***Need Help*** Fuel pump problem?!?!? - Page 2
Old March 5th, 2009, 04:37 PM   #21
Trick Tuners's Avatar
KB'd GT
You can have someone else turn the key while you press down on the valve to see if gas comes out (watch out!!). Maybe you are out of gas!! once i helped someone troubleshoot an issue like this for a couple hours. then we added some gas, and what do you know!!!
Old March 5th, 2009, 10:20 PM   #22
Mluna08 is on a distinguished road
Anyone with any insight?
Old March 5th, 2009, 10:28 PM   #23
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
casper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant future
start with a new filter 17k is far to much, dont let anyone B.S. you, & get a motorcraft one no generic/part store brand's.
MM BRACKET RACING CREW CO-FOUNDER
BAMA Performance Drag Team Founder
2012 300a GT auto
Old March 5th, 2009, 11:10 PM   #24
neverfastenough1's Avatar
Pressure will only die down so much with the key off (like 5 psi or so). You should be able to walk out to your car and check the pressure without turning the key on.
Old March 6th, 2009, 11:22 AM   #25
KB'd GT
he did that already and got nothing. If you have a pprv delete, or an internal tank leak you will not hold pressure, but it should still give a little squirt on prime. (if its hooked up at all). If not, then drop the tank and see if any hoses are leaking or broken.
Threads Similar to: ***Need Help*** Fuel pump problem?!?!?
99 Mustang fuel pump problem? stephen V6 Mustangs 18 September 3rd, 2010 07:57 PM
Fuel Pump Wiring Problem Black Five 0h 5.0 Mustangs 3 December 25th, 2007 12:32 AM
Fuel Pump Problem? chaosstangman 5.0 Mustangs 3 December 19th, 2007 11:39 AM
Fuel Pump Problem RyanGT 99-04 2 November 11th, 2007 03:18 PM
1990 Ford Ranger XLT fuel pump problem ScyraxxX All Other Vehicles 22 August 9th, 2007 02:15 PM
