Car wont start - Page 2
Old February 1st, 2009, 07:15 PM   #21
TheUNZippee!'s Avatar
Originally Posted by Black01 View Post
Yeah but it didnt even start when i jumped it
Be more definitive. Didn't start, as in it was turning over fine but won't fire, or it wouldn't turn over at all, or turn over fast enough.
Turn over= what is happening as you turn the key to start.
Turn over but not start= engine is spinning normally but not firing.
BONER CREW EMPLOYEE - BWAL, CEO
Originally Posted by My Wife
Old February 1st, 2009, 07:19 PM   #22
1999 cobra
99blkcobra is on a distinguished road
Send a message via Yahoo to 99blkcobra
i civic batery will work just to see if thats it. my brother in law uses a 54rdl (civic battery) from autozone that he has in the back of his truck, just to jump start his tahoo when it drains out, (he has a system)
1999 Mustang Cobra (rebuilding, someday...)
1996 civic dd
[/SIZE]
MM Cobra Club #3
Old February 1st, 2009, 07:20 PM   #23
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
on a fresh kill ( of a battery) I can see that working, but not a 4 month dead battery. lol
Old February 1st, 2009, 07:33 PM   #24
Black01's Avatar
2001 Mustang GT
Black01 is on a distinguished road
yeah it would just turn over but not fire and start when i jumped it. Is it true that if i just push down on the schrater valve fuel should come out? or do i need a fuel pressure gauge to test that?
Old February 1st, 2009, 08:30 PM   #25
hughball65's Avatar
'00 GT,5-spd, X
hughball65 is on a distinguished road
Your fuel rail should be pressurized after cranking to around 28-35 psi. If you actuate the schrader valve, there should be pressurized fuel present, which would indicate fuel pump probably working.
Also need air for the combustion process... make sure something didn't die or build a nest in your air cleaner.
Next is spark. I would first check fuse(s) that are associated with ignition, then check if spark is happening to the plugs... try the ol' spark to block check.
Threads Similar to: Car wont start
Car wont start adam654 99-04 25 March 4th, 2010 10:01 PM
My car wont start Reset 99-04 34 December 14th, 2008 05:49 AM
car wont start Black Five 0h 5.0 Mustangs 8 January 4th, 2008 03:12 PM
Car wont start 99v6stang V6 Mustangs 41 February 20th, 2007 10:08 PM
Car Wont Start? 87ttopstang 5.0 Mustangs 4 February 7th, 2007 09:45 AM
