got my new BBK valve covers in
Old January 12th, 2007, 11:55 PM   #1
1999 Mustang
Invictus is on a distinguished road
well the new valve covers just came in (i cracked my old one trying to wrestle it off for the cam swap) and they are almost an entire inch higher clearance wise than the stockers... with the stock ones i could just BARELY get them in by prying my engine back a good 1/4 and managing to get my cam caps off while they were still on by reaching my arm underneath and doing it without looking lol. (only way i could figure out). so these new ones dont stand a chance! it's the driver side in particular the clutch cable and master cyl and all that assembly in the way ahh..
i think the only way i'm going to have any kind of clearance is to lower my engine a couple of inches only problem is i don't have the sligtest clue as to where to even start in doing this. is it just the motor mount bolts? how do i support it to be able to lower it its in my driveway.. the old covers are off so i cant drive it up any ramps.. any help with this appreciated thanks.
Old January 13th, 2007, 12:00 AM   #2
1999 Mustang
sry.. basically what's the best way to to lower my engine enough so that i can get enough clearance up top to bolt the new valve covers down. keeping in mind my car is in the driveway and what about my headers, and tranny and all that??
Old January 13th, 2007, 02:42 AM   #3
superbeef1000's Avatar
yeh you could jack the car up place it on jack stands and then use a good floor jack with a piece of 2\6 wood and place the jack under the oil pan or crank pully jack it up just a little to puport the motor then undo the motor mounts take them out , then lower the engine a little ,you may need to take off the starter and steering rod , h pipe then just put it all back when yur done but its a lot of work i had to do this when i installed my headers
Old January 13th, 2007, 03:00 AM   #4
1999 Mustang
how do i get the master cyl. off and how do i get the clutch cable out of the way??? if i get these 2 out of the way i think i could pull it off.. there's no way the new valve covers are just slipping in there though. i even took the cam caps off for an extra 1/4" of clearance and still not even close!
Old January 13th, 2007, 03:16 AM   #5
1999 Mustang
the directoins say remove 2 5mm bolts from the firewall.. lol that didnt do anything is there something im missing on the clutch cable..? and does anyone have a writeup as to how to remove the master cyl? appreciated.. thanks!
Old January 13th, 2007, 11:20 AM   #6
MM's Mad Scientist
acmillr's Avatar
Slow Fella
acmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to behold
If I'm not mistaken, you will need to look above your brake pedal, inside the car, and remove the nuts that are put on from the interior of the car to completely remove the brake booster and master cylinder together.
Old January 13th, 2007, 02:41 PM   #7
Keegan_Vann's Avatar
Keegan_Vann is on a distinguished road
Send a message via AIM to Keegan_Vann
yeah this is right I had to do the same thing for my headers and when replacing my clutch.
I wanna go fast... I wanna go fast... I'm goin' fast!!!!!
Old January 13th, 2007, 02:52 PM   #8
MM's Mad Scientist
acmillr's Avatar
Slow Fella
Invictus, Im proud for you- You are going to know every nut and bolt in your car within the next few months.
Old January 13th, 2007, 06:43 PM   #9
1999 Mustang
hehe im gettin it bro.. alright i got the master cyl. setup those 4 bolts on it off completely and managed to actualyl rotate it a bit a good inch or 2 out of the way, and i think that will be sufficient. how in the world do i get this clutch cable off though?! it's now the only thing stopping me. the BBK BS directions say remove the 2 5mm bolts at the firewall.. okay i took them off lol and that didnt do me any good. if i got the clutch cable out of the way i'd be home free. thanks for the help so far! and yes im gettin it, i love doin this though. nothin better than hands on experience.
Old January 14th, 2007, 01:44 AM   #10
1999 Mustang
AlRIGHT! i manged to do this without lowering my motor!! yes yes i know im a beast.. =) lol jk... alright... So i ended up having to take off the entire master brake cyl. assembly and brake lines and there was a little metal bracket holding the clutch cable in place that i un bolted and it gave me just enough slack in the cable to move it out of the way just enough. had to take the coil packs, fuel rails, injectors, power steering fluid resovoir, wireing harness, and yeah about 24,000 other things lol but the covers are in and bolted down and over with. i'm now in the process and putting everything back on.. but obviously my brake lines were exposed and probably got an assload of air in them... so i dont know where to begin to bleed the lines. isn't there a bleeder valve or something? what's the best way to do this?? i'll have everything hooked back up here in an hour or so and i'll have to bleed the brakes and hopefully be done with it tomm morning sometime. any brake bleeding tips appreciated, thanks
Old January 14th, 2007, 08:58 AM   #11
Invictus could you post some pictures when your done id like to see how thees valve covers look when in place oh and a job well done
Old January 14th, 2007, 09:32 AM   #12
MM's Mad Scientist
acmillr's Avatar
Slow Fella
Get someone to pump the brake pedal while you bleed off the air at your calipers. *Start with the caliper closest to the master cylinder (front driver's side) and work out from there.
What you will need to do is
1) Take all of your wheels off.
2) Locate your bleeder valves on your calipers.
