injectors
will 36# injectors be enough with a kb 2.1 at 9psi and cams? (provided I have the pump (SVT Focus or GT) etc. to back them up)
True blue crew founder/member #1378/442 rwhp/rwtq*on a Mustang dyno * looking for block busting power...cms stage 3 blower cams on the horizon..[/
Boost gets you laid
they would probably reach at least 90% duty cycle, those injectors are good to around 430 horsepower.. crank. i'd go ahead and get the 42's man, your injectors will be the weakest link if you go with the 36's.
![]() '01 GT. Just a couple Bolt-ons. 0rwhp 0rwtq. Epic Turbo build in progress 2003 Rubicon (wheelin rig) 2008 Silverado 4x4 (towin rig/road queen) 2009 KTM 450 XC-W (Brap Brap!) |
^^+1, the kit comes with 36#ers but if cammed that is more are and needs more fuel i would think, get the 42s
![]() 2000 kenne bell GT (440HP-432TQ) Tuned by Joe at http://www.tricktuners.com dyno vid:http://youtu.be/lr3xpxw2_v8 2011 escape MUSTANG TAT CREW |
2003 gt
5.4 32v on the way
just go with 42, can't hurt you.
Before asking a gearing related question click THIS link and enjoy all your saved time. Click here for your tuning needs My slow paced budget 5.4 dohc build |
I don't think the 36 lbers will be enough.
KB'd GT
you will be fine. If they are from KB they are probably actually 38#.
Boost gets you laid
what if he wants to expand and put a smaller pulley on it?
KB'd GT
Then he should probably build the motor first.... and if you build the motor, you would need a bigger blower! I'm pretty sure KB hit 500 with those injectors in their tests. You can bump the FP to get a little more room if needed, but if you already have some 38s, its hard to justify spending 200+ for new injectors. If you don't have them already might as well go with 60s. They cost about the same and work just fine.
Threads Similar to: injectors
| Injectors | mustang1072 | 5.0 Mustangs | 20 | August 25th, 2008 10:27 PM |
| Injectors | Juggalo_X | V6 Mustangs | 2 | October 9th, 2007 04:06 PM |
