Discussing Trans question in the 99-04 Forum. I have about 57k miles on my car and would like to change the trans ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
14.61@96.03 2.159 60' (Was my first/best pass. So far.)
Trans question
I have about 57k miles on my car and would like to change the trans fluid. If I pull the plug and drain it, how much would I have to put back in? Also is it better to go with Royal Purple of is there another brand out there thats at Autozone thats as good? My car is going on a mustang dyno this Sat. and I would to have it running and shifting smoothly.
Last thing. I pure it in from the top after takeing the shifter out right? Someone told me you don't have to do that with Fords but that doesn't sound right. Last edited by BlackedOut04GT : March 15th, 2009 at 03:48 PM. |
put back in what it says.. mercon... use 3.5 qts.. if its a manual
well i used 3.5 this weekend when i changed out my clutch.. i have t-45 tranny
#4 | |
99' Mustang GT
3214@OVER 9000!!!
I just changed it yesterday, used Mercon5. I would say don't even worry about changing it. Its a closed system. Unless you have some serious problems, the oil will look pretty new. 126k miles on the clock, and the oil looked just like the new stuff. Waste of time really..... unless you're just looking for a reason to piss with your car.
![]() 99' Rio Red Mustang GT: --My Garage-- Full bolt-ons minus gears. Check garage. Life= eat, lift, eat, eat, eat, sleep, repeat ![]()
#5 | |
99' Mustang GT
3214@OVER 9000!!!
Also, you probably won't notice any bit of a difference in shifting with new fluid. And you need to buy a hand pump at your local auto store, and just pump it into the top drain plug hole, after you put the bottom one it. The haynes manual says to fill it until its level with the top plug.(3 quarts~6pints)
2002 MUSTANG GT
14.2@100
do you have a 3650? manual or auto? the 3650 takes 3.3qts of mercon 5. When i did mine i used 3qts mercon5 (it may say something about auto tranny but ignore it) and the other .3qts i used lucas stop slip additive. smoothed shifts out a lot. 3.3qts will not bring you level with the bottom of the top plug. its 1/2in down i think. take the shifter off its easier then pumping and less messy. its always good to change your fluid. i think its required at 60k but not a 100%. good luck
N/A 4v Guru
2003 Mach 1
I use royal purple syncromesh in my 3650 and it woke great
![]() Military Crew U.S. Army Aviation Apache's Lead The Way |
2002 GT, True Blue, Stick
I might do this too...73k on the clock and its already laid up for the winter so what the hell lol
True blue crew founder/member #1MM's late nite crew #4 The beast lives..KB FTMFW!!!! |
yea it's a 3650 trans manual. I drive it year round and it's just starting to get to that point where I need to clean out all the fluids and change a few things.
I did change out the trans fluid with Royal Purple. Seems to shift a little bit smoother, but I haven't really put it to a test yet. I checked with Autozone and a few other shops just to make sure nothin would go wrong. My internet went down on me right after I started this tread so I couldn't check to see what advice you guy where giveing me.
Side note. I found out one of the 4 bolts that holds my MGW shifter in had come loose. That was a fun surprise. |
I heard you can use like just regular autozone auto tranny fluid with a little of lucas oil stabilizer? Sounds crazy lol
2000 GT JLT Shortram, Mac long tubes, Mac o/r H pipe, UPR k member kit, UPR Billet cc plates, Spec stage 2, steeda clutch quad. 1/8th mile-9.035, 1.980 60ft just flows. New time- 8.92, 2.28 60ft. Mods. |
^ Not sure about that. The Royal Purple I put in works great now that I have been able to run it through all the gears a few times. Could be all in my head but I think it shifts a tad bit faster and easier now too. I guess I'll really find out just how good it is after I hit the track at end of April/start of May.
Threads Similar to: Trans question
| Trans question. | VOLIPINO | Modular Mustangs | 3 | April 18th, 2008 08:43 AM |
| trans question | 5mustang0 | 5.0 Mustangs | 18 | March 4th, 2008 09:07 AM |
| Trans Question | sundro2000 | 5.0 Mustangs | 2 | February 26th, 2008 04:27 PM |
| 86 5.0 trans Question? | 86foxgt | 5.0 Mustangs | 1 | April 11th, 2007 10:07 PM |
| Trans question need help | 00stang | V6 Mustangs | 14 | February 10th, 2007 08:10 PM |
