Camshaft
Old February 17th, 2009, 02:31 PM   #1
S IHI II IB IB Y is on a distinguished road
Send a message via AIM to S IHI II IB IB Y
Camshaft
I have an '02 supercharged GT running on about 7psi and I'd like to put in a performance camshaft. There's an aluminum flywheel on it now (I'm sure that makes somewhat of a difference). I really don't know much of anything about cs's so I'm wondering how I should go about doing this. I want a little boost in performance and of course the amazing sound that a cs produces, but I don't want anything so gnarly that It's difficult to start and idle in somewhat colder weather. Any help/suggestions are appreciated.
Old February 17th, 2009, 02:37 PM   #2
BlckBullitt01's Avatar
TT Bullitt
BlckBullitt01 is on a distinguished road
Your probably going to want a cam that will allow you to use the stock springs.
If you have to replace the springs well, thats more money, then you might as well go ahead and replace the heads, etc..
I'd say talk to whoever tuned your car and see what they say. If your looking to do on a budget, I believe comp cams has several cams for S/C mustangs.
Edit: Flywheel should have nothing to do with cams.
Old February 17th, 2009, 03:06 PM   #3
Black Bullitt's Avatar
2001 Mustang Bullitt
Faster than Twinmill
Black Bullitt is just really niceBlack Bullitt is just really niceBlack Bullitt is just really niceBlack Bullitt is just really nice
Send a message via AIM to Black Bullitt
If your going to spend the money I'd go with CMS stage 2 blower cams. They sound nice, make good power on unported heads, but the downside is I believe you need new springs.
2001 Bullitt #5069
505rwhp/538rwtq @ 15#s
Originally Posted by FluffyTheRhino View Post
Nothing says "Upgrade EVERYTHING" like busted parts
Old February 17th, 2009, 03:11 PM   #4
Eagle2000GT's Avatar
12.73@111.36
Eagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to behold
Supercharger cams do not give have that engine lope sound associated with naturally aspirated high performance cams. That lope is caused by the overlap where both the exhaust valve and intake valve are open at the same time. Running that type of cam with a supercharger allows the boost to escape out the exhaust.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370
Mods list in Garage.
Old February 17th, 2009, 03:14 PM   #5
That is true, but it does have a slight cammed sound which is very noticeable over stock cams just not as noticeable as a NA cam. If I wasn't at work I would post a youtube video. You can do a search with this: mustang VT stage 2 blower cams and it will be one of those videos.
2001 Bullitt #5069
Old February 17th, 2009, 03:45 PM   #6
Sweet35th is on a distinguished road
Where in MN are you? Hitech Motorsport is in Elk River. Check out the website if you want (Hitech Motorsport - Performance EFI Tuning / EFI Dyno Tuning Experts - Elk River, Minnesota - Midwest Region) . They have several custom cam specs for blower aps. depending on exactly what you are after. If you want to come on in, I can show you some dyno graphs of before and after.
Old February 17th, 2009, 04:44 PM   #7
I'm actually in Brooklyn Center so yea that may be an option that I'll take advantage of at some point. when I take it out of storage for spring I'll come and check out what Hitech has, I also was referred to a place called DB performance a little further north I believe. Thanks man I'll stop in.
Old February 17th, 2009, 05:50 PM   #8
I'm also wondering what the ball park range would be for a new cam. For you guys that have done this work before what would I be looking at for like minimum just putting in a new shaft and not changing springs or anything and also what would it be to just take it and run with it, go all out with camshaft and supporting mods for it?
Old February 17th, 2009, 06:51 PM   #9
ajm
Not going against what you said but one way or the other springs are always a good choice.
Old February 17th, 2009, 06:52 PM   #10
ajm
Price of whichever cams you want (usually about 5-600), some other stuff if you have a windsor vs a romeo (100 max), and then its not a bad idea to replace the front cover and valve cover gaskets while youre in there which is only about another 50 total, and if youre only doing cams and no springs, get the afm cam tool (30) and youll have those things in there in no time at all (2 hours tops) minus degreeing.
Old February 17th, 2009, 07:49 PM   #11
limited's Avatar
99 limited edition vert
limited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of light
cam choice also depends on the rpm range you want the most power. power range for stage 2's are lower than stage 3's. I Run stage 3's and find the driveability is real good,but if you have a centri you will have a loss of midrange so I would go with stage 2's (or cms 2.5) or mph custom. You should always change your springs when adding performance cams. do it right the first time
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1M
Tuned by Joe at http://www.tricktuners.com
Old February 17th, 2009, 08:09 PM   #12
ajm
omg ftmfw +11054511000
Old February 17th, 2009, 09:02 PM   #13
UnixHH's Avatar
2003 Saleen S281
UnixHH is a glorious beacon of lightUnixHH is a glorious beacon of lightUnixHH is a glorious beacon of lightUnixHH is a glorious beacon of lightUnixHH is a glorious beacon of light
Send a message via Yahoo to UnixHH
^^^^^^^^^^^blower cams...
480RWHP 450RWTQ 15psi @ 15* on 91 octane
Old February 17th, 2009, 09:03 PM   #14
BakerFX4's Avatar
BakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud of
iTrader: 14 reviews
ill have these after monday^
Old February 17th, 2009, 09:03 PM   #15
UnixHH's Avatar
2003 Saleen S281
sounds like its loping to me..
Old February 17th, 2009, 09:06 PM   #16
BakerFX4's Avatar
iTrader: 14 reviews
hell yeah it is... Loping real hard.... I cant wait till mine is chopping like that! Hey unix, u got long tubes? and what midpipe you got?
Old February 17th, 2009, 09:11 PM   #17
UnixHH's Avatar
2003 Saleen S281
stock manifolds, bassani o/r x pipe, 40 series flowmasters
Old February 17th, 2009, 09:14 PM   #18
B0B
Boost gets you laid
B0B's Avatar
2001 Mustang GT
12.93@113.7 (on the 18's)
B0B is just really niceB0B is just really niceB0B is just really niceB0B is just really nice
Send a message via AIM to B0B
damn unix what are the specs on those cams, those things sound sick and your power output is fuckin great compared to mine with the stock ones.
'01 GT. Just a couple Bolt-ons. 0rwhp 0rwtq. Epic Turbo build in progress
2003 Rubicon (wheelin rig)
2008 Silverado 4x4 (towin rig/road queen)
2009 KTM 450 XC-W (Brap Brap!)
Old February 17th, 2009, 09:15 PM   #19
UnixHH's Avatar
2003 Saleen S281
umm dont quote me 100% but i think 531/531in ex 292in ex duration 114lsa
Old February 17th, 2009, 10:04 PM   #20
BakerFX4's Avatar
iTrader: 14 reviews
Ive got the mac long tubes, prochamber, and flows. Hopefully mine sounds as good as that.
Threads Similar to: Camshaft
Camshaft Ticket-Me-Yellow V6 Mustangs 2 June 12th, 2008 10:59 AM
Getting a Camshaft itschristorres8 V6 Mustangs 14 June 9th, 2008 05:59 PM
camshaft new 5.0 94-95 3 March 17th, 2007 12:33 PM
Camshaft for a 96 94pacecarSVT V6 Mustangs 2 February 1st, 2007 12:24 AM
Camshaft Help djdroop23 Classic Mustangs 4 May 31st, 2006 12:06 PM
