Valve Spring Kit??
Old February 10th, 2009, 07:42 PM   #1
BoostHard1210's Avatar
13.000
BoostHard1210 is on a distinguished road
Question
Valve Spring Kit??
hey guys i bought a set of patiot Valve Spring Kit and if i installed them with my stock cams will the hurt anything?
Abe
Old February 10th, 2009, 08:09 PM   #2
ajm
You should be ok, im running the patriot springs and like them quite a bit. Any particular reason why you just plan on upgrading the springs,retainers,and locks and not the cams?
Old February 10th, 2009, 08:27 PM   #3
NeverEnuff's Avatar
1989 LX Coupe
7.1@99mph
NeverEnuff has a spectacular aura aboutNeverEnuff has a spectacular aura about
Originally Posted by PAzYearazzUP View Post
Yeah. It might flatten the cam with the extra load the springs make. You lose HP being it has to fight that extra spring pressure. Did you load and shim them all even pressure across the head?
Um. NO....that is one of the dumbest things I have ever heard. Flattening the cam lobe cause of added spring pressure. OMG. wow.
Put the springs in...you will be fine...FOREVER.
Old February 10th, 2009, 10:16 PM   #4
13.000
because i bought a stroker kit and was going to buy cams untill clearance issues came up and dont really want to hassle (custom grind)And kinda low on cash. plus already boughst the spring kit
Abe
Old February 10th, 2009, 10:36 PM   #5
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
97S281 is a name known to all97S281 is a name known to all97S281 is a name known to all97S281 is a name known to all97S281 is a name known to all97S281 is a name known to all
iTrader: 13 reviews
whitefang jr. is spelled pazyearazzup.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old February 10th, 2009, 10:44 PM   #6
NeverEnuff's Avatar
1989 LX Coupe
7.1@99mph
What cams did you get or do you want?
Old February 10th, 2009, 10:57 PM   #7
ajm
That sucks, but yea youll be fine with your kit. I was just curious why you wanted to upgrade but not drop cams in. Best of luck to you.
Old February 10th, 2009, 11:26 PM   #8
13.000
270ah
Abe
Old February 11th, 2009, 12:51 AM   #9
13.000
does anyone know if 262 will work???
Abe
Old February 11th, 2009, 08:31 AM   #10
ajm
yes the 262's would work
Old February 12th, 2009, 12:57 AM   #11
13.000
how dose the idle sound i want something with a lop
Abe
Old February 12th, 2009, 10:19 AM   #12
NeverEnuff's Avatar
1989 LX Coupe
7.1@99mph
The 270s will work. Had them in my 99 GT when it was 2V...and then put them in a bone stock 04 GT. They will work. Just have to take your time and degree them in.
Threads Similar to: Valve Spring Kit??
valve spring upgrade? V6Power 99-04 3 December 7th, 2008 05:11 PM
Valve Spring Troublee! tehdwarvenn 5.0 Mustangs 12 September 12th, 2008 08:20 AM
Valve spring cups hooligan 2.3 Mustangs 0 March 31st, 2008 12:57 PM
Valve Spring removal acmillr 99-04 0 January 7th, 2007 10:53 AM
