***Need Help*** Fuel pump problem?!?!?
Old March 5th, 2009, 02:55 AM   #1
Mluna08 is on a distinguished road
About 5 days ago I was driving home from work and I noticed that my 2001 Mustang GT Auto felt like it was hesitating a bit when I would hit the gas.
I pulled into my drive way and it felt like it was going to shut down on me, Ive never ran out of gas in my car but I would imagine that the way the car was acting it might have been.
My gas gauge read 1/4 tank left.... a few people have mentioned that it may be the fuel pump and what I felt was the fuel pump gradually going out.
Its not a cheap fix so I was wondering if anyone could provide some insight on the other possibilities.
When I turn the car on it turns but it just wont start. Car has 47K on the odometer and fuel filter was changed at 30K.
Thanks in advance.
Old March 5th, 2009, 03:09 AM   #2
BlackedOut04GT's Avatar
14.21@97.93 2.107 60' (Best pass. So far.)
BlackedOut04GT has a spectacular aura aboutBlackedOut04GT has a spectacular aura about
Send a message via AIM to BlackedOut04GT
Have you cleaned the throttle body at all? Try that first, it's a good thing to do anyways. I had a problem with mine about a year ago. I had an 1/8 of a tank left ,so it said, and couldn't get it to start. Took the tank out and the plastic end clip for the filler that goes in the tank had come off and was stuck under the float. Side note you just reminded me that I need to change my fuel filter. It's only been 57k miles on it.
Old March 5th, 2009, 03:23 AM   #3
mrsinister2424's Avatar
99' Mustang GT
3214@OVER 9000!!!
mrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to behold
Send a message via AIM to mrsinister2424 Send a message via MSN to mrsinister2424
Does anything look fishy with your injectors or fuel rails? I finally figured out why I've been getting shitty gas mileage these last two weeks..... the bolt that holds the fuel rail down loosened up and one of the injectors was leaking gas! Car acting real shitty when it was doing that.
99' Rio Red Mustang GT: --My Garage--
Check garage.
Vortech V-1 intercooled running 9lbs of boost
Life= eat, lift, eat, eat, eat, sleep, repeat
Old March 5th, 2009, 03:33 AM   #4
Lucky it didn't catch on fire there.
Old March 5th, 2009, 07:12 AM   #5
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
if you got a tuner, look at the frps and see what the pressure is. if it is ok, you can knock that factor out of the way. fuel pump change isnt bad at all, only take 1-2 hours to change and there are people that pretty much give their stockers away.
Old March 5th, 2009, 09:03 AM   #6
~C~
~C~, The Other White Meat!
~C~'s Avatar
Y2K YellowJacket GT
~TBD~
~C~ is just really nice~C~ is just really nice~C~ is just really nice~C~ is just really nice
Send a message via AIM to ~C~
where?
BLOWN Bumblebeast!
370 rwhp / 381 ft lbs
~Tuned by JJ at WMS
"Like the blind man says......We shall see...."
Old March 5th, 2009, 09:26 AM   #7
mustangrebuilder will become famous soon enough
put more gas in it, you could be reading that you have a 1/4 of a tank but really you have none.
check the grounds on the fuel pump, if one come loose its not going to work.
just some places to start
Old March 5th, 2009, 09:30 AM   #8
Black Bullitt's Avatar
2001 Mustang Bullitt
Faster than Twinmill
Black Bullitt is just really niceBlack Bullitt is just really niceBlack Bullitt is just really niceBlack Bullitt is just really nice
Send a message via AIM to Black Bullitt
I had a '97 cavalier and the fuel pump went out on it. It made it buck and die. It sucked. Back then I didn't know much about cars and paid someone to change out the pump...got raped in the process. Lesson learned and started learning a lot about cars.
2001 Bullitt #5069
505rwhp/538rwtq @ 15#s
Originally Posted by FluffyTheRhino View Post
Nothing says "Upgrade EVERYTHING" like busted parts
Old March 5th, 2009, 10:02 AM   #9
03gtfirered's Avatar
2002 MUSTANG GT
14.2@100
03gtfirered is on a distinguished road
check all the free and less expensive things it could be first before you spend big money. ^these guys, as always, have given you great places to start.
