high speed vibration??
Old March 23rd, 2009, 01:18 AM   #1
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
OK guys tell me what you think, Last month I converted my rear end to 31 spline. Consists of 31 spline Moser axles, FRPP 31 spline T-Loc, FRPP 4:10 gears. Last week was when I got to finally drive the car. I have a Vibration that starts at around 65. It feels like a fine vibrations like pinion angle. Pinion angle and driveshaft angle check out good and the u-joints are fine. I had taken the steel dampener off. I put it back on and the Vibration was a little better. By guess is that its the driveshaft. In the Ford Service manual it says to mark the drive shaft and the flange so you can line them back up for balance reasons. I however did not do that. Anyone have any input?
Old March 23rd, 2009, 01:20 AM   #2
ajm
ive heard that if you dont mark and line it back up youll be ok; then again if thats the case why would ford bother to say its necessary? and thats just what ive "heard"/read/seen posted by a few people
I really dont have any ideas for you
Old March 23rd, 2009, 01:21 AM   #3
John's_stang is on a distinguished road
maybe need an alignment? or balance? lol idk
Old March 23rd, 2009, 01:24 AM   #4
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
I ruled out the tires because i swapped them and its still there. ALignment is fine. If someone lived around me with and aluminum drive shaft i woudl try that but... no one does
Old March 23rd, 2009, 01:25 AM   #5
ajm
Since you didnt mark it to realign it to begin with maybe try turning it 90* or whatever to where its aligned in a different position just to see if it gets better/worse. Sounds a little goofy but hell its worth a try considering the amount of time involved in doing it.
Old March 23rd, 2009, 01:27 AM   #6
Old March 23rd, 2009, 01:30 AM   #7
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
thats what i was going to try next. the driveshaft and flange both had yellow paint marks on them and i lined them up. I just hope one of my axle flanges doesnt have a little run out to it.
Old March 23rd, 2009, 01:31 AM   #8
ajm
That crossed my mind too but I didnt think much of it considering you bought them new (i think) but you never know stuff happens. I guess that would be the next thing to check after the driveshaft. Id image if you got the yellow mark lined up though you should be good.
Old March 23rd, 2009, 01:37 AM   #9
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
that what i thought, and another thing that leads me to the ds is because i bolted the dampner back on it got better.
Old March 23rd, 2009, 01:38 AM   #10
ajm
thats pretty weird, it makes sense the dampner cut down the vibration though
Old March 23rd, 2009, 01:58 AM   #11
mrsinister2424's Avatar
99' Mustang GT
3214@OVER 9000!!!
mrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to behold
Send a message via AIM to mrsinister2424 Send a message via MSN to mrsinister2424
Actually I've heard tons of people getting bad vibration problems after doing gears. The remedy was a new driveshaft. I've heard this on threads and from people I've met time and time again.
99' Rio Red Mustang GT: --My Garage--
Check garage.
Vortech V-1 intercooled running 9lbs of boost
Life= eat, lift, eat, eat, eat, sleep, repeat
Old March 23rd, 2009, 02:04 AM   #12
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
thats what im hoping is that its the driveshaft and that an aluminum one will fix it
Old March 23rd, 2009, 02:06 AM   #13
99' Mustang GT
3214@OVER 9000!!!
Sounds like that's the problem. I'd probably go with that.
Check garage.
Old March 23rd, 2009, 02:42 AM   #14
not yet captured
SilverFreakGT is on a distinguished road
my car had a vibration like that at high speeds, (more like 90 plus) and it turned out one of the bolts on the transmission mount had striped the threads inside the bellhousing so it was just loose inside. Put a nut on the other side with a longer bolt to solve that little problem. =)
Silver on charcoal
MMR Coilover kit, FRPP 4:10's, SCT box tune, FRPP King Cobra Clutch, Steeda quick release quadrant on FRPP cable, MGW shifter, K/N cold air intake, Flowmaster exhaust [SIGPIC]
Old March 23rd, 2009, 02:46 AM   #15
2003 gt
5.4 32v on the way
DickH is just really niceDickH is just really niceDickH is just really niceDickH is just really niceDickH is just really nice
Well the alu drive shaft is an awesome idea, but just to cover something else, what are the odds that one of the axles is just slightly warped or something, causing the vibration?
Before asking a gearing related question click THIS link and enjoy all your saved time.
Click here for your tuning needs
My slow paced budget 5.4 dohc build
Old March 23rd, 2009, 02:54 AM   #16
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
since they are brand new i hope the odds are very unlikely, but you never know. Im not saying the drive shaft would cover it up, im saying that it might be the problem
Old March 23rd, 2009, 02:56 AM   #17
mustang_gtr_99's Avatar
1999 3V GT/2007 GT D/D
corner carver
mustang_gtr_99 is a jewel in the roughmustang_gtr_99 is a jewel in the roughmustang_gtr_99 is a jewel in the roughmustang_gtr_99 is a jewel in the rough
my wifes 04 6er did it at about 65 when one of her tires was off allance????
OS2 (SW) USN
REAR SEAT DELETE FABRICATOR
"RSD pics in garage"
99 3V GT/2007 GT DD
Old March 23rd, 2009, 02:57 AM   #18
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
swapped out all the tires, i was hoping maybe i threw a weight off one of the new wheels in the back but that wasnt it
Old March 23rd, 2009, 02:59 AM   #19
corner carver
they balanced it with the new tires on? It was wiered to because it started at 65 and smoothed out at about 70. Just enough to be anoying
OS2 (SW) USN
99 3V GT/2007 GT DD
Old March 23rd, 2009, 03:01 AM   #20
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
i mean i swapped them out to my old ones and its still there. so its not the tires or wheel issue
Threads Similar to: high speed vibration??
i finially get to get high speed 00redgt The Clubhouse 21 March 3rd, 2009 12:02 AM
vibration from tranny at high speeds? VinceSVT 99-04 15 October 25th, 2008 04:50 PM
high speed internet ? 00redgt The Clubhouse 17 August 14th, 2008 10:04 PM
slight vibration at high speed? 91cobra5.0 5.0 Mustangs 3 June 22nd, 2008 09:38 PM
vibration at high speed help help !!!! jagstang96 96-98 6 February 7th, 2007 09:41 PM