3) Make sure you have plenty of fluid in your master cylinder BTW: You will have to repeat this step throughout the process.
4) Get whoever is helping you to pump up the brake pedal and hold it down (hard). Then back off the bleeder valve with a wrench. Let all of the pressure come out then tighten the valve back down. After that tell the other person to let off of the brake pedal (DO NOT LET OFF OF THE BRAKE PEDAL WHILE YOU HAVE THE VALVE OPEN OR IT WILL SUCK AIR INTO THE SYSTEM). Repeat this process as many times as necessary to get all air removed from the lines.
5) Crank the car and cycle the brakes to see if they feel spongey. If they do, you still have air in the system and you need to repeat all steps.
*Have plenty of brake fluid on hand- you will need it.
Old January 14th, 2007, 08:28 PM   #13
1999 Mustang
i start with the closest one or the furthest one?? seveeral people ahve told me to start from the passenger side Rear of the car (farthest from master cylinder). i have 3 bottles of prestone brake fluid from walmart will this do the trick? if i run out can i reuse the fluid that gets pumped out? thanks i didnt have much time to get on it today i'm about to jack it up and get er' done
Old January 14th, 2007, 08:57 PM   #14
mdvaldosta's Avatar
11.47@120.58
On a side note getting the clutch cable off is as easy as popping it off the clutch fork to make slack, slipping it off the clutch quadrant under the dash, and taking off the two small bolts holding it to the firewall. Shouldn't take more than a couple minutes once the car is in the air.
I had trouble getting the driver's side valve cover off as well when I did the cam swap. Had to play with it for a few minutes then it magically came off. Took the clutch cable off but not the master cylinder.
Old January 15th, 2007, 01:02 AM   #15
1999 Mustang
yeah i could've gotten the stock plastic ones in with no problem just takes some moving around and elbo grease.. however the new BBK valve covers are much more bigger in volume and the removal of the master cylinder and brake booster and that entire assembly was necessary not to mention the bolts are HEX bolts which makes the job even more of a hassle.. it took me several hours but they're in now and i RTVd the hell out of them and so far no oil leaks. i haven't bled my brakes yet because they still work the pedal is just very spongy so i will definately have to do it tomorrow morning.
lol... to anyone reading this thread if you've been planning on adding some nice new titanium or chrome BBK valve covers, be prepared to spend an entire day under the hood with a lot of patience. i dred the day ill have to take these things off again for any reason!
Old January 15th, 2007, 07:29 AM   #16
MM's Mad Scientist
acmillr's Avatar
Slow Fella
Start with the closest. You want to push the air out of the system gradually.
Old January 16th, 2007, 11:29 AM   #17
Casper98GT's Avatar
Youre mustang has hydroboost you know this right ? You might not have disturbed youre brake lines, in fact maybe powersteering lines. Check it first. I'll get back to you tonight on how to bleed the hydroboost.
91 LX, 5spd.
Ex:Toyota/Ford tech
Old March 2nd, 2011, 04:08 PM   #18
2004 mustang
tommyboy2008 is an unknown quantity at this point
wrong
Originally Posted by acmillr View Post
get someone to pump the brake pedal while you bleed off the air at your calipers. *start with the caliper closest to the master cylinder (front driver's side) and work out from there.
1) take all of your wheels off.
2) locate your bleeder valves on your calipers.
3) make sure you have plenty of fluid in your master cylinder btw: You will have to repeat this step throughout the process.
4) get whoever is helping you to pump up the brake pedal and hold it down (hard). Then back off the bleeder valve with a wrench. Let all of the pressure come out then tighten the valve back down. After that tell the other person to let off of the brake pedal (do not let off of the brake pedal while you have the valve open or it will suck air into the system). Repeat this process as many times as necessary to get all air removed from the lines.
5) crank the car and cycle the brakes to see if they feel spongey. If they do, you still have air in the system and you need to repeat all steps.
*have plenty of brake fluid on hand- you will need it.
you start from the passenger rear and work closer to the m/c
Old March 2nd, 2011, 04:46 PM   #19
Tang Stang's Avatar
Tang Stang is just really niceTang Stang is just really niceTang Stang is just really niceTang Stang is just really nice
Rod @ AzzKicker Cars
2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's.
1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC.
1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch
Old March 2nd, 2011, 04:58 PM   #20
Willy Mo's Avatar
Willy Mo is just really niceWilly Mo is just really niceWilly Mo is just really niceWilly Mo is just really niceWilly Mo is just really nice
you always start with the furthesrt away from the master cylinder when bleeding brakes. Its fairly easy with 2 people. One to push the pedal and another to oper the bleerder screw.
Threads Similar to: got my new BBK valve covers in
BBK Valve Covers gsjohnson 99-04 24 October 14th, 2007 11:18 AM
valve covers orangestang 96-98 1 October 9th, 2007 09:49 PM
Valve Covers mikebert 5.0 Mustangs 9 January 21st, 2007 06:48 PM
Valve covers will not fit... LOL turbong 5.0 Mustangs 3 December 29th, 2006 10:16 PM
