2000 mustang gt turbo rebuild!
Old February 4th, 2009, 08:59 PM   #1
Killax15 is on a distinguished road
Hey guys i have a 2000 gt that im turbocharging either going to use a Precision t-76 or a master power t-70
my questions is the motor has roushly 111,000 miles on it now i know once i put the custom turbo set up on there i better start saving months down the line for either a new motor or rebuidling my motor, now with a budget of about 3k what would be my best possible options? oh hp wise i want like 500-550 is my goal , i already have clutch, tranny, fly wheel, fuel set up, to complete my set up..
Old February 4th, 2009, 09:30 PM   #2
Mustang GT
2000ZincGT will become famous soon enough
i would build the engine first
Stock.....
Old February 4th, 2009, 10:18 PM   #3
bottlefed02gt is on a distinguished road
With a budget of 3k you are probably going to have to build your own. Possibly buy the hotside, which there was one in the classified adds. Aftermarket K-member, tuner, injectors, etc. 3k is going to be tight.
Old February 4th, 2009, 10:27 PM   #4
ajm
Things were kinda mixed from the way I read them, You have 3k to spend on a turbo setup or an engine?
Old February 4th, 2009, 10:55 PM   #5
lol im sorry its 3k to spend on the motor the turbo stuff i already have im just worried about the engine now so im trying to figure out what are my best options for about 3k
Old February 4th, 2009, 11:26 PM   #6
yojoe600's Avatar
yojoe600 will become famous soon enough
u can buy a short block for around that price and be set... try livernoise or mmr
Originally Posted by supermachone View Post
it was something like the tinman from the wizard of oz pinching off a tight fart...
Cat Club Co-Founder
Old February 4th, 2009, 11:28 PM   #7
ajm
mmr shortblock or if you want more options and have the knowledge to do it yourself then id say do it yourself.
Old February 5th, 2009, 12:30 AM   #8
B0B
Boost gets you laid
B0B's Avatar
2001 Mustang GT
12.93@113.7 (on the 18's)
B0B is just really niceB0B is just really niceB0B is just really niceB0B is just really nice
Send a message via AIM to B0B
what kind of fuel setup do you have right now? what clutch?
500-550 will almost definitely blow up on the dyno with that kind of mileage on a stock motor. you can probably get away with 400 for a while until you can save up for a built motor, then crank the boost. a master power t-70 will be more than enough for your goals and i dunno if you've looked into pricing or not, but a mp t70 is less than half as much as a precision t-76. you need a tubular k member, and likely coilovers and tubular a arms if you want to do it RIGHT. you can route the piping with the stock k member but i will gaurantee you will end up redoing it because of ground clearance issues. you can buy a hotside from MMR for $1400, but you can build one or get one made for cheaper. you will need the turbo, intercooler, blowoff valve, blow through MAF, wastegate, all exhaust piping, v-band clamps, all intercooler piping, tuner, dyno tune, gauges, etc etc. it will add up fast and its pretty hard to put a set budget on something like this. i don't think its possible for under $3000
'01 GT. Just a couple Bolt-ons. 0rwhp 0rwtq. Epic Turbo build in progress
2003 Rubicon (wheelin rig)
2008 Silverado 4x4 (towin rig/road queen)
2009 KTM 450 XC-W (Brap Brap!)
Old February 5th, 2009, 12:31 AM   #9
B0B
Boost gets you laid
B0B's Avatar
2001 Mustang GT
oh yeah don't forget oil feed and return lines, tapping the oil pan, and any other misc hidden expenses
Old February 5th, 2009, 01:49 AM   #10
well i have about 110,00o miles on the motor and i have a spec stage 2 clutch, t56 tranny manifold and such the manifold i have i can use with the stock k member im just trying to weight my options out with what i can do with my motor with a budget of around 3k if i dont get forged internals then imma just have around 400hp but i know because of my high mileage my motor wont last for long even if my hp is around 400
Old March 12th, 2009, 10:10 AM   #11
Nateman15's Avatar
13.37@101.22
Nateman15 is on a distinguished road
look at the on3performance.com 2v kit. 2 grand for a complete T-70 kit. u just need to but k-member, injectors, fuel pump, MAF, and tune. i can't find anything better priced kit
Old March 12th, 2009, 10:23 AM   #12
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
if you want power, set the rest of the car up for it. you can make the power, but it means nothing when you cant use it.
