Trouble code p1450 - Forums at Modded Mustangs
post #1 of 8 Old March 12th, 2009, 01:25 PM Thread Starter
Trouble code p1450
Code p1450 keeps getting thrown on my car. It is described as...unable to bleed up fuel tank vacuum. Has anyone thrown this code before or does anyone know how to fix it? I didnt think the fuel tank had a vacuum. Thanks
Bullitt #835 4:10s, bassani O/R X, bassani mufflers, Bassani mid-headers, forged/built 2v, trickflow 44 heads, BIG blower cam, v1 vortech intercooled 11# boost 532rwhp/468tq
bottlefedbullitt01 is offline
post #2 of 8 Old March 12th, 2009, 01:45 PM
Lefty's Avatar
iTrader: 17 reviews
Check to make sure your gas cap is on tight and making a seal.
Lefty is offline
post #3 of 8 Old March 12th, 2009, 01:46 PM
Lefty's Avatar
iTrader: 17 reviews
Here's this to broham
Possible causes:
EVAP canister purge outlet tube (EVAP canister purge valve to EVAP canister) blockages or kinks.
EVAP canister tube (fuel tank to EVAP canister) blockages or kinks.
Fuel vapor elbow on EVAP canister contaminated.
Restricted EVAP canister.
Canister vent (CV) solenoid stuck closed (partially or fully).
Plugged or contaminated CV solenoid filter.
EVAP canister purge valve stuck open.
Fuel filler cap stuck closed (no vacuum relief).
VREF circuit open in fuel tank pressure (FTP) sensor.
Damaged FTP sensor. (fuel tank pressure)
Check for kinks or bends in the fuel vapor hoses/tubes (EVAP canister purge outlet tube and EVAP canister tube).
Visually inspect EVAP canister inlet port, CV solenoid filter and canister vent hose assembly for contamination or debris.
Check CV solenoid filter for blockage or contamination.
Lefty is offline
post #4 of 8 Old March 12th, 2009, 01:49 PM Thread Starter
damn cuz! thanks Ill do all that shit this afternoon!
post #5 of 8 Old March 12th, 2009, 01:49 PM
Lefty's Avatar
iTrader: 17 reviews
No prob bro
Lefty is offline
post #6 of 8 Old March 12th, 2009, 03:56 PM
Black Bullitt's Avatar
Send a message via AIM to Black Bullitt
I got a similar error on my old Bullitt when I installed my Vortech. Come to find out the one wiring harness is a b!tch to snap back together, so that might be the source of the problem. Mine was unplugged, because it's so tough to snap back together. I guess I didn't get it snapped all the way and it came undone. I hope that's the source of the problem. If it's not another thing to check is the gasket where the filler neck goes into the gas tank. Those typically rip or tear when you drop the gas tank. It's advised to get a new one when you do the install. You will lose pressure in the gas tank through that gasket if it ripped. Let me know if those two things fix it or were the cause.
Did you put a new fuel filter in when you did your install. I'm sure you did, but I just have to ask for the sake of asking.
2001 Bullitt #5069
505rwhp/538rwtq @ 15#s
Originally Posted by FluffyTheRhino View Post
Nothing says "Upgrade EVERYTHING" like busted parts
Black Bullitt is offline
post #7 of 8 Old March 13th, 2009, 02:09 PM
Trick Tuners's Avatar
Possible causes:
My money is on the canister purge solenoid.
Trick Tuners is offline
post #8 of 8 Old March 13th, 2009, 04:25 PM
Lefty's Avatar
iTrader: 17 reviews
I've heard of that issue numerous times.
Lefty is offline
Human Verification
