Forged internals?
Old February 8th, 2009, 10:59 AM   #1
BlackedOut04GT's Avatar
14.21@97.93 2.107 60' (Best pass. So far.)
BlackedOut04GT has a spectacular aura aboutBlackedOut04GT has a spectacular aura about
Send a message via AIM to BlackedOut04GT
Forged internals?
So I am toying with the idea of doing forged internals for my 04 GT. I want to get a good setup but with out spending both arms, legs, and a seed maker. I want something that is not the cheapest but also not the most expensive too. I'd like to rebuild my stock block with forged pistons, rods, crank and what ever else I would need. I know, I know I will have to do the top end as well, but I have a good idea about what I want to do for that. It's just the block this has me thinking. An good ideas?
Old February 8th, 2009, 11:06 AM   #2
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
how much power, whats intended use of car, etc. we need more info
Old February 8th, 2009, 03:13 PM   #3
Daily driver/drag and track racer. Thinking around 450-to 520ish at the wheels, but I would want it to be able to handle 700-750hp. Just in case I want to add a turbo,blower,or spray to it later.
Old February 8th, 2009, 03:16 PM   #4
Moderator
casper gt's Avatar
2010 mustang gt auto
casper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud of
thats big power bro, be prepaired to spend big $$ to do it.
MM BRACKET RACING CREW CO-FOUNDER
BAMA Performance Drag Team Founder
2010 GT auto
Old February 8th, 2009, 03:19 PM   #5
BYAHHHH!
Scott2001GT's Avatar
2001 Mustang GT
13.874
I am doing Livernois. going for 600 to 700RWHP stock block with internals but ya they are right ALOT OF MONEY
Old February 8th, 2009, 03:21 PM   #6
Yea I know. But I should be getting a good raise at work and getting my taxes back soon, just trying to get an idea whats out there. I can build the block my self next winter. Just looking to get most of the stuff i will need.
Old February 8th, 2009, 03:23 PM   #7
BYAHHHH!
2001 Mustang GT
13.874
I think your block may need to be re-honed?
Old February 8th, 2009, 03:24 PM   #8
But the way I see it. If your going to build a good motor, you need a great base.
Old February 8th, 2009, 03:26 PM   #9
Yea the block would have to be cleaned and all. I just want to try and keep it the same size and not have to bore it over.
Old February 8th, 2009, 03:38 PM   #10
BYAHHHH!
2001 Mustang GT
13.874
ya man I am doing the same things. I am going to do the Livernois 298ci stroker kit and a Kenneb bell 2.6L or 2.8H. don't forget tranny and re-end
Old February 8th, 2009, 04:08 PM   #11
Yea I have been looking at a TKO600 trans and maybe 31 or 32 spline axles, LSD, and the 4.10 gears I have. Staying with the 8.8 rearend.
Old February 8th, 2009, 06:10 PM   #12
BYAHHHH!
2001 Mustang GT
13.874
TTC: TREMEC Transmissions
other options ^^^
ya the slpine will have to be updated for sure. good rear-ends
Old February 8th, 2009, 09:06 PM   #13
Nossit's Avatar
1999 Mustang GT
8.65@72.5mph 1/8th
Nossit will become famous soon enough
Send a message via AIM to Nossit
I say boost the crap out of it to about 400 hp without forged internals. Thats right around where you can be with stock insides but at 400 hp you can have fun now and when you do build it, up the boost.
You're going to have a hard time hooking up with 400 hp so after I boosted it, I'd build the rear. Then I would try to up the hp.
This is kind of an impatient way to have fun but thats what I'd do.
1999 Mustang GT - K&N drop in, Mac Prochamber, Mac CB, 555r's, 31 spline Strange axles, and 4.10's
Old February 8th, 2009, 09:18 PM   #14
UnixHH's Avatar
2003 Saleen S281
UnixHH is a glorious beacon of lightUnixHH is a glorious beacon of lightUnixHH is a glorious beacon of lightUnixHH is a glorious beacon of lightUnixHH is a glorious beacon of light
Send a message via Yahoo to UnixHH
call houston performance (281-893-6080) ask for chris! this guy knows his shit and will point you in the right direction. ive spent about $15,000 with these guys and haven't had one problem.
480RWHP 450RWTQ 15psi @ 15* on 91 octane
Old February 8th, 2009, 09:56 PM   #15
there is a ford racing dealer not to far from me. I just think that there is a less expensive way of getting of getting the same kind of power and strength from my motor. Is it possible to build a motor with forged internals without have to bore the block? Everything i have found or been told means boring the block out a min of .30 over.
Old February 8th, 2009, 09:57 PM   #16
ajm
Yes its possible. What youre reading might be referring to using a used block? In which case you would want to bore it.
Old February 8th, 2009, 10:37 PM   #17
07 gt
chefalan23 will become famous soon enoughchefalan23 will become famous soon enough
i know a guy thats selling a forged shortblock for 2 grand with:
Brand new FRPP 4.6L Romeo Block (Torque plate finish honed)
ARP Main Studs
Diamond 19cc Pistons (2V Valve Reliefs)
Modmax H Beam Rods (ARP 2000 rod bolts)
Federal Mogul HP Series Main/Rod Bearings
6 bolt B series Cast Crank
As mentioned above, all parts are fully machined and balanced and ready for assembly. This shortblock will withstand 600+rwhp.
07 GT 5spd Black on Black
BBK Equal Length Shorties
4.10s
FRPP K springs
JLT with canned tune
Pypes O/R H
Pype Bomb axleback
Steeda UDP
Old February 9th, 2009, 05:25 PM   #18
WHOOP!
AggieStang's Avatar
7.44@95 (1/8)
AggieStang is just really niceAggieStang is just really niceAggieStang is just really niceAggieStang is just really niceAggieStang is just really nice
I just spent 8k to rebuild my engine. Be prepaired to lay down some cash...
Buy my:
Nitrous Accessories
Diablosport Programmer
In The Classifieds
Old February 9th, 2009, 08:43 PM   #19
wishIhada5.0's Avatar
2002 GT, True Blue, Stick
wishIhada5.0 is a jewel in the roughwishIhada5.0 is a jewel in the roughwishIhada5.0 is a jewel in the rough
Send a message via AIM to wishIhada5.0
SHM seems to have good luck with Manley internals......
True blue crew founder/member #1
378/442 rwhp/rwtq*on a Mustang dyno * looking for block busting power...cms stage 3 blower cams on the horizon..[/
Old February 11th, 2009, 05:37 PM   #20
Yea it would most likely take me a year if not 2 years to build the motor I want. I just want to make sure the car gets paid off first.
Threads Similar to: Forged internals?
forged internals AnFking6908 V6 Mustangs 23 May 2nd, 2008 08:22 PM
Forged internals? energiesource 99-04 27 May 14th, 2007 02:50 PM
Going to forged internals...what to get? ltsmash1200 99-04 7 April 23rd, 2007 12:08 AM
forged internals FastBack71 5.0 Mustangs 6 January 17th, 2007 08:58 PM
Forged Internals Rolis V6 Mustangs 7 December 5th, 2006 12:15 AM
