Cobra IRS?
Old March 20th, 2009, 01:33 AM   #1
mustang_gtr_99's Avatar
1999 3V GT/2007 GT D/D
corner carver
mustang_gtr_99 is a jewel in the roughmustang_gtr_99 is a jewel in the roughmustang_gtr_99 is a jewel in the roughmustang_gtr_99 is a jewel in the rough
Cobra IRS?
I found a guy with an 04 cobra who want to swap me his IRS for my solid axel set up. I am thinking it is worth it because I am all about cornering performance but it is a lot of work. What do you all think?
OS2 (SW) USN
REAR SEAT DELETE FABRICATOR
"RSD pics in garage"
99 3V GT/2007 GT DD
Old March 20th, 2009, 01:41 AM   #2
Diabeetus's Avatar
Black 2001 Cobra
Diabeetus will become famous soon enoughDiabeetus will become famous soon enough
Send a message via AIM to Diabeetus Send a message via Yahoo to Diabeetus
You can out handle an IRS car with a good setup from Maximum or Steeda, but the IRS does make for a nice ride. Stock for stock Id consider the IRS and upgrade for you so if its a straight trade I say do it. Be aware that if you take his cobra rear brakes you have to run at least a 16 inch rim. Also you're gonna have to take his shocks as well. Disconnect your ABS sensors underneath the rear seat and just take his and plug them in. Its a straight swap, pretty straight forward. PM me if you need anything else.
Black 2001 SVT Cobra
Solid axle
"Good judgment comes from experience, experience comes from bad jugment"
MM Cobra Club Member #1
Old March 20th, 2009, 01:47 AM   #3
corner carver
I have 18" rims so no problem there. I also was about to get the steeda 5 link...hmmmmm The IRS would come at no cost but I am going to need the best cornering equipment out there for what I am doing.
OS2 (SW) USN
99 3V GT/2007 GT DD
Old March 20th, 2009, 01:47 AM   #4
njstang's Avatar
13.58 @ 102.31
njstang has a spectacular aura aboutnjstang has a spectacular aura about
iTrader: 5 reviews
im not a fan of IRS but im more of a straight line kinda guy rather then getting in the twisties, but cobra IRS in a gt will give you some nasty rep points
Originally Posted by Jazzer The Cat View Post
Jazzer says heat your meat so it sticks to the street
NEW JERSEY STANG OWNERS :
http://njnewedge.forums-free.com/
Old March 20th, 2009, 01:49 AM   #5
corner carver
Its kinda hard to call my car a gt anymore with the engine swap and mods, lol
OS2 (SW) USN
99 3V GT/2007 GT DD
Old March 20th, 2009, 12:45 PM   #6
Resident DJ
Lefty's Avatar
'01 Cobra Vert.
iTrader: 12 reviews
Are you wanting to do twisties or hit the drag strip?
Old March 20th, 2009, 02:09 PM   #7
MM's official Brony
foursixblurrrr03's Avatar
2003 Mustang GT
14.13 @ 98.4
foursixblurrrr03 is a name known to allfoursixblurrrr03 is a name known to allfoursixblurrrr03 is a name known to allfoursixblurrrr03 is a name known to allfoursixblurrrr03 is a name known to allfoursixblurrrr03 is a name known to all
Send a message via AIM to foursixblurrrr03
he already said he wants to hit the twisties. i'd say go for it, it's better than our solid axel and it would be really cool to see done
suspension is a waste of money. Throw a blown big-block in there and run a set of sumi's
Old March 20th, 2009, 02:50 PM   #8
Resident DJ
Lefty's Avatar
'01 Cobra Vert.
iTrader: 12 reviews
If you love the drag strip then stick w/ the solid but if not then yes do it. It's better ride quality and great for road twisties
Old March 20th, 2009, 07:50 PM   #9
corner carver
Yah, I am not a 1/4 guy, I like the circuit racing. So add one more thing to my list, lol. Now I have to look into IRS upgrades.
OS2 (SW) USN
99 3V GT/2007 GT DD
Old March 20th, 2009, 09:41 PM   #10
Diabeetus's Avatar
Black 2001 Cobra
IRS upgrades are expensive! They are also labor intensive. Just about any modification requires takin the whole friggen thing apart. If you want to do competitive road racing then Id go with the 5 link from Steeda. Its also lighter then the IRS. I swapped my IRS for a solid cause Im a drag racer.
