Diff Is leaking
Ok so i took it to a shop to install my 3.73s and well its been a while since then and now my diff started leaking from the middle and ive taken the diff cap off and replaced the oil and reput sealant and it worked for two days and now its leaking again should I just order the damn gasket or do u think its gunna leak again?
04 GT <11.8@114mph>
2011 Mustang GT
12.1 @ 116
Take the cover off. Go to a flat work bench and take a hammer to it. Flatten the metal back out with a hammer. Clean it up. Put new RTV gasket maker on it. Tighten it down in a star pattern to equilize the pressure.
Mods in garage. Built suspension and gears since posted times. |
48.47@ 12.58
how did you tighten it down? just slapped on the rtv and tightened it? You are supposed to hand tighten the bolts then wait for a few until the rtv gets tacky before you tq down the bolts.
I pt the sealant and put the cap back on tightined it hand tight n then waited 2hours of drying time then i tightined it as much as i could and poored in the oil and it worked perfectly fine for two days
04 GT <11.8@114mph>
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 4 reviews
Take the pan off and lay it on a glass table, granite counter top etc something you know is going to be dead flat. If it isnt flat try your best to flatten it out using a hammer. Clean the pan and housing with lacquer thinner, also be sure to clean out the inside of the housing with carb cleaner etc so fluid isnt trying to run out of the bottom onto your non cured rtv, clean the housing where the pan-housing mate with some lacquer thinner. Apply some black rtv and install according to specs (criss coss pattern, hand tight,let sit for a bit, then criss cross pattern at 33ft lbs)
Threads Similar to: Diff Is leaking
| 2 diff dynos 2 totally diff readings | 03snakeminated | 4V / SVT | 45 | December 4th, 2008 03:52 PM |
| need help with diff.... | 88stangGT | 5.0 Mustangs | 3 | May 16th, 2008 12:38 AM |
| ET diff with 4.10 vs 3.73 | njstang | 99-04 | 8 | May 6th, 2008 03:29 PM |
| Leaking | vnmous | 99-04 | 4 | August 13th, 2007 12:49 PM |
| How much diff will it get you? | scxc15 | V6 Mustangs | 8 | May 20th, 2007 02:38 AM |
