starter removal - Forums at Modded Mustangs
post #1 of 13 Old February 21st, 2009, 02:50 PM Thread Starter
njstang's Avatar
iTrader: 5 reviews
starter removal
ok so i know its a PITA to do and ive searched a little on here and havnt found much. i removed the bottom bolt, and the top one that is above the terminals, apparently there is 3 on the starter? i cant find the 3rd one, am i just retarded or is it hidden?
Originally Posted by Jazzer The Cat View Post
Jazzer says heat your meat so it sticks to the street
NEW JERSEY STANG OWNERS :
http://njnewedge.forums-free.com/
njstang is offline
post #2 of 13 Old February 21st, 2009, 04:07 PM
Send a message via AIM to Saleenssc14
its AAAALLLLLLLL the way on top a bitch to find it
Saleenssc14 is offline
post #3 of 13 Old February 21st, 2009, 04:07 PM
Use a 1/4" ratchet with I think it's 12mm socket. It's on the very top and if you feel around with your fingers, you'll find it.
Make sure the ratchet has alot of clicks though. You'll only be able to turn it slightly so every click helps. I found this the easiest way after having to take it out 3 times now.
zinc02GT is offline
post #4 of 13 Old February 21st, 2009, 04:17 PM
Moderator
03SonicBoom's Avatar
Remember to remove the negative from the battery. Kind of a basic step but it's important.
03SonicBoom is offline
post #5 of 13 Old February 21st, 2009, 04:18 PM
mrsinister2424's Avatar
Send a message via AIM to mrsinister2424 Send a message via MSN to mrsinister2424
Just use a 12" or 16" extension, you should be able to get at it from the front.... I think.
99' Rio Red Mustang GT: --My Garage--
Check garage.
Vortech V-1 intercooled running 9lbs of boost
Life= eat, lift, eat, eat, eat, sleep, repeat
mrsinister2424 is offline
post #6 of 13 Old February 21st, 2009, 04:47 PM Thread Starter
njstang's Avatar
iTrader: 5 reviews
yeah battery is disconnected, i have 18" worth of extensions and a universal, and i still cant get to it, im trying to come in from the front, gap where the motor mount it but i cant get the right angle to get on the bolt. im using a 1/2" drive
njstang is offline
post #7 of 13 Old February 21st, 2009, 04:54 PM
Hmm, I didn't have a problem getting to it from the front, but then again my engine was jacked up a few inches off the k member.
Check garage.
post #8 of 13 Old February 21st, 2009, 05:04 PM
zinc02GT is offline
post #9 of 13 Old February 21st, 2009, 08:00 PM
qwick04gt's Avatar
i had that motor mount unbolted and the motor jacked up a little
4.10s,sfc,o/r x,lts,cai,70mmtb,plenium,30lb injectors,svt focus pump,hitech stage 2 cams,beehive valve springs, stage 2 clutch, borla stinger cat back, and a short throw. pampered with mobil 1 5w20.
qwick04gt is offline
post #10 of 13 Old February 21st, 2009, 08:04 PM
!FACEPLATED!
F8L GT's Avatar
iTrader: 13 reviews
NJ, if you have about a 24" extension you can go right through the crossmember and get it from the front.
Teksid short block, Ported 2v heads, Custom ground cams, Edelbrock Vic Jr intake, Brandon Alsept tuned
F8L GT is offline
post #11 of 13 Old February 21st, 2009, 08:08 PM
BakerFX4's Avatar
iTrader: 15 reviews
+1 go from the front right thru everything. Need alot of extension tho.
4.75 MMR 900se
Livernois ported heads
HP 292s blower cams
Procharger D1sc at 20+ psi
IW 15% OD pulley
(and more bolt ons)
E85
Tune/numbers coming shortly!!
BakerFX4 is offline
post #12 of 13 Old February 21st, 2009, 08:09 PM
03gtfirered's Avatar
i used a swivel and about a 12'' extension and went in from the front, worked like a charm. the bolt hole for the third bolt broke on mine so i no longer have a top third bolt. it starts like a charm lol
______________________________
summit racing catback, bassani o/r x pipe, RAM HDX,jlt intake, mach grill delete, tinted headlights and tail lights!!
Originally Posted by TwirtleNutZ270 View Post
Dude not having a tuner is kinda like having a cake without a fork.
03gtfirered is offline
post #13 of 13 Old February 21st, 2009, 08:18 PM Thread Starter
njstang's Avatar
iTrader: 5 reviews
yeah the thing is that my nut for the xpipe is cross threaded on the stud so i cant completely take off that side of the x pipe so jacking up the motor might be impossible. im trying to remove the starter (1) to give me room to get my dremel tool up there to cut the stock nut/stud off and because i need to get it off to put my new headers on. with the 1/4" drive i couldnt get it on the nut due to the x pipe being there. im going to unbolt the motor mounts and try jacking the motor an inch or so and hope that i can get to the damn top starter bolt. ugh i hate my car.
njstang is offline
Human Verification
