2004 mustang gt
![]() iTrader: 1 reviews
cooling system?
i'm going to change antifreeze just wondering how u guys flushed system because repair manual says to drain radiator and then remove plugs from block to drain it,drivers side easy to get to but passenger side plug is behind engine mount looks impossible to get to,how do i get all the antifreeze out
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 4 reviews
Drain radiator, refill with water and run for a bit. Repeat until you have fresh water coming out. Another way to do it is open the radiator drain and fire it up, continue to fill your reservoir with water as it runs/drains until you get clean water.
2004 mustang gt
once i get it running clear do i add straight antifreeze until i get the 50/50 mix they call for since there may be straight water in block
straight. Once the water is clear/clean just stop filling it,turn the car off and then let the radiator drain, thread the plug back in. Then use a hydrometer to get the mixture right again, shouldnt cost you but a few bucks at the parts store.
Another way you could do it which is really a waste of antifreeze/$ though is drain the radiator, refill with 50/50 or whatever mix you like to use, let it run for a bit, drain again, and repeat until its as clean as you want it to be.
2004 mustang gt
ok,thanx i'll get one of those tomorrow
no problem.
#8 | |
Resident DJ
'01 Cobra Vert.
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
drain the radiator by the drain plug, pull off a lower hose, and there is a plug on the block itself to drain the block.
Threads Similar to: cooling system?
| Problem With Cooling System | Baby96 | All Other Vehicles | 7 | January 11th, 2008 10:44 AM |
| Bleeding the Cooling System | MUSTANG | V6 Mustangs | 3 | January 3rd, 2008 11:55 AM |
| moping up the cooling system | usmcsawgunner | 5.0 Mustangs | 4 | July 2nd, 2007 01:28 PM |
| 07 cooling system upgarde | dumps | 2005 - 2010 | 2 | May 29th, 2007 10:03 PM |
| 96 GT Cooling System Upgrade ?'s | Areteracing | 96-98 | 5 | January 15th, 2007 10:50 PM |