Old March 12th, 2009, 11:20 AM   #13
G00SE is on a distinguished road
Old March 12th, 2009, 11:42 AM   #14
Schraders is on a distinguished road
I had roushly 130,XXX miles on my motor when I went turbo (MP T70). At 8 pounds it makes 400 rwhp/435rwt and it's a ton on fun on the street. I'm collecting parts to build a better lump but in the meantime it's still quick. The key is in the tune, if it runs out of fuel or has too much spark it'll be over in an instant.
I would be careful with the On3 kit, it's very cheap but the guy seems a little suspect and the materials they are using have a bad track record of cracking. Most of the kit comes from China. If you want to know more check out the forums at The Turbo Forums.com.
www.schradersspeedandstyle.com
Old March 12th, 2009, 11:43 AM   #15
The Doctor
Lefty's Avatar
'01 Cobra Vert.
iTrader: 11 reviews
+ a bazillion
Old March 12th, 2009, 11:47 AM   #16
ponygrrl's Avatar
2003 Mustang GT
ponygrrl has a spectacular aura aboutponygrrl has a spectacular aura about
Send a message via AIM to ponygrrl
I don't know if it's because my comprehension sucks this morning but I'm still confused in this post...
Ok, you have all the turbo components, a good tranny and a clutch. Someone mentioned fuel... do you have any fuel components? Suspension (kmember, etc)?
You say you have $3k for the engine. That's a good amount to work with. For 500-550hp you can get a good shortblock for $3k. Like mentioned, check with Livernois or MMR. Where are you located? There may even be a local engine builder who can take care of you and build a customer block to your application within your budget. Show around on forums, even, for takeout shortblocks and even heads and cams then just have a machine shop go through them. Good thing about 2Vs is the classified market is great for them since everyone is moving on up.
Good luck and keep us posted on the build.
03 GT|boss330 forged shortblock|steen racing stage 3 heads|vt stage 2 blower cams|i/h/e|detriot trutrac|moser 31 splines|125 shot
May it R.I.P.
New whip: 1953 Ford Mainline Coupe... let the games begin!
Old March 12th, 2009, 02:43 PM   #17
lilmarc1988's Avatar
2001 mustang gt
lilmarc1988 will become famous soon enough
Send a message via AIM to lilmarc1988 Send a message via Yahoo to lilmarc1988
turbo gets me wet
Old March 12th, 2009, 03:51 PM   #18
Black Bullitt's Avatar
2001 Mustang Bullitt
Faster than Twinmill
Black Bullitt is just really niceBlack Bullitt is just really niceBlack Bullitt is just really niceBlack Bullitt is just really nice
Send a message via AIM to Black Bullitt
4.6L Short Block Kit
Sean Hyland Motorsport - 1996-04 Ford Mustang GT and Cobra 2V and 4V Forged Rotating Assemblies
Build it yourself.
2001 Bullitt #5069
505rwhp/538rwtq @ 15#s
Originally Posted by FluffyTheRhino View Post
Nothing says "Upgrade EVERYTHING" like busted parts
Old March 12th, 2009, 06:29 PM   #19
WHOOP!
AggieStang's Avatar
7.44@95 (1/8)
AggieStang is just really niceAggieStang is just really niceAggieStang is just really niceAggieStang is just really niceAggieStang is just really nice
500hp= mucho denero.
Buy my:
Nitrous Accessories
Diablosport Programmer
In The Classifieds
Old March 12th, 2009, 06:47 PM   #20
moosenuk17's Avatar
2000 ford mustang GT
moosenuk17 is a jewel in the roughmoosenuk17 is a jewel in the roughmoosenuk17 is a jewel in the rough
Send a message via AIM to moosenuk17 Send a message via MSN to moosenuk17 Send a message via Yahoo to moosenuk17
500hp=muy explosivo without forged internals
2000 kenne bell GT (440HP-432TQ)
Tuned by Joe at http://www.tricktuners.com
dyno vid:http://youtu.be/lr3xpxw2_v8
2011 escape
MUSTANG TAT CREW
Threads Similar to: 2000 mustang gt turbo rebuild!
2.3 turbo engine rebuild kit newbiemustang 2.3 Mustangs 4 September 18th, 2008 11:12 AM
Turbo rebuild???? oms4life General Tech 1 March 23rd, 2007 12:52 AM
Im Installing This Turbo In My 2000 V6 Take A Look Brianzeke007 V6 Mustangs 28 November 15th, 2006 01:59 AM
turbo rebuild beheivjer V6 Mustangs 3 March 14th, 2006 09:32 PM
