serious issues
Old March 19th, 2009, 07:53 PM   #1
mpboy's Avatar
2002 GT
99.99@999.9
mpboy has a spectacular aura aboutmpboy has a spectacular aura aboutmpboy has a spectacular aura about
serious issues
my passenger side front tire is trashed. my buddy works at an alignment shop and hooked me up with a free alignment. I have been chasing this problem for a while. The right fronts camber is way off (talking like 2-2.5 degrs) and the caster has it pushed back towards the back and he says that's as good as he can get it and that something is bent or not right down there. When the suspension travels it has a bad pop. In my quest to chase it down, i discovered that the shock mount bracket that has the two studs that go through the camber adjustment plate was bent. I know it sounds like a lower control arm, but i have checked it and its straight. the only other thing i can think of is the spindle, but it did not look torn up. the car has a 1.5inch drop and its an 02 gt. no other suspension mods other then the drop. sorry for the long post, but im at my wits end
Originally Posted by Dennis View Post
i fail to see the humor here. the farve thing ok its funny. but that shit there is just fucked up.
Wow Chris. You are the square root of stupid.
Eh, I personally think 4" is too big.
Old March 19th, 2009, 10:31 PM   #2
ajm
Been wrecked before?
Old March 19th, 2009, 10:37 PM   #3
The Doctor
Lefty's Avatar
'01 Cobra Vert.
iTrader: 11 reviews
Have you tried getting aftermarket C/C plates for the alignment aspect?
And +1 on ajm's question?
Old March 19th, 2009, 10:40 PM   #4
limited's Avatar
99 limited edition vert
limited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of light
K-member?
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1M
Tuned by Joe at http://www.tricktuners.com
Old March 19th, 2009, 10:43 PM   #5
Billy Weston
C MY 4D's Avatar
2003 Cobra
11.14@124.36
iTrader: 7 reviews
Well either the k-member has moved, the lower control arm is bent, the spindle is bent or the strut is bent.
TT Build in progress.......
Old March 19th, 2009, 11:08 PM   #6
BLK01SS's Avatar
1/8 7.95@82.43
BLK01SS has a spectacular aura aboutBLK01SS has a spectacular aura about
Check your ball joints......?
Topless Mustang Club Founder
2000 Mustang Gt 5.4 SOLD
2001 Camaro SS
Originally Posted by rk_2000_Z/28 View Post
Black C6Z06=pure, hot, nasty, unprotected sex
Old March 19th, 2009, 11:27 PM   #7
mpboy's Avatar
2002 GT
99.99@999.9
more specifics. never been wrecked/cube kissed. the shocks are new and the old ones were not bent. i took the lower control arm off and compared it to a new one and it didn't seem bent, i know they can be damaged and not show it. the k member has never been removed. when i pulled the engine i did it from the top, the closest i got to the k member was the motor mounts. i have not checked the spindles, but that would be the only thing i havent checked, my ? is what the hell could break down there to cause the shock mount bracket to bend? that thing is thick ass metal, also the shock tower were the camber plate sits was pushed up slightly
Old March 19th, 2009, 11:29 PM   #8
mpboy's Avatar
2002 GT
99.99@999.9
there isnt much that could cause the camber to be that bad and the caster to be that pushed back. if you were to look at it you would swear it had been wrecked. i dont know man im to the point where im just going to start replacing it all, but there isnt much to cause the wheel to pull in that bad
Old March 19th, 2009, 11:30 PM   #9
ajm
Do you have some string and another person handy and/or a measuring tape?
If so get your wheels straight and measure the gap between your tire and rear of the fender and gap between the tire and front of the bumper on each side using a the tape measure and compare.
If you have another person handy using the string or long tape measure measure from the rear of the front tire to the front of the rear tire on each side and compare.
May sound stupid but its a starting point to see whats going on w/o guessing and saying "oh its this part, its this part" etc etc.
