11.493@121.32
Drag only wheels/drag radials
I'm looking into getting some rear wheels/drag radials for occasional use at the strip. I don't have to have the lightest and fanciest. I'm only putting down 265rwhp/300rwtq for what it is worth. I have a 2004 Mustang GT. I don't want to spend that much money LOL!
What should I being looking at? Brands/sizes etc. Would I be better off getting a 315/35 17 style, or a 15" wheel style? |
cheapest drag wheels would probably be the Summit/Jegs Wheels.
![]() N/A Auto 2-Valve 1.74' 60ft 12.79 @ 105.5 |
11.493@121.32
If I go with the 15" wheels should I be going with 8" or 10" width?
Right now I have 17 X 10.5 wheels/with 315/35 17 tires (BFG KD). Am I going to see a noticeable difference in traction with the drag radials? |
15X8 wheels will be fine with a 5.5" backspacing, if you go with 15x10s make sure you get 6.5" backspacing
![]() Single 67mm turbo, ported pi heads, edelbrock vic jr. manifold w/HPP plenum, terminator shortblock, return fuel system... Goal 600+ rwhp. |
2003 Mach 1 Mustang
just get some 15x8s and put some MT ET streets on there and you will be more than fine and yes you will notice a big diff in traction
![]() mostly stock 8.2@83 1/8th |
5.5bs on a 10inch rim also works good too .. thats the set up i run with a 275/50 mickey .. car is lowered on sportlines and tire doesnt rub .. 15x10 5.5 is common with fox bodies and are usually easier to find used cheap .. thats what i did anyways
12.777@115JLT;Prochamber;Magnapacks;4.10s;31 Spline;Spec Stage 2+;Predator;NX 125Shot .. Quest for 11s |
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
but the fox rear and teh 96-98 rears are more narrow. a set of 10.50 bias plys have rubbed hard on a lot of cars.
#8 | |
2001 Mustang GT
12.4@111 (N/A)
this is them, and as you can see it's pretty flush ![]() ![]() this is a 15x8 w/ 5.5" bs (this would sit 2 inches in compared to a 15x10 w/ the same bs). As you can see they are 'tucked' but not enough to stick them out 2 inches without hanging past the fender. ![]()
12.4 @ 111mph N/A 2V... (first trip out) in desperate need of a driver mod ![]() N2O times coming soon my junk at the track
mm's nitrous mod
2000 mustang gt
there are a lot of guys that run a 5.5bs on these cars. i have seen a few at the track, they will run without too much issue.
I am using a Weld Draglite 15x9 with 5.5 BS,along with a 275x50x15 M/T DR.
Seems to work and fit well. The 9 inch width is a great fit for that size tire. Just remember to use long,3 inch axle studs,with the thick center Weld wheels,to be safe! |
11.493@121.32
Thank you for the information!
Did I mention that I'd like to drive to and from the track (about 50 miles each way) on these wheels/tires (and be safe in case it rains)? |
2001 Mustang GT
12.4@111 (N/A)
if you don't want to have to worry in the rain get Nittos.
Moderator
2010 mustang gt auto
for the power your making & the fact you want to drive to the track on them/etc, you would be best off to look into 315/35r-17 nitto d/r's & just run them all the time. you'll get at least a year of d/d & track time out of them & not have to worry about the weather, changing tires at the track , etc., etc. I have them on mine fulltime & haven't ever had a problem (dont put many miles on though but tons of track time & drive back & forth to track)
MM BRACKET RACING CREW CO-FOUNDER BAMA Performance Drag Team Founder 2010 GT auto
2011 Mustang GT
12.89@111
You could get two 16" v6 mustang wheels and put some drag radials on them. That seems to be a pretty popular thing to do when money tight or you just dont wanna drop a grand on welds.
2011 Mustang GT Auto Bone Stock
not a typo, but ill get pics maybe this week if its nice out and i feel like swapping tires for just a pic ..
11.493@121.32
I thought about getting some deep dish bullitt replicas (17 X 10.5) and putting on the Nitto 555Rs. But this would cost $681.98 shipped from American Muscle.
I was just wondering if I could do it a little bit cheaper some other way. |
11.493@121.32
What about putting a drag radial tire on my stock Mustang 17 X 8 bullet rims?
Would this give better traction than the 315/35 17 BFG KDs on the 17 X 10.5 rims? |
2001 Mustang GT
12.4@111 (N/A)
no need in going through the trouble. The next time you get around to it just snap a pic and PM it to me if you don't mind.
#19 | |
TT Bullitt
![]() iTrader: 2 reviews
11.493@121.32
Would 275/60-15 be the size of tire that I would be looking for to fit on the 15" rims for the Mustang?
Sorry for asking so many damn questions! |
Threads Similar to: Drag only wheels/drag radials
| Drag Radials.. | Black_stang | 99-04 | 55 | March 3rd, 2010 02:44 PM |
| drag radials | Mustang RacR94 | 4V / SVT | 11 | September 2nd, 2008 03:02 PM |
| Drag Radials | MATT02GT | 99-04 | 6 | July 26th, 2007 07:04 PM |
| Drag Radials | myeleanor | 2005 - 2010 | 32 | April 18th, 2007 07:21 PM |
| Wheels for drag radials? | fomocoro | 2005 - 2010 | 1 | April 10th, 2007 07:00 PM |
