whats needed for cobra hat and dual pump install?
LinkBack (1) Thread Tools
Old February 5th, 2009, 08:44 PM   1 links from elsewhere to this Post. Click to view. #1
BakerFX4's Avatar
BakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud of
iTrader: 14 reviews
what else would i have to do to put the cobra pumps and hat in my gt tank and have it going?
4.75 MMR 900se
Livernois ported heads
HP 292s blower cams
Procharger D1sc at 20+ psi
IW 15% OD pulley
(and more bolt ons)
E85
Tune/numbers coming shortly!!
Old February 5th, 2009, 08:46 PM   #2
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
into a gt tank?
Old February 5th, 2009, 08:47 PM   #3
BakerFX4's Avatar
iTrader: 14 reviews
yeah....
My boy sweet with the quick response!
4.75 MMR 900se
HP 292s blower cams
IW 15% OD pulley
(and more bolt ons)
E85
Old February 5th, 2009, 08:50 PM   #4
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
the plastic holder for the basket will have to be removed, and the it should eb a direct swap if i remember right.
Old February 5th, 2009, 08:52 PM   #5
BakerFX4's Avatar
iTrader: 14 reviews
no module problems?
4.75 MMR 900se
HP 292s blower cams
IW 15% OD pulley
(and more bolt ons)
E85
Old February 5th, 2009, 08:52 PM   #6
BakerFX4's Avatar
iTrader: 14 reviews
Can i use my stock fuel sending unit with it?
4.75 MMR 900se
HP 292s blower cams
IW 15% OD pulley
(and more bolt ons)
E85
Old February 5th, 2009, 08:54 PM   #7
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
the hat should have its own sending unit. the stock cobra pumps run off the same fpdm as a gt. if you upgrade pumps, you will have to upgrade fpdm as well.
Old February 5th, 2009, 08:54 PM   #8
BakerFX4's Avatar
iTrader: 14 reviews
I keep seeing fpdm... what is this? The sending unit is missing unfortunately.
4.75 MMR 900se
HP 292s blower cams
IW 15% OD pulley
(and more bolt ons)
E85
Old February 5th, 2009, 08:55 PM   #9
BakerFX4's Avatar
iTrader: 14 reviews
sweet2kstang.... im bout to pm you with the deal.
4.75 MMR 900se
HP 292s blower cams
IW 15% OD pulley
(and more bolt ons)
E85
Old February 5th, 2009, 08:56 PM   #10
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
fuel pump delivery module
i havent looked tnot trying to swap sending units. i will have to do some looking in the morining when i get home.
Old February 5th, 2009, 08:58 PM   #11
BakerFX4's Avatar
iTrader: 14 reviews
where is this module at?
4.75 MMR 900se
HP 292s blower cams
IW 15% OD pulley
(and more bolt ons)
E85
Old February 5th, 2009, 08:59 PM   #12
BakerFX4's Avatar
iTrader: 14 reviews
GT as in GT supercar fuel pump or mustang gt?
4.75 MMR 900se
HP 292s blower cams
IW 15% OD pulley
(and more bolt ons)
E85
Old February 5th, 2009, 09:04 PM   #13
jivepepper's Avatar
jivepepper is just really nicejivepepper is just really nicejivepepper is just really nicejivepepper is just really nice
In the trunk under the left panel. Most people also build a baffle around the pumps like the cobra tank has to insure there's always fuel around them.
665/541 WHP/WTQ 4.6L SOHC 2V ON 93 OCTANE PUMP GAS.
NO METH INJ., NO E85, NO RACE GAS, N2O BABY BOTTLES!
TRAP=POWER: 11.01 @135, IN SUMMER HEAT, 1350' TRACK, 315/35/17 DR'S
Old February 5th, 2009, 09:06 PM   #14
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
the stock mustang gt fpdm will hold 2 stock cobra pumps.
Old February 5th, 2009, 09:06 PM   #15
jivepepper's Avatar
The mustang gt and cobra use the same fpdm. If you every upgrade the cobra pumps then you need to upgrade to a modifed FPDM.
Old February 5th, 2009, 09:09 PM   #16
BakerFX4's Avatar
iTrader: 14 reviews
Where do i get this from? If they use the same one then why do i need another one?
4.75 MMR 900se
HP 292s blower cams
IW 15% OD pulley
(and more bolt ons)
E85
Old February 5th, 2009, 09:10 PM   #17
BakerFX4's Avatar
iTrader: 14 reviews
is the fpdm the thing with the red button on it?
4.75 MMR 900se
HP 292s blower cams
IW 15% OD pulley
(and more bolt ons)
E85
Old February 5th, 2009, 09:16 PM   #18
BakerFX4's Avatar
iTrader: 14 reviews
Your making me wanna just stick with the gt pump, wiring upgrade, and BAP. Bro if you give me a write up on how to hook the BAP up with the Supercar pump with the wiring upgrade, ill put 10 bucks in your paypal. But i go to the tuner for the cam install and all on the 22nd. Appt. is on the 23rd. so im just trying to get all this done ASAP ya know. Sorry if im buggin!
4.75 MMR 900se
HP 292s blower cams
IW 15% OD pulley
(and more bolt ons)
E85
Old February 5th, 2009, 09:20 PM   #19
jivepepper's Avatar
No that's the fuel cut off switch. The fpdm can't be seen unless you remove some panels.
Old February 5th, 2009, 09:23 PM   #20
BakerFX4's Avatar
iTrader: 14 reviews
oh... lol
4.75 MMR 900se
HP 292s blower cams
IW 15% OD pulley
(and more bolt ons)
E85
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/108984-whats-needed-cobra-hat-dual-pump-install.html
For Sale Stock 03/04 Cobra Fuel parts - Ford Mustang Forums : Corral.net Mustang Forum This thread Pingback July 13th, 2011 10:04 AM
Threads Similar to: whats needed for cobra hat and dual pump install?
Fore Precision 03-04 Cobra Triple Hat In Stock Derek@DRI 99-04 0 June 3rd, 2008 05:55 PM
Fore Precision Walbro Fuel Pump Hat! Derek@DRI 99-04 0 May 28th, 2008 11:29 AM
