Fuel Rails
how restrictive our the stock fuel rails? is there any need to upgrade them to reach the 600hp mark? and has an one ever heard of these
Fore Precision Works Billet Fuel Rails Available NOW for the 1996-2004 Mustang GT with PI (performance improvement) intake manifolds. Designed specifically for the 1996-2004 Mustang GTs, these are the finest fuel rails available. -OEM positioning, orientation, and size of o-ring seats for injectors. -Robust integrated mounts for safe and reliable injector seating. Stainless steel mounting hardware included. -FRPS bank includes a 1/8" NPT fitting for remote fuel pressure sending units for in car fuel pressure gauges. Optional block-off available for return style systems. -SAE o-ring boss ports (-8 size) on front and back of both rails. -These fuel rails are machined from 6061-T6511 from a solid block of aluminum. There are no welds or caulk to fail. ![]() 185$
![]() 480RWHP 450RWTQ 15psi @ 15* on 91 octane |
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
fore makes some badd ass products. stock rails have seen 600hp, but if you have enough $$$ to make that power then what is another couple hundred on a set of rails?
Resident DJ
'01 Cobra Vert.
Moderator
2012 300a gt auto
12.10@116
with all the crap fuel rails floating around, those look like their a steal.
MM BRACKET RACING CREW CO-FOUNDER BAMA Performance Drag Team Founder 2012 300a GT auto
not to mention they look like sex! lol do you know anyone that runs these? and if so i would like to see a picture
#6 | |
Resident DJ
'01 Cobra Vert.
" factor
2000 GT
Fuel lines are a restriction before the fuel rails.
2000 Black convertible GT: KB 15psi, and other goodies... ![]() 1971 Datsun 240 z: Header and rebuilt motor. (The DD) |
but you would think with the larger bore you would have more fuel availible for the injectors and the pump wouldnt have to work as hard to keep the pressure stable? i dunno just my thought process
if you just got a KB the kit comes with new fuel rails
![]() 2000 kenne bell GT (440HP-432TQ) Tuned by Joe at http://www.tricktuners.com dyno vid:http://youtu.be/lr3xpxw2_v8 2011 escape MUSTANG TAT CREW |
lol
1999 3V GT/2007 GT D/D
corner carver
^+1 Kb
#12 | |
mm's nitrous mod
2000 mustang gt
. i am looking into their rails and fuel hat. i looking into the bbk rails also.
Their dual fuel pump hat seems to be a nice setup.
#14 | |
Resident DJ
'01 Cobra Vert.
I've been looking at rails too. I found mine new ones. Sweet Thread!!
03 GT 5sp, K&N FIPK, MAC LT ceramic coated headers, MAC Prochamber, Steeda Tri-ax, 3.73, SCT X-cal2 tuned by D&G Dyno Tune, NX plate Kit, Eibach Pro Springs, CMS Stage 2 cams. STRIKE design from MK Motorsports. |
KB'd GT
Werd. Those rails are very sweet looking. If i were you i would do the wire upgrade for the fuel pumps. That should get you another 5% DC out of the pumps, and is cheap. ( should have mentioned that in the other thread).
12.73@111.36
What is the wire upgrade?
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. |
KB'd GT
Its where you run some 8 gauge to the FPDM with a relay, and some 10-8 guage from the FPDM to the fuel pump.
you know where i can buy this wire upgrade joe?
KB'd GT
some places sell kits, but sweet2kstang did a great write up here. you can buy this stuff from stereo stores / auto parts stores.
fpdm/fuel pump wiring upgrade |
Threads Similar to: Fuel Rails
| fuel rails?? | Military98stang | 96-98 | 5 | September 24th, 2008 09:43 PM |
| new fuel rails | zerofx150 | 99-04 | 3 | February 8th, 2008 08:36 PM |
| Fuel Rails | Euroeater95 | 94-95 | 9 | August 31st, 2007 03:10 PM |
| Help! Fuel Rails | Skullman | General Tech | 0 | September 24th, 2006 08:09 PM |
| fuel rails | 03stanger | General Tech | 0 | June 8th, 2006 07:17 PM |
