C/C Stock Specs
Old March 17th, 2009, 07:46 PM   #1
PowerShiftz02GT is just really nicePowerShiftz02GT is just really nicePowerShiftz02GT is just really nicePowerShiftz02GT is just really nice
iTrader: 13 reviews
C/C Stock Specs
hey what are the C/C Stock specs for a New edge gt?
Old March 17th, 2009, 08:57 PM   #2
The Doctor
Lefty's Avatar
'01 Cobra Vert.
iTrader: 11 reviews
Uh could you rephrase the question? Are you asking whats the adjustability limits or what?
Old March 17th, 2009, 09:01 PM   #3
iTrader: 13 reviews
like once i put my lowering springs on, my geometry will be off. So the whole reason to get C/C Plates is to re align the struts right? So whats the Stock Alignment numbers? the degrees and stuff i guess. You know what i mean?
The stock alignment setting i guess is another way of saying it?
Old March 17th, 2009, 09:01 PM   #4
The Doctor
Lefty's Avatar
'01 Cobra Vert.
iTrader: 11 reviews
I'm not really sure. Let me ask you this...how low are you dropping your car?
Old March 17th, 2009, 09:06 PM   #5
iTrader: 13 reviews
H&R SS springs
So 1.7ish in the front
Old March 17th, 2009, 09:06 PM   #6
schwarzGT's Avatar
2003 GT
schwarzGT is on a distinguished road
Camber .6 degrees negative
Caster 3.6 degrees positive
Toe-in .25 degrees
StangSuspension.com Series II 2 inch lowering springs, MM Caster Camber Plates, MM Strut Tower Brace, Steeda Bumpsteer Kit, Steeda Clutch Pedal Improvement Kit, Fidanza Aluminum Flywheel, Centerforce Dual Friction Clutch
Old March 17th, 2009, 09:10 PM   #7
iTrader: 13 reviews
yeah thats what i was looking for. Ok so what'd you get those number from?
anyone know how much belle tire would charge to do an alignment. There closed right now but how much roughly do you guys think?
Old March 17th, 2009, 09:12 PM   #8
The Doctor
Lefty's Avatar
'01 Cobra Vert.
iTrader: 11 reviews
H&R SS springs
With that much of a drop you'll need aftermarket C/C plates. I prefer MM C/C plates.
Old March 17th, 2009, 09:13 PM   #9
The Doctor
Lefty's Avatar
'01 Cobra Vert.
iTrader: 11 reviews
Around here, for a 4 wheel alignment, shops will charge anywhere from $65-$100. Just depends on the shop.
Old March 17th, 2009, 09:14 PM   #10
wishIhada5.0's Avatar
2002 GT, True Blue, Stick
wishIhada5.0 is a jewel in the roughwishIhada5.0 is a jewel in the roughwishIhada5.0 is a jewel in the rough
Send a message via AIM to wishIhada5.0
I just ordered my MM CC plates from ebay some guy out in washington had them for $189.99 shipped
True blue crew founder/member #1
378/442 rwhp/rwtq*on a Mustang dyno * looking for block busting power...cms stage 3 blower cams on the horizon..[/
Old March 17th, 2009, 09:15 PM   #11
schwarzGT's Avatar
2003 GT
These are the specs that ford prefers, they allow for a bit more/less for tolerance. I got these numbers from the instructions that came with my MM plates. I aligned my car to these specs the best I could then ran it to an alignment shop, they said I was dead on for camber and caster and they only had to make a minor adjustment to the toe.
Old March 17th, 2009, 09:18 PM   #12
iTrader: 13 reviews
^^^^^^ok yeah i remember you saying that a couple days ago. Ok i didnt think the Specs came with the C/C Plates. I thought you had to find that info on your own. good to know.
thanks man.
Rep+++
but hey what tool do you use to align it? Im assuming you didnt have the computer alignment machine
Old March 17th, 2009, 09:19 PM   #13
The Doctor
Lefty's Avatar
'01 Cobra Vert.
iTrader: 11 reviews
thanks man.
Rep+++
With the lowering springs you're going w/ I can almost guarantee you aren't going to be able to align your car properly/correctly with the stock plates.
Old March 17th, 2009, 09:20 PM   #14
iTrader: 13 reviews
oh sorry, yeah im buying aftermarket C/C Plates.
Should of mentioned that.
Old March 17th, 2009, 09:21 PM   #15
The Doctor
Lefty's Avatar
'01 Cobra Vert.
iTrader: 11 reviews
Ok good
Which ones?
Old March 17th, 2009, 09:21 PM   #16
iTrader: 13 reviews
Ok good
Which ones?
MM i think.
Old March 17th, 2009, 09:26 PM   #17
The Doctor
Lefty's Avatar
'01 Cobra Vert.
iTrader: 11 reviews
MM i think.
Def. go with those. I have MM's and I wouldn't have gone w/ any other.
Old March 17th, 2009, 09:28 PM   #18
schwarzGT's Avatar
2003 GT
Word, well the number one thing to remember is the order of alignment...Caster, Camber, Toe. If you adjust it in that order you will have a much easier time aligning with alot less frustration. I used an angle finder to set my caster and camber. I work part time at an auto shop so I had access to this old alignment tool for adjusting toe. It had a fixed 90 degree edge on one side that would go across one wheel then it had a movable side with an angle finder on the other. You can try and measure from outside to outside with a tape measure to get it close, but I would definitely take it to a shop to have them fix it for you
Old March 17th, 2009, 09:29 PM   #19
iTrader: 13 reviews
Lefty did you align them yourself or did you take them somewhere?
Old March 17th, 2009, 09:30 PM   #20
The Doctor
Lefty's Avatar
'01 Cobra Vert.
iTrader: 11 reviews
I use a $25,000+ machine at school to align my car
Hawk Eye FTMFW!!
Threads Similar to: C/C Stock Specs
stock specs 91cobra5.0 94-95 3 June 27th, 2008 08:35 AM
stock specs? 91cobra5.0 96-98 30 June 25th, 2008 10:42 AM
stock specs 5.0 RIDIN5.0 5.0 Mustangs 13 May 22nd, 2008 11:11 AM
Stock Specs 89 LX 5.0? teal89 5.0 Mustangs 9 February 21st, 2008 02:58 AM
Stock speaker specs cobralini Audio/Video 6 August 25th, 2006 11:48 PM