______________________________
summit racing catback, bassani o/r x pipe, RAM HDX,jlt intake, mach grill delete, tinted headlights and tail lights!!
Originally Posted by TwirtleNutZ270 View Post
Dude not having a tuner is kinda like having a cake without a fork.
Old March 5th, 2009, 10:22 AM   #10
Thank you all for your recommendations, I am off today and will check these things out.
One thing I forgot to mention was that when I got out of the car it did smell like gas.
Old March 5th, 2009, 10:31 AM   #11
I'd check all your fuel lines.
2001 Bullitt #5069
Old March 5th, 2009, 01:02 PM   #12
Trick Tuners's Avatar
KB'd GT
Can you hear the fuel pump prime with key on engine off? It should buzz for a couple seconds on key on. If you are in a garage or other quiet place you can hear it from the drivers seat. If not, you can have a friend listen by the gas tank. You can also use a screwdriver and a rag to see if there is pressure at the rails in the valve (tire valve thing).
Its not the throttle body, unless some guy was stuffing rags in there.
Old March 5th, 2009, 03:02 PM   #13
So i went out to the car and when I turn the the key to the on position without starting the car I can here something turn on.... like a pressurized line turning on.
One thing I have noticed is that when I try to start the car the THEFT light stays on. Not sure if this is common but I dont remember it coming on like this.
I checked fuses, all look fine (Fuse box under the hood). Reset the fuel pump from the switch in the trunk and still nothing.
I didnt try the valve. Where do I find the fuel line valve?
Old March 5th, 2009, 03:06 PM   #14
KB'd GT
Its on the front of the passenger side rail, under a black cap. Remember gas will spray out, so wrap a rag around the screw driver before you see if there is pressure in it.
Old March 5th, 2009, 03:21 PM   #15
BYAHHHH!
Scott2001GT's Avatar
2001 Mustang GT
13.874
mine was doing the same. look at my thread I posted. Son of a...... 1fastfox seems to have good suggestions! try fuel stabilzer for the rest of your tank the 93 octane to clean the system. mine would start then die and I would have to give it gas to start. good starts for the past 3 times though!
Old March 5th, 2009, 03:25 PM   #16
Thanks.. check it out.... There are two lines. One with a red/green cap (dirty) that has a tag on it that read pressurized line and a black cap.
The red/green cap with tag did not have any pressure, car was off no key in ignition.
Black cap did have pressure and I used a white rag to determine the substance, it was yellow and cold so I am thinking the black cap was the A/C.
Old March 5th, 2009, 03:30 PM   #17
2002 MUSTANG GT
14.2@100
its called the scraider valve and its located on the fuel rail. locate the fuel rail and look for a valve on the end. also you want to have the key in the ignition and the key turned to on. you want the fuel pump to prime the lines if it is working. that will bring pressure to that valve and should spray gas out if working properly.
Old March 5th, 2009, 04:01 PM   #18
Found the valve, used the screwdriver with the key in the ignition and in the on position. No Pressure.
Did it with the key out and no pressure as well.
Any other suggestions?
Old March 5th, 2009, 05:06 PM   #19
2002 MUSTANG GT
14.2@100
and you said you can hear the whine of the fuel pump priming? sounds like you got either a bad pump or a line is clogged somewhere. did you check the fuel shut off switch in the trunk?
Old March 5th, 2009, 05:11 PM   #20
I can hear a click when I turn the key. Yes I reset the fuel switch in the trunk.
Threads Similar to: ***Need Help*** Fuel pump problem?!?!?
99 Mustang fuel pump problem? stephen V6 Mustangs 18 September 3rd, 2010 08:57 PM
Fuel Pump Wiring Problem Black Five 0h 5.0 Mustangs 3 December 25th, 2007 01:32 AM
Fuel Pump Problem? chaosstangman 5.0 Mustangs 3 December 19th, 2007 12:39 PM
Fuel Pump Problem RyanGT 99-04 2 November 11th, 2007 04:18 PM
1990 Ford Ranger XLT fuel pump problem ScyraxxX All Other Vehicles 22 August 9th, 2007 03:15 PM
