? difference between a blow through and draw through maf
Old February 2nd, 2009, 08:16 PM   #1
01 blue bullitt's Avatar
01 blue bullitt will become famous soon enough
This has been very confusing for me. What are the pros and cons? What is the tuning difference? I will be running a vortech bypass valve that is open while idling closes under throttle then reopens when throttle is closed... Any help?
Old February 2nd, 2009, 08:33 PM   #2
ajm
As far as I know the main differences are tuning and given you take the same maf and run it blow through, then run it draw through the blow through will peg easier. I may be wrong though.
Old February 2nd, 2009, 08:40 PM   #3
its a abaco mass air and the guy before me was making over 900 rwhp so I hope I dont peg it
Old February 2nd, 2009, 08:42 PM   #4
B0B
Boost gets you laid
B0B's Avatar
2001 Mustang GT
12.93@113.7 (on the 18's)
B0B is just really niceB0B is just really niceB0B is just really niceB0B is just really nice
Send a message via AIM to B0B
draw through MAF's are located before your blower/turbo. the blower sucks the air through the maf basically. not as accurate and you have to run a bypass back into the intake AFTER the MAF or it will throw off the readings.
Blow Through MAF's go after the blower/turbo and read the air flow as close to the Throttle body as feasable. they are more accurate and you can run a blowoff valve as long as the valve is before the maf and as far away from it as possible. they may peg slightly sooner than a draw though but i doubt its that much.
'01 GT. Just a couple Bolt-ons. 0rwhp 0rwtq. Epic Turbo build in progress
2003 Rubicon (wheelin rig)
2008 Silverado 4x4 (towin rig/road queen)
2009 KTM 450 XC-W (Brap Brap!)
Old February 2nd, 2009, 08:45 PM   #5
I am using a vortech bv57 which is open at a idle and closes when throttle opens will this be a issue?
Threads Similar to: ? difference between a blow through and draw through maf
stuck between staying blow through or converting back to draw through. pimpdout98gt General Tech 9 August 25th, 2008 11:45 PM
Converting 90mm maf to blow thru on Sc. Pics jivepepper 99-04 8 August 2nd, 2008 11:40 PM
Blow thru MAF carlos 99-04 7 May 14th, 2008 07:27 PM
