what does your car idle at??
i was driving home last night from a friends house and sitting at the light i noticed my car seems to be running at really low rpms at idle. it was about 6ish or so maybe a bit higher but not much...i was wondering what your alls cars are idling at and what it should be idling at...also has anybody noticed that at certain times there car jumps up in idle and then back down? i was told it was just something with the computer but i was still a bit curious? thanks guys!!
thanks for the sig Zatrekaz ![]() Bowties are for Gay Guys!!! |
2002 MUSTANG GT
14.2@100
![]() iTrader: 1 reviews
mine idles at 750-800 rpms and it never jumps up in idle. maybe try cleaing the TB.
just cleaned tb a week ago, when i did seafoam the car and change oil and fuel filter as well. it doesn't always jump rpms at idle just every now and then almost like as if a set of cams were loping in the car, but it doesn't do it constant neither it does it maybe 3 times then straightens itself out
!FACEPLATED!
Mine idles at 500.. bacause i put it there lol
![]() MM Bracket Racing Crew Co-Founder ~Its a Drag Car, Not a Show Car~ LINK-->Custom Race Transmission Build<--LINK
eventually @ something
I set my idle to 780. I have the opposite problem, while I slow down in gear, if i take it out of gear, my idle sinks down to 500 then goes back up to 780, its really weird. if im out of gear and come to a stop it doesnt happen, only when im in gear then throw in neutral
MM.s Used Car Whore
2011 F150 XLT 4x4 5.0
14.89
i set mine at 780 but its more like 980
2011 Mustang GT
12.1 @ 116
Stock idle should be around 650-800 rpms.
Clean your IAC.
Mods in garage. Built suspension and gears since posted times. |
myspace.com/garrettstarnes 2004 4.6 engine. Cold air intake. Stage2 clutch. Spec Flywheel. Intake spacer. Throtle Body spacer. More to come! |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 4 reviews
650 for me, i was running it at 600 for while but decided to bump it up some
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 14 reviews
hey ajm... with the cams, if its idled down lower then it prolly lopes harder huh? With it being idled low have you ever had it die on you while idling?
![]() 4.75 MMR 900se Livernois ported heads HP 292s blower cams Procharger D1sc at 20+ psi IW 15% OD pulley (and more bolt ons) E85 ![]() Tune/numbers coming shortly!! |
Yea it def does. The lope is more noticable but not as loud, if that makes any sense. I never had it die when I was running at 600 although there were a few occasions where it sputtered a bit when pulling into a parking spot, I guess low rpm + the strain of the power steering pump is what would do it. Thats the only reason I bumped it up to 650. It would run fine at 550 as well in the drive way but I didnt want to risk it and be dieing out at lights n stuff lol.
how did you bump it up yourself?
!FACEPLATED!
with a tuner
Theres a setting somewhere in the tuner that is labled as "drive idle speed" and "neutral idle speed" or something like that. You can adjust it up and down in increments of 50.
so my xcal 3 has it?
yea. I may be wrong here on the specifics of what the tuner will pop up and what to select since I dont play with the thing enough to really know the ins and outs of it but plug it in etc and select load custom tune, pick your tune and hit select then the next screen will come up, you want to select "used saved options" or something like that. It should then pull up all the settings and stuff, go through and find the idle speed, adjust it, hit select, hit cancel or whatever it is to save/load the tune and youre good to go after it loads and does its thing.
oh... sounds easy enough then.
yea its pretty simple, it doesnt take but a minute or two to do. probably takes longer for the tune to load than it does to get through all of the steps.
1999 mustang gt
Mines idles at 500 and does bump up to about 800 every once and a while. Only when the ac is on though.
My idle is usually at 550 and jumps up occasionally. I drive an automatic btw.
Is that normal? |
Threads Similar to: what does your car idle at??
| my car at idle.. | jat | 2005 - 2010 | 4 | November 10th, 2008 11:19 AM |
| Problem starting my car (won't idle) | Reset | 99-04 | 25 | May 24th, 2008 01:19 PM |
| Car Wont Idle | 1BADSTANG | 5.0 Mustangs | 2 | December 4th, 2007 08:37 PM |
| car wont idle | bluedemon | 5.0 Mustangs | 2 | February 2nd, 2007 06:13 PM |
| My Car Idle And Revving To About 4500 RPMs | Drgnracin72 | Videos | 13 | October 14th, 2006 12:22 AM |