Solid axle
Old March 20th, 2009, 11:22 PM   #11
99mustanggtman's Avatar
1999 GT
99mustanggtman will become famous soon enough
iTrader: 7 reviews
Send a message via AIM to 99mustanggtman
I don't know why the IRS gets such a bad rap at the track, throw on a brace and some sticky tires and they cut 1.5/1.6 60fts all day. The reason you rear about people snapping axles on the IRS is because of the shock from wheel hop, run a sticky enough tire and its no problem. There's plenty of low 10 second guys and even high 9 second Terminator guys running with just a brace a sticky tire.
The only real disadvantage I can see with the IRS is the extra weight over the SRA. Roughly 80lbs more.
Single 67mm turbo, ported pi heads, edelbrock vic jr. manifold w/HPP plenum, terminator shortblock, return fuel system... Goal 600+ rwhp.
Old March 21st, 2009, 12:34 AM   #12
corner carver
ouch, I dont think I want that then. I just took abut 80lbs off the fron end
OS2 (SW) USN
99 3V GT/2007 GT DD
Old March 21st, 2009, 11:58 AM   #13
spdfrek is on a distinguished road
It's 80lbs heavier, but less unsuspended weight too. I have one in my project car. I plan on doing a full upgrade of all the bushings. From the reading I've done getting rid of all the rubber in the IRS will get rid of 99% of the wheel hop thats there, and improve handling by a large margin.
If your still not wanting the extra 80lbs (which does help give you a better weight balance) then I'd also recommend looking at the maximum motor sports rear suspension setup over the steeda.
Interesting enough if you call maximum motor sports, they are pretty excited about setting up IRS stuff, and say they can make it work as good or better then a solid axle. If you call grigg's, they will tell you not to bother with the IRS and to keep a solid axle.
I chose the IRS because I wanted to be a bit different, and because the roads around here are not the best, so an IRS will give a better ride. I've been told on rough drag strips the IRS will also hook up better then a solid axle because it can conform to the surface better.
Old March 21st, 2009, 01:43 PM   #14
corner carver
Thanks for the info. I think I will keep my solid rear and go with steeda like I have always planed. New edge mustangs weigh enough as is without adding more.
OS2 (SW) USN
99 3V GT/2007 GT DD
Old March 22nd, 2009, 04:42 AM   #15
Diabeetus's Avatar
Black 2001 Cobra
Good plan.
Solid axle
Old March 22nd, 2009, 07:10 PM   #16
Resident DJ
Lefty's Avatar
'01 Cobra Vert.
iTrader: 12 reviews
+1. The IRS can, and it has been proven, to be built very, very well. It's just not cheap
Old March 23rd, 2009, 11:16 AM   #17
NeverEnuff's Avatar
1989 LX Coupe
7.1@99mph
NeverEnuff has a spectacular aura aboutNeverEnuff has a spectacular aura aboutNeverEnuff has a spectacular aura about
Don't defend the IRS here...you will get into trouble....
Old March 23rd, 2009, 11:22 AM   #18
NeverEnuff's Avatar
1989 LX Coupe
7.1@99mph
Its not much more than a solid. Figure it up. For a solid to hit some good 1.5-1.6 60fts...you need.
-Upper/lower control arms 300-400
-31 spline posi 200-300
-31 axles 250-300
-Springs 200
-Gears -wash
-Stickey tires
-total without wash prices-950-1200
01/03/04 IRS.
-Brace 160
-Gears -wash
-Sticky tires -wash
-total without wash- 160
99 IRS
-Brace -160
-Gears -wash
-31 posi 200-300
-01/03/04 axles 700-800
total without wash 1060-1260
The prices don't favor the SRA unless you have a 99 IRS. Other than that...why would not want ride quality and hook on the street for a price cheaper than building the solid....???
I have a total of 700 bucks in my 03/04 IRS right now. All new bushings, MM tie rods, MM spindle bushings, the works. Stock axles, and posi with 3.55 gears.
WHen I traded my axle for this setup, I traded it with about 800-1000 bucks worth of goodies already in it. Eaton posi, gears, axles, HPM upper and lowers with springs.
Old March 23rd, 2009, 11:23 AM   #19
Resident DJ
Lefty's Avatar
'01 Cobra Vert.
iTrader: 12 reviews
Ok well all I can say is.............
I wuv my IRS
Old March 23rd, 2009, 11:24 AM   #20
NeverEnuff's Avatar
1989 LX Coupe
7.1@99mph
I wuv my IRS
My too. ha!
Threads Similar to: Cobra IRS?
IRS 03 cobra ricerraper33 V6 Mustangs 44 September 15th, 2008 04:27 PM
Cobra IRS B/C A RealCarCostsTooMuch 96-98 9 February 11th, 2008 08:39 PM
