The George Forman of Keepers
Brake booster
If you have a leak in the brake booster or master cylinder, will it have an effect on the power steering system? Those systems are completely separate right?
When I turn my wheel, its making alot of noise and making my RPMs dive more than it ever has. Also, when I put the car into gear from an idle (with my foot on the brake) the RPM's dive 300-500 and gets damn near stalling. Now if I just put the car into gear without applying any brake, the RPM's dont dive at all. Im so sick of this POS. I have multiple gremlins Im chasing around. |
power steering pump goin out,.
![]() 2000 kenne bell GT (440HP-432TQ) Tuned by Joe at http://www.tricktuners.com dyno vid:http://youtu.be/lr3xpxw2_v8 2011 escape MUSTANG TAT CREW |
2002 MUSTANG GT
14.2@100
![]() iTrader: 1 reviews
^sounds like it. check fluid level if havent already.
2002 Camaro SS
12.XX@11X??
Are the brakes mushy or anything?
2006 GTO A4-13.3 2.1 60' Motor/12.0 1.7 60' 100 Shot otherwise stock |
no, they feel fine.
def. your power steering
Does our power steering run off the brake booster at all?
Resident DJ
'01 Cobra Vert.
No. It's seperate. Check the fluid in your power steering and if the fluid is fine I would most likely suspect the PS pump is goin'.
Ok, I am convinced there is a problem in my power steering pump. Its failing. I think I have more than one problem at once and that is what is making this difficult.
I ran through my Haynes to help. I did this "test" on the brakes to see if my master cylinder or hydro booster is failing. With the tranny in nuetral, I stopped the engine and applied the brakes several times to deplete all the accumulator reserve. Then I held the pedal depressed and started the engine. If the hydro boost is operating correctly, the pedal should fall slightly than push back against my foot. Well, the pedal fell slightly and just stayed there NOT pushing back. To see if there were any leaks, I had my daughter apply the pressure to the pedal while at idle and I sprayed a little carb cleaner (carefully) near the brake lines/master cylinder and booster. There was no change in idle at all. Now, Im still getting the occasional lean codes in bank one and two. Any thoughts on this mess???? |
Resident DJ
'01 Cobra Vert.
No other than your 02's could just be taking a poo. I'm still working on diagnosing that problem though broham
PM sent.
Resident DJ
'01 Cobra Vert.
Replied
The Hammer
Millenium Falcon
sell it and get a GT
problem solved dude |
Rags! Fuck.
Resident DJ
'01 Cobra Vert.
The Hammer
Millenium Falcon
seriously man......
i had a 95 Z28 that was falling apart in my hands 2 years ago, i said fuck it, sold it, and got a GT. if it worked for me, it could work for u too |
I cant go buy a new car right now. I need to fix this thing. Believe me, eventually, I will get rid of it. All my problems started with these LT's. I need it right for awhile. Maybe by summer I'll be in a spot but for now, I need to try real hard to get this thing at least reliable.
Resident DJ
'01 Cobra Vert.
Check your lean code thread.
#19 | |
The Hammer
Millenium Falcon
u can get a nice 99 GT with 60k on it for the trade in of ur 04 vert
Well, now that I have the LT's on with no cats its going to be hard to sell or trade. I still have a loan on it anyway, so Im stuck. Plus, its to the point now where I just want to BEAT this fucking thing. I want it to work right. I guess I dont know when to quit and never have. The challenge of the whole thing has gotten the best of me.
Threads Similar to: Brake booster
| Brake light switch problem after upgrading brake booster | black88 | 5.0 Mustangs | 2 | January 20th, 2008 11:41 PM |
| Question (Brake Booster) | Stang187 | V6 Mustangs | 17 | January 4th, 2008 07:02 PM |
| Brake booster | kwill5 | 96-98 | 11 | August 10th, 2007 09:54 AM |
| PCV or Brake booster. | 232stang | V6 Mustangs | 5 | March 12th, 2007 09:59 PM |
| brake booster swap??? | OTreborO | 5.0 Mustangs | 7 | June 2nd, 2006 04:31 PM |
