2003 Mach 1
12.7@107
![]() iTrader: 1 reviews
ABS
So for ahile now when I brake I hear a "clicking" noise and the pedal jumps on me. Short story is I found out it's something to do with the ABS system. Now my ABS light DOES NOT come on. I can removed the fuse for the ABS and everything operates normal as in no jumping pedal, but of course the ABS light then stays on. My question is...is it more like a wheel sensor of the actual ABS module? Anyone had this problem?
2003 Azure Blue Mach 1 5-Speed BBK LTs, o/r X-Pipe,FRPP 4.30 Gears, MGW Shifter, JLT Ram Air, AJE K-member, Eibach Sportline Springs, Moroso Wet Sump Street/Strip Oil Pan, Nitto 555Rs, Steeda Clutch Adjuster, SCT X-Cal 3, NGK TR55ix Plugs |
!FACEPLATED!
that jumping you are feeling is the abs module applying and releasing the brakes. how ever are you stepping on the brakes?
![]() MM Bracket Racing Crew Co-Founder ~Its a Drag Car, Not a Show Car~ LINK-->Custom Race Transmission Build<--LINK
2003 Mach 1
12.7@107
So it is the module? Yea Im actually applying the brakes... it never happens unless im pressing the brakes...
!FACEPLATED!
yes i do know that you are applying the brakes, the pulsing is the anti lock working. What im asking is how hard are you applying the brakes, does it do it at any pressure?
2003 Mach 1
12.7@107
Yes ANY pressure.
!FACEPLATED!
That sounds strange. one of your wheel speed sensors might be going to hell.
13.58 @ 102.31
![]() ![]() iTrader: 5 reviews
kind of a dumb idea but check your brake fluid, also you may have a leak in a brake line, you could be loosing pressure when pressing on the brakes and therefore the abs is engaging. not sure if it could be it but its worth a shot i suppose
!FACEPLATED!
nah, the abs wont do that with lose of fluid. it will only do that if it senses a tire locking up
13.58 @ 102.31
hmmmm....who needs abs anyway?! lol
!FACEPLATED!
I almost disable mine when i did my 31 spline conversion. but then i decided to swap the abs rings.
2003 Mach 1
12.7@107
Only thing is everytime I've seen a sensor going bad/ or is bad the ABS would come on.... Thats why I was thinking it might be the actual module...
!FACEPLATED!
What i would suggest is to bring in somewhere to get it checked. either that or pull the fuse and remove the bulb from the cluster.
2003 Mach 1
12.7@107
Someone told me AutoZone has a way of reading ABS codes that dont show up with an OBD2 reader.. anyone know id thats true? When you pull the fuse you loose your traction control too.. its kinda nice to have for a daily driver
!FACEPLATED!
hell my TC hasnt been engaged since I bought the car
13.58 @ 102.31
i know autozone does it for free, im not sure if they can scan for ABS codes though, im sure it wouldnt hurt to give them a call or stop by. Sometimes there can be "hidden codes" that are there but dont trigger the CEL
!FACEPLATED!
either that or unplug the module and remove the light
!FACEPLATED!
no CEL its an ABS light
2003 Mach 1
12.7@107
I mean Ive got an OBD2 Reader and it's not showing anything. I will give them a call tomorrow though and try to find out.
2003 Mach 1
12.7@107
SMS says F it and rip the S.O.B. out haha
13.58 @ 102.31
yeah i know but i was just refering to me seeing it happen with cels, i dont know if it is similar to a abs light or whatnot
Threads Similar to: ABS
| ABS and NON-ABS Axles... HELPSSS | John's_stang | 99-04 | 6 | October 8th, 2008 12:43 AM |
| Abs!! Help | izze01 | 5.0 Mustangs | 6 | August 25th, 2008 07:07 AM |
| Abs unit | Killax15 | 99-04 | 5 | June 27th, 2008 01:25 PM |
| abs light? | stang300a | V6 Mustangs | 3 | March 13th, 2008 03:02 AM |
| ABS | mxnate116 | 5.0 Mustangs | 6 | June 2nd, 2007 02:03 AM |
