#21 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 4 reviews
#22 |
Instead of starting a new thread, a place around me wants $749 which includes....
4:10 Gear installed on 2000 Mustang including lube, pinion bearing, solid pinion spacer. I am kinda thinking this is a bit much but need some opinions. |
#23 |
sry for adding something so late lol but thoes thicker shims are cast and if you tap them too hard with a hammer they WILL shatter. id suggest a deadblow or a piece of wood inbetween ie. no metal on metal contact. just my 2 cents
![]() 480RWHP 450RWTQ 15psi @ 15* on 91 octane |
#24 |
Great write up but i wish someone would give ajm sum pics DANG IT! would make it that much better
thx ajm
LED third brake light to replace old sun damaged one, shorty antenna, new PI Intake Manifold with aluminum crossover (my original was all plastic). Bosch Platinum 4 Spark plugs (awesome set)
#25 |
13.40@101.58 (Sux!)
![]() iTrader: 1 reviews
One Important step mentioned in the write-up: "Take your old pinon + shim (after you remove the bearing of course) and get a measurement from the bottom of the pinion to the top of the shim." I didn't do this and removed the shim then didn't know which shim I removed. I have to go thru the whole process of figuring out my new pinion depth! MAJOR pain!
#26 |
n/a
this was awesome thanks man having step by step allows almost anyone to do it with the right tools!
#27 |
13.7@103
Yeah too bad he's banned now.
![]() Bigbore Kooks (parting out 2v motor) N/A 5.3 4v Build
http://www.moddedmustangs.com/forums...ing-build.html |
#28 |
n/a
i need a 99-04 tan leather driving seat! and tuner! |
#29 |
#30 |
'02 VERT
13.08@106.11
what was all that about
CMS STAGE II FRPP 4.10s LTS, O/R H, FLOWMASTER WELD ONS EDELBROCK INTAKE MHS 6061 ELBOW NX PLATE 100 SHOT SCT X3 TUNED BY JOE MANSFIELD AT ABOVE AND BEYOND PERFORMANCE |
#31 |
2003 MUSTANG GT
![]() ![]() ![]() ![]() iTrader: 10 reviews
Idk if a mod would want to insert these into the original write-up, but here's pics of my install:
![]() 4v MMR 4.75 Stroker, Teksid block .020 over, 9.27:1CR, Posi Race Ported Eaton 4v MMR Stroker 1000 / Posi Race Ported Eaton Build How To: 2v to 4v COP Swap |
#32 |
2003 Gt
slow
why is he banned^^
Threads Similar to: Gear install write up
| LT Header install write up? | 05roush0090 | 2005 - 2010 | 21 | December 29th, 2008 10:38 PM |
| header install write up | beheivjer | Modular Mustangs | 0 | May 14th, 2007 03:27 AM |
| Gear install in KY | shamdoodie | V6 Mustangs | 2 | February 13th, 2007 01:26 PM |
| Long Tube header Install Write-Ups? | xx9gt6xx | General Tech | 2 | April 27th, 2006 03:12 PM |
| Good Nitrous Install Write Up | stangaddict | General Tech | 3 | March 26th, 2006 09:10 PM |
