Wierd noise...help plz if you can
It almost sounds like a bird chriping noise. It chirps like once ever second while ideling but speeds up with rpms increase. Its hard to tell where it is coming from. It could be under the hood or possibly the tranny, god knows.
I am also trying to assosiate it with another noise the dealership never was able to figure out. It sounds like the same pitch as the pulse chirp as stated above but it is different and only occurs at 2800ish rpms and it is a very rapid chirp and lasts to about 3k rpms but its just a real rapid bursting chirp noise then it quits. I am trying to desirn if they both are coming from the same location and or are the same issue, or if they are two intirely different problems. Reguardless i dunno what or where they are coming from and if anybody can shine some light on this i would be greatful. |
sounds like a belt or pulley i have the same problem i just spray some stop sqeek on it every now and then. you could try that and see if that works
Sounds like the belt. With the engine stone cold, take the belt off and crank it up. You can run it briefly without it, long enough to see if that is the problem.
If it were the belt would it be a tension issue or is it just the belt is possibly needing replacement?
It's probably just the belt. I'm not sure about Ford's (this is my first one) but on a Chevy the idler pulley will develop a squeak eventually. If it's a tension issue, the belt tensioner will jump around a little at idle when it's worn.
maby you got a civic stuck in your intake?
#7 | |
#8 | ||
i heard WD40 isnt good for the belt something about taking off the protective layer on the belt i am not sure of this though soo dont hold me to it
well if it was the belt and i wanted to lube it up a little more to take away the chrip noise, water would work fine but only for a very short time, i guess i'll try it. But i've also noticed it doesn't happen all the time. But also i wouldn't doubt it being the belt i bought it 6k miles ago and it may be time for a change approaching 30k miles.
ya ha ha.make sure its not the belt. i had the same issue once and it turned out to be that the serpentine belt was frayed. lol it broke on the way to autozone.
Official MM Zeppelineers. Crew member #3
If it is the belt, don't get a Gates or whatever the cheap ones are at the Zone's or Advanced - go to Napa and get the best one they have. Those cheap ones do not last long at all.
#12 | |||
#13 | ||||
Belt dressing. No matter what you use, it's temporarily covering the noise. Buy a new quality belt from Napa. I don't know if it's true or horseshit, but a mechanic once told me anything used as belt dressing might quiet the noise a little while but accelerated the wear. Good belts are way too cheap, and painfully cruicial to mess around with. ALWAYS use the best belt you can buy. |
Yea definitely go with a new belt I just meant to temporaraly quiet the noise that was what we did.
I wanna go fast... I wanna go fast... I'm goin' fast!!!!! |
i went cheap at autozone. its lasted me 6k miles so far. lol
DO NOT use wd-40. That is a lube and your belt works by using friction. If you must get by with something belt dressing is less than 3 bucks and will give you a pretty good answer. A stethoscope(like what a doctor uses) is a great way to check for noises like that. Pull off the contact pad and but a short piece of brake line or something in the end. It works fantastic. And like someone else said, replacing a belt is a cheap way to save you a ton of money.
Threads Similar to: Wierd noise...help plz if you can
| wierd from noise | noppe180 | 96-98 | 5 | October 28th, 2007 02:26 AM |
| Wierd Noise..please help | tmab11 | V6 Mustangs | 1 | October 14th, 2007 06:48 PM |
| wierd grinding noise | G.T. Rags | 96-98 | 45 | September 14th, 2007 11:39 PM |
| wierd clunking noise from right rear | notoriousmvd | 5.0 Mustangs | 8 | July 5th, 2007 03:09 AM |
| wierd noise suggestions? | 02NEBstang | 99-04 | 2 | December 22nd, 2006 08:29 PM |
