02 sensor cause a miss?
Sooo it ran good for a while. Now it popped some new codes. The check engine light is illumintated and actually started flashing. It runs fine part of the time then it cuts back and acts like it is missing. Could a fault O2 sensor cause this?
P0161----Oxygen O2 Sensor Circuit Low Voltage (Bank 2, Sensor 2) P0202----Cylinder 2 Injector Circuit Malfunction p0204----Cylinder 4 Injector Circuit Malfunction p0208----Cylinder 8 Injector Circuit Malfunction They just replaced the PCM last month.
2003 vert gt 2v teskid build 12.7 @ 107 (SOLD) ![]() 1989 mustang lx 92gt short block w/gt40p, explorer intake, 65mm tb, 373 gears, 76mm C&L maf, tubular K-member 14.15 @ 94 (5000' above sea lvl) |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 4 reviews
I could be wrong but seeing that its the rear o2 sensor throwing a code I doubt it. The front would be a different story though.
2000 GT
Pcm's don't go bad. very often (1 in 10 million). Have you tuned it up? You have misfires on both banks. I would start with replacing the plugs, then move a cop and see if the misfire follows. Just do one at a time, i would swap cop 2.
If the misfire follows the cop. Replace them.
2000 Black convertible GT: KB 15psi, and other goodies... ![]() 1971 Datsun 240 z: Header and rebuilt motor. (The DD) |
1997 Mustang GT
Faster than an s4
the O2 will not cause a miss fire. A miss fire only happens from bad timing. The O2 sensors don't have any part of the timing. They only control the air\fuel ratio. They might richen you up a bunch, but not cause a missfire.
Aztec Gold 97GT. MM CC Plates, Panhard Bar, SFC's & Tower Brace Eibach Sway Bars H&R Race Springs/Bilstein Shocks MAC CAI, LT's, Catted H and Pro-Dumps KB Boost-a-Spark 04' PI Motor Author of The Official Suspension Guide |
Authorized Vendor
![]() Join Date: Sep 2008
If the injectors are plugged or not firing, that could also cause a misfire. Also, as misfires usually don't use up the oxygen, they can create a lean reading. So it could very well be your misses are causing the O2 sensor readings and not the other way around.
2000 GT
Thats true. I would still check cop's before injectors though. Injectors can be swapped also. And follow the code. Easiest way of troubleshooting cheaply without just buying a set of cops and injectors
Just make sure you do one or the other first, not both at same time.
Its a intermittent problem. The car will run fine then it will run like @$$. I'll swap some cp around and check the plugs while they are out...
Check the coils with a dvom. It doesnt take but a few minutes.
is that a direct voltage ohm meter?
2000 GT
digital
I'm going to change the O2 sensor. The O2 sensor code came first. There were 2 of them. Then after i cleared the codes and drove home the next day it threw the other codes.
#12 | ||
KB'd GT
The timing would have to be WAY WAY off to get a misfire. Most misfires are due to lean or rich mixtures. You could add or subtract nearly 20* timing and not get a misfire at idle and low part throttle (BAD idea at wot!!!) |
#13 | |
Well I found the wiring to both rear o2 sensors pulled out of the sensors. Solder the wires together as a temp fix and it runs great again...So thats a fix until i get my LT and Hpipe installed.
Threads Similar to: 02 sensor cause a miss?
| did i miss something? | gooberhead320 | The Clubhouse | 23 | April 25th, 2008 09:59 PM |
| why does MM miss me? | Bandit | V6 Mustangs | 16 | April 14th, 2008 12:18 AM |
| so what did i miss... | Onemanzu | V6 Mustangs | 15 | December 28th, 2006 12:14 AM |
| So Did I Miss Anything? | Cricket | The Clubhouse | 7 | October 10th, 2006 11:35 AM |
