#21 |
2002 MUSTANG GT
14.2@100
![]() iTrader: 1 reviews
+1 i heard there coming out in spring and are going to be around 2k. they will flow much better then a ported PI head. just wait bro you'll be much happier with them. just my 0.02
#22 |
2001 bullitt #835
not fast enough
![]() iTrader: 4 reviews
yeah me too.
Bullitt #835 4:10s, bassani O/R X, bassani mufflers, Bassani mid-headers, forged/built 2v, trickflow 44 heads, BIG blower cam, v1 vortech intercooled 11# boost 532rwhp/468tq
#23 |
I heard the tfs was bigger? Plus a whole lot cheaper and I don't change all the other stuff that has to be done with the bullit. alternator. fuel rails etc.
665/541 WHP/WTQ 4.6L SOHC 2V ON 93 OCTANE PUMP GAS. ![]() NO METH INJ., NO E85, NO RACE GAS, N2O BABY BOTTLES! TRAP=POWER: 11.01 @135, IN SUMMER HEAT, 1350' TRACK, 315/35/17 DR'S
#24 |
1997 Mustang GT
Faster than an s4
There are actually a lot of options out there for intakes.
If you are simply looking for a metal intake manifold to survive your nitrous, the hardball intake from Texas Hot Rods and a the Typhoon intake are a decent piece. The Typhoon however, has unreliable fitment and power gains. Both are supposed to improve, but they are both only going to show at high rpm. If you want a piece that is metal, strong and adds decent performance, the Trick Flow Track Heat intake, the Bullit Intake and the P-51 intake are very good intakes. They are a step above the metal pieces from Tehas Hot rods and Typhoon, in power gain and qulity. They are all proven, very good performing and well built intake manifolds, but they also cost a bit more, and often require new fuel rails for fitment. Reichart and Logan Motorsports make sheet metal intakes that are pretty much the best pieces you can buy. No torque loss with huge power gains. The most powerful N/A mustangs on the road are running one of the 2. However, they are expensive and don't fit under a stock hood. They are monster pieces, built for monster machines. You dont' have to have a 11:1 compression 7k rpm stroker to take advantage of them, but they will definitely put your beast into a new level. I did a lot of research on this a while back. Figure out your price range and what your goals are. There is no point getting a Logan Intake if you never plan on doing more than putting in new cams and a 75 shot. You should just stay stock for that. But if it comes down to the difference of Bullit or Trick Flow vs. Reichart, thats a tougher call.
Aztec Gold 97GT. MM CC Plates, Panhard Bar, SFC's & Tower Brace Eibach Sway Bars H&R Race Springs/Bilstein Shocks MAC CAI, LT's, Catted H and Pro-Dumps KB Boost-a-Spark 04' PI Motor Author of The Official Suspension Guide |
#25 |
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
the reichard intake in a good intake, but not great n/a. the intake is a very short runner, but will hsine under boost. the p51 is not as great as they try to make it out to be either. the logan is a nice piece but also is $1600. the tfs hasnt had much review on it, but from the little i have heard isnt that impressive. the hps intake is a nice piece, but again, i havent heard enough feedback on it to convince me to go buy one yet.
#26 |
2004 mustang gt
+ 1 i hella forgot about thos lol wtf is wrong with me
![]() Ford racing shorty headers(came with car) Bassani o/r x pipe mac cat-back SCT xcal3 91 tune K&N drop in filter |
#27 |
When I do Hi Tech motorsport stage 2 cams Im lookin at the Trick Flow Heads and Manifold. Done all at once.
Im looking at redoing my motor next year. looking at getting a short block stroked and bored .20 Im staying N/A as well. Im looking at getting the most hp possible and safely while staying N/A. Was wondering, if you upgrade your Manifold, Cams, Heads. Could you run bigger injectors than stock and would be a power gain??? jw
B&M Short Shifter / Ford Heavy Duty Clutch / 3.73 gears / Nitto Drag Radials / Steeda CAI / Diablo Tuned / Mac LT Headers / Lethal Cated Xpipe / Pypes Exhaust / Smoked headlights and Tail lights / GT floor mats / PP 70mm TB / Accufab Plenum |
#28 |
Was curious anyone hear about the Victor Jr manifold???
Also I looked up the trick flow manifold. What is needed with it? I noticed you need to get a throttle body and a inake kit as well Im assuming. Is there any full kits? where it comes with everything needed?
#29 |
1999 Mustang GT
I have heard of the stock plastic intake manifolds cracking under pressure and was wondering how much they can take?
#30 |
2001 Mustang GT 5.8
the typhoon intake only gains 21hp with comp cams 270's and a 75mm throttle body + plenum. the intruction sheet actually says that. i got mine for a great price and my plastic one cracked.
![]() 351W c4 tranny AJE suspension slowly building |
#31 | ||
mm's nitrous mod
2000 mustang gt
they are still junk. if you look at the sheet, the power and torque curve is still less under 4k rpm's.
#32 |
ok Cause I know they sell 2 different victor jr manifolds. A Carb and a EFI.
Only problem I dont know anyone with that manifold with a dyno.
#33 |
i have a bullitt and switched it for a foxlake no regrets, it was a even trade with a buddy though
#34 |
1997 Mustang GT
Faster than an s4
THe Foxlake P-51 is a great intake, it just requires a few mods. The TFS intake does have a kit that you can buy it in from Trick Flow. Also, since most of our mustangs are expected to be boosted to get power, most intakes are designed with that in mind. That is why the best ones are expensive sheet metal pieces. They are all semi-custom pieces made by racing companies. The limited production just makes them expensive. With a N/A set up, you need to be pushing higher RPM's and definitely have some new bump sticks. With a totally built motor, any of the aftermarket parts will work great. They just tend to be minimal upgrades when you don't have the internals/cams/heads to make em flow.
As for your injectors, you will want to upgrade them, the stock 19lbs injectors are only rated to 300 hp. You should increase to 24lbs or more to support a fully built N/A car. Estimates are 450 hp with the new TF heads, Logan motorsports intake, stroked and poked 4.6 at 7k+ rpm. Big numbers, but you got to get the whole package to make it work.
Threads Similar to: Intake manifolds
| Intake manifolds | Imran | 99-04 | 6 | January 14th, 2009 12:36 PM |
| Intake manifolds? | DCstangGT | 99-04 | 20 | September 9th, 2007 02:47 PM |
| Intake Manifolds | 97_4.6L_Stang | Modular Mustangs | 14 | January 21st, 2007 02:23 PM |
| intake manifolds............ | ERIC | 99-04 | 1 | January 21st, 2007 11:54 AM |
| intake manifolds 94 GT | WVSNS& | 94-95 | 7 | August 31st, 2006 12:10 PM |
