04 mustang gt
7.21 @ 98
poly isolators
Do poly isolators make the car sit higher as opposed to using the stock isoloators?? i mean if i swap the stock isolators out for poly urethane isolators is it gonna raise it up a tad? i have heard a few times that they make it sit a little higher...but am not sure..btw, i am referring to the REAR ONLY
thanks
![]() cams + 150 shot |
1997 Mustang GT
Faster than an s4
They will not make your car sit any higher than stock. However, your stock ones are probably partially worn through, so they make be slightly different because of that. However, its not going to be more than .25" or so, so I wouldn't worry about it.
Aztec Gold 97GT. MM CC Plates, Panhard Bar, SFC's & Tower Brace Eibach Sway Bars H&R Race Springs/Bilstein Shocks MAC CAI, LT's, Catted H and Pro-Dumps KB Boost-a-Spark 04' PI Motor Author of The Official Suspension Guide |
04 mustang gt
7.21 @ 98
i want them to help it sit up...i'm putting different coils in the back...and they may slam it a little too much...so i was gonna buy the poly iso's just in case it makes it too low...then i could stick them in and gain a little more height...
just wanted to know if they would be worth buying for this reason
![]() cams + 150 shot Last edited by mrbigjeep; January 30th, 2009 at 07:37 PM. |
same thing with me man haha
-2003 TERMINATOR- -2006 MUSTANG GT- |
04 gt dsg
i have upr eibach pro kit with poly isos front and rear.
04 mustang gt
7.21 @ 98
thanks...i ordered them...
#7 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 4 reviews
Exactly what he said. Comparing a new oem isolater and poly isloator the thicknesses will probably be the same, but over time the factory rubber one wears out and starts to get thinner where the spring sits so by changing to the poly ones it should raise it up some from where it currently sits. |
Threads Similar to: poly isolators
| Removing spring isolators | Texas01GT | 99-04 | 12 | July 1st, 2008 03:36 PM |
| Poly Bushings | vtmustangs | 2005 - 2010 | 10 | March 6th, 2008 03:52 PM |
| Springs w/o Isolators | formgen | General Tech | 4 | October 28th, 2006 01:10 AM |
| Spring Isolators | mustangdrvr2019 | V6 Mustangs | 2 | October 2nd, 2006 09:36 AM |
| bushings of poly or thane? | WVSNS& | General Tech | 4 | May 1st, 2006 11:13 AM |
