HP gain with long tube headers? - Forums at Modded Mustangs
Closed Thread
post #1 of 40 Old February 13th, 2009, 12:45 PM Thread Starter
I have a 2004 Mustang GT with 5-speed. Mods include 3.73s, BBK CAI, 70mm throttle body, BBK upper plenum, Comp 262AH cams, SLP x-pipe with cats, Flowmasters, dyno-tuned.
Currently making 299rwtq at 4200 rpm and 265rwhp at 4900 rpm.
How much of a gain will I see by installing the SLP long-tube headers with this setup? The SLPs mid-pipe is modular making it possible to add the long tubes without tossing the mid-pipe.
saxmanJJ is offline
post #2 of 40 Old February 13th, 2009, 12:47 PM
MM's Orangest
Mach Boy's Avatar
I'm not familiar with a modular setup. You will see somewhere between 5-10rwhp with longtubes and even more if you get a O/R midpipe.
Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector)
Mach Boy is offline
post #3 of 40 Old February 13th, 2009, 12:51 PM Thread Starter
The SLP mid-pipe comes with part of the pipe that can be taken out, so that the catted-section can be mated to the long-tubes.
saxmanJJ is offline
post #4 of 40 Old February 13th, 2009, 12:51 PM Thread Starter
Remember, I have cams so I thought that the engine could better take advantage of the long tubes?
saxmanJJ is offline
post #5 of 40 Old February 13th, 2009, 12:54 PM
MM's Orangest
Mach Boy's Avatar
It might make a little more power than a non-cammed engine but you're not going to get a 20rwhp gain or anything like that. I'd think right around 10rwhp would be about right.
Mach Boy is offline
post #6 of 40 Old February 13th, 2009, 12:56 PM
Black Bullitt's Avatar
Send a message via AIM to Black Bullitt
But if you had a blower...
2001 Bullitt #5069
505rwhp/538rwtq @ 15#s
Originally Posted by FluffyTheRhino View Post
Nothing says "Upgrade EVERYTHING" like busted parts
Black Bullitt is offline
post #7 of 40 Old February 13th, 2009, 12:57 PM Thread Starter
I'm not going to spend over $1000 to pick up 5 or 10rwhp!
saxmanJJ is offline
post #8 of 40 Old February 13th, 2009, 01:00 PM
If you plan on going FI it's worth it. SLP is nice and expensive. Check out MAC or BBK. I've had BBK before and it worked just fine. I'm going MAC this time around.
2001 Bullitt #5069
post #9 of 40 Old February 13th, 2009, 01:00 PM
MM's Orangest
Mach Boy's Avatar
If you had a blower that changes everything. Blowers get more power with the more mods you have.
Mach Boy is offline
post #10 of 40 Old February 13th, 2009, 01:20 PM
US Air Force (retired)
Eagle2000GT's Avatar
Long-tubes do not add a lot of horsepower according to before and after dyno runs. And, most of the gains that are seen are most likely the result of the off-road mid-pipe. Its the one mod that I've done where I think the money would have been better spent elsewhere.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370.
USAF 1969-1996: Vietnam veteran. Aircraft maintenance. ICBM Operations. Research & Development.
Also own: 1997 Harley FXDWG, 1998 F-150, and 2002 Corvette LS1
Eagle2000GT is offline
post #11 of 40 Old February 13th, 2009, 01:29 PM
BakerFX4's Avatar
iTrader: 15 reviews
if you are n/a. I think they help alot out with airflow if you are blown with a good midpipe and all.
4.75 MMR 900se
Livernois ported heads
HP 292s blower cams
Procharger D1sc at 20+ psi
IW 15% OD pulley
(and more bolt ons)
E85
Tune/numbers coming shortly!!
BakerFX4 is offline
post #12 of 40 Old February 13th, 2009, 01:42 PM
I Poop Entirely Way Too Much
Headers dont really give gains, 10 maybe 20 hp if your lucky. The added pressure forces the air out of the stock manifold and it being so short, about 14 inches for the longest run the negative affects are minimal. Add in the fact that they can be a real hassle for work lata on and they arent worth it to me.
Nothing says "were dating" like sticking your dick in her.
03_StangGuy is offline
post #13 of 40 Old February 13th, 2009, 01:49 PM
Lefty's Avatar
iTrader: 17 reviews
IMO you only feel LT more at the top end and gain HP up there. Doesn't help w/ Low end at all...
Lefty is offline
post #14 of 40 Old February 13th, 2009, 01:55 PM
Moderator
03SonicBoom's Avatar
This might very well be my uneducated opinion but, does 265rwhp on a cammed engine seem low to anyone else?
03SonicBoom is offline
post #15 of 40 Old February 13th, 2009, 02:00 PM
!FACEPLATED!
F8L GT's Avatar
iTrader: 13 reviews
I agree 03sonic, with just cai, udps, off road x and flowmasters I was at 256rwhp and 299 rwtq. I would think that cams and his mods would be more than that.
Teksid short block, Ported 2v heads, Custom ground cams, Edelbrock Vic Jr intake, Brandon Alsept tuned
F8L GT is offline
post #16 of 40 Old February 13th, 2009, 02:02 PM
The UPS guy
MikeD05GT's Avatar
Send a message via AIM to MikeD05GT
my bassani has the modular legs for it... id bet you'll see 10-15 rwhp..thats not outa the question at all...
MikeD05GT is offline
post #17 of 40 Old February 13th, 2009, 02:07 PM
LT's really woke my kb stang up. Don't have before and after numbers though, since i have been doing tunes with tricktuners.
2000 Black convertible GT: KB 18psi, and other goodies...
2006 Nissan Titan: Tow package, 4 inch lift. (The DD)
RyanGT is offline
post #18 of 40 Old February 13th, 2009, 02:23 PM
MM's Orangest
Mach Boy's Avatar
He's losing some power not having an O/R midpipe. But cams on our cars don't do as much as what they do for the pushrods.
Mach Boy is offline
post #19 of 40 Old February 13th, 2009, 02:26 PM
On a stock bottom end where you can't push more boost I'm sure the gains will be minimal on a blown application, but with a built block and LTs with lots of boost you'd come out on top.
2001 Bullitt #5069
post #20 of 40 Old February 13th, 2009, 02:32 PM
RALVAREZ26's Avatar
man, who's selling you those longtubes, are they made out of gold or something? i picked mine up for $200!
http://smokinperformance.com
1997 P.I. swapped GT
RALVAREZ26 is offline
Closed Thread
Human Verification
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/110245-hp-gain-long-tube-headers.html
Good Job, Nutwaver - Page 2 This thread Refback July 16th, 2012 07:47 PM
What about long tube headers? | ChaCha Answers This thread Refback December 8th, 2010 04:29 PM
