coolant on spark plugs
Old January 26th, 2009, 05:37 PM   #1
1999 Mustang GT
hardhitter has a spectacular aura abouthardhitter has a spectacular aura abouthardhitter has a spectacular aura about
Send a message via AIM to hardhitter
I pulled out one of my spark plugs after a recent intake manifold change and its got coolant on it.. is this from a leaking intake manifold gasket?
Vortech V2 Si
Old January 26th, 2009, 05:51 PM   #2
BakerFX4's Avatar
BakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud of
iTrader: 14 reviews
dude everytime you post a thread it reminds me of my car!!!! Swear... One of my plugs smelled like that a while back when mine was missing. Since then i just changed all the COP's and it hasnt came back yet but who knows. I guarantee you tho that i smelled antifreeze on the plug and it even looked wet.
4.75 MMR 900se
Livernois ported heads
HP 292s blower cams
Procharger D1sc at 20+ psi
IW 15% OD pulley
(and more bolt ons)
E85
Tune/numbers coming shortly!!
Old January 26th, 2009, 05:52 PM   #3
BakerFX4's Avatar
iTrader: 14 reviews
A mechanic checked it out and "said" it was fine. so who knows!
4.75 MMR 900se
HP 292s blower cams
IW 15% OD pulley
(and more bolt ons)
E85
Old January 26th, 2009, 06:01 PM   #4
Trick Tuners's Avatar
KB'd GT
On the tip of the plug or the part that the COP goes on?
Old January 26th, 2009, 06:02 PM   #5
Diabeetus's Avatar
Black 2001 Cobra
Diabeetus will become famous soon enoughDiabeetus will become famous soon enough
Send a message via AIM to Diabeetus Send a message via Yahoo to Diabeetus
I would re-seal the intake if I were you.
Black 2001 SVT Cobra
Solid axle
"Good judgment comes from experience, experience comes from bad jugment"
MM Cobra Club Member #1
Old January 26th, 2009, 06:19 PM   #6
1999 Mustang GT
It was on the tip of the plug but I replaced it and pulled it out again and it's dry now
Vortech V2 Si
Old January 26th, 2009, 06:21 PM   #7
1999 Mustang GT
Should I change the spark plugs if they're white?
Vortech V2 Si
Old January 26th, 2009, 06:51 PM   #8
KB'd GT
Check the oil and coolant to rule out a HG, then you may want to double check the intake gaskets. New plugs is never a bad idea. I figure that i'f i'm going to check them i might as well put some new ones in for $30.
Threads Similar to: coolant on spark plugs
Spark plugs F8L GT 99-04 3 August 4th, 2008 12:11 AM
Spark plugs AnFking6908 V6 Mustangs 29 April 26th, 2008 12:31 AM
spark plugs GT33 2005 - 2010 17 April 2nd, 2008 12:51 PM
Spark Plugs Montanasvt 4V / SVT 20 February 11th, 2008 02:13 AM
Spark Plugs BlackIce V6 Mustangs 2 January 12th, 2007 12:05 PM