Old March 19th, 2009, 11:32 PM   #10
mpboy's Avatar
2002 GT
99.99@999.9
you can sit in front of the car and see the camber is wayyyyyyyy off, and if you can see it that's bad, and the back of the tire is pushed 1 to 1 1/2 inches further than the driver wheel.. so its cambered really negative and pushed towards the trunk
Old March 19th, 2009, 11:34 PM   #11
ajm
hmm..and youre positive its never been wrecked, ran off the road and slammed a curb good, etc; original owner?
Old March 19th, 2009, 11:38 PM   #12
mpboy's Avatar
2002 GT
99.99@999.9
im sure. as much as i hate to admit it, it ran fine before i rebuilt the motor. when my motor blew i didn't know much about cars and didn't have the money to get it fixed so i did it all my self. so im sure it was something i did. now that i know what im doing (a least i act like i do) im trying to retrace my steps to see if i broke/unbolted/under tightened something
Old March 19th, 2009, 11:40 PM   #13
ajm
maybe you accidently unbolted some bolts on the kmember? just an idea. Apart from the collision side of things I really dont have too many suggestions for figuring out whats up other than taking the wheel off and doing a little measuring but once again pointless if its never been smashed. Id imagine if the k member were to move back on you on the left side, it would move foward on the right side making the gap between the bumper and front of the front tire off as well.
Old March 19th, 2009, 11:43 PM   #14
mpboy's Avatar
2002 GT
99.99@999.9
i think im going to just pull that whole side off and trace it from the k member down. I was wondering the k member thing my self, im sure i didn't touch it, but you never know, and if the k member was dropped would it effect the other side?
Old March 19th, 2009, 11:47 PM   #15
ajm
Yea, usually what you have on one side youre gonna have on the other side. For example if your k member is pushed back on the left side its usually gonna be pushed foward on the right. Unless it was slid back evenly which doesnt seem to be the case in your situation since the gap between the rear of the tire and fender is smaller on one side than the other right? If you get a chance take a look under the car and see if you can see some "bolt rings" around where the kmember bolts up to see if its moved any.
Old March 19th, 2009, 11:48 PM   #16
mpboy's Avatar
2002 GT
99.99@999.9
yea all the other tires lined up fine on the alignment, its just that tire, somthing is bent, i just have to find it
Old March 19th, 2009, 11:51 PM   #17
ajm
Yea definitely sounds like it. Id jack it up, take off both tires and get to it with a tape measure measuring and comparing both sides.
Old March 19th, 2009, 11:58 PM   #18
ajm
wasnt thinkin right lol
Old March 25th, 2009, 01:49 PM   #19
mpboy's Avatar
2002 GT
99.99@999.9
sorry to bring up an old post. The problem was the control arm bushings. One of the bushings was pushed in and torn and that cause the control arm to sit to far up and back. There is still a popping noise on some bumps that i can feel through the floor, im starting to think it could be a motor/tranny mount, because im pretty sure the front end is good
Old March 25th, 2009, 02:05 PM   #20
njstang's Avatar
13.58 @ 102.31
njstang has a spectacular aura aboutnjstang has a spectacular aura about
iTrader: 5 reviews
man you had me stumped with this one lol good to hear you found out what the problem was and got it taken care of, as for the popping noise i would just pull the tire and go over all the nuts and bolts again just making sure they are tight, also check and make sure your frunt strut isnt loose either, it could be moving around when its compressing when u hit a bump.
Originally Posted by Jazzer The Cat View Post
Jazzer says heat your meat so it sticks to the street
NEW JERSEY STANG OWNERS :
http://njnewedge.forums-free.com/
Threads Similar to: serious issues
GF Issues mylilboostedpony The Clubhouse 36 February 25th, 2009 05:55 PM
AC Issues... 02MustangV6e9 V6 Mustangs 4 February 23rd, 2009 08:37 PM
still having issues... mustangsoldier 5.0 Mustangs 32 February 16th, 2009 07:11 PM
t-5 issues cburns 5.0 Mustangs 6 October 24th, 2008 02:44 PM
Issues... mustang1072 V6 Mustangs 20 December 18th, 2007 02:09 PM
