, I havnt transfered all of the dyno files onto my home computer, so I wont be able to post them up till monday.
Old February 3rd, 2009, 10:55 AM   #99
PapaSmurf's Avatar
2003 Mustang GT
12.28 @ 116
iTrader: 13 reviews
Its tuesday LOL
Old February 3rd, 2009, 12:42 PM   #100
Its tuesday LOL
Crap!!!! I was chillen with Gargamel
Here you go. 04 GT full bolt ons, long tubes, Hitech stage 2 cams, and NX with modified jet sizes to get 100rwhp out of the shot.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/107173-hitech-stg2-cams.html
CAM QUESTION! | Page 2 | Mustang Forums at StangNet This thread Refback March 31st, 2012 01:32 AM
Comp Cams vs. CMS Cams --Stage 1 Battle-- - Page 2 - MustangForums.com This thread Refback March 24th, 2011 12:20 PM
CAM QUESTION! - Mustang Forums at StangNet This thread Refback February 20th, 2011 11:03 AM
Comp Cams vs. CMS Cams --Stage 1 Battle-- - Page 2 - MustangForums.com This thread Refback February 19th, 2009 12:06 AM
Threads Similar to: HiTech stg2 cams
Video of my HiTech cams Trevor04GT 99-04 12 December 17th, 2008 06:56 PM
Hitech Stage 2 njstang 99-04 7 December 10th, 2008 10:33 PM
hitech stage 2 cams fliptikal 96-98 3 December 9th, 2008 05:07 PM
my hitech stage 2 cams johnr2001 99-04 29 July 15th, 2008 10:02 PM
