MM's Mad Scientist
Slow Fella
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
Engine Build
Well, I finally tore my motor apart. I've got the comp stage II cams on the way, and I'm taking my heads to be ported this afternoon. Also going back with new upper plenum/throttle body and cai. I'm throwing in some 4.10's while she's down too. I'm still debating on an intake. I've read terrible things about the typhoon, but also some good.
BTW: Are the underdrive pulleys worth the money while I'm in there? Also: Has anyone ever done business with Dynospeed in Memphis?
#2 | |
Re: Engine Build
BB&T's doin it this time. their dyno has a 1/4 mile simulator on it.
Nobody gonna take my car Im gonna race it to the ground Nobody gonna beat my car Its gonna break the speed of sound Oooh its a killing machine Its got everything Like a driving power big fat tires And everything - Deep Purple |
MM's Mad Scientist
Slow Fella
Where is BB&T located?
Is it down there around the power plant on stateline?
Pig Romancer
2003 GT
300.32@5.02mph
hey that bb&t (if I got that right), where about is it located? what state, and what county? I'm only like 1.5 hours from tupelo, and about 2 from mephis...is it anywhere near or between those?
Pig Romancer
2003 GT
300.32@5.02mph
MM's Mad Scientist
Slow Fella
I know that it is in Southaven, MS (just south of Memphis on 55), but Im not sure exactly where in southaven.
get off 55 on stateline and head west toward 51. and its down on the left. its actally like right across the street from the power station.
MM's Mad Scientist
Slow Fella
10-4..
What tuning programmers do they sell/use?
you can call'em to make sure but i think they sell both SCT and diablo.
i know they use FAST toothey're info is on my www tab
#10 | |
Re: Engine Build
MM's Mad Scientist
Slow Fella
The P-51 is just a little to much for my money. I may just see how the stock intake does and go from there since it's not really hard to change anyway.
you really don't need an intake just yet anyway. those kinds of intakes pick up alot more power with a power adder. with the setup you are looking at with the cams and ported heads, an accufab T/B and plenum will do you just fine. you wouldn't get the bang for your buck right now. do you have full exhuast with L/T's?
MM's Mad Scientist
Slow Fella
Actually, I have equal lengths with o/r x-pipe and race-flow mufflers.
the p51 loses lotz of power down low in the rpm range
your gonna want all you can down there becasue those cams arent going to come on hard untill about 3500 rpms
MM's Mad Scientist
Slow Fella
Thanks for the input. I figured they would be a litle dead on the bottom. that's why i'm going with the 4.10's
MM's Mad Scientist
Slow Fella
Do I need to get aftermarket coil packs? Will they help out over 5500rpms? I'm just trying to make sure to get some good solid results.
i had a stock intake and a trickflow plenum with my procharger and it made 429rwhp before i put the headers and x-pipe on. but i never got it dynoed again after that,so i est. it made right around 450 on the ground with the stock intake and aftermarket plenum.
MM's Mad Scientist
Slow Fella
cooool.....
MM's Mad Scientist
Slow Fella
Do I need two sprocket retention bolts?? I have read that the holes in the comp cams are larger than factory. Do these come with the cam??
Threads Similar to: Engine Build
| Engine Build Up or Engine Replacement... | OcOnnor220 | 99-04 | 8 | July 27th, 2008 03:54 PM |
| *306 engine build* | shurb125 | 5.0 Mustangs | 18 | October 11th, 2007 08:02 PM |
| Engine build up. | mr_jits | Modular Mustangs | 5 | July 24th, 2007 02:49 PM |
| engine build | ByPopularDemand | V6 Mustangs | 8 | June 14th, 2007 05:20 PM |
| Engine Build Up | hawaiianbrian78 | Classic Mustangs | 3 | November 12th, 2006 10:14 AM |
