![]() iTrader: 3 reviews
Nitrous feed line.
alright n2o elite I am feeding my n2o line through the drain plug in my trunk on the passenger side. My issue is that no matter how I try to route the line its really close to my exhaust pipe ,possibly less than a 1/16 of an inch, where the pipe comes over the axles. So my question to you fine gentlemen is how safe is it to have the line at its current location? approximately how hot does the exhaust pipes get? because the Teflon line itself can hold up to about 600 degrees but I'm wondering how the nitrous inside the line will react. thanks!
dont rout it next to your exhaust.....bad joojjooo
![]() 2000 kenne bell GT (440HP-432TQ) Tuned by Joe at http://www.tricktuners.com dyno vid:http://youtu.be/lr3xpxw2_v8 2011 escape MUSTANG TAT CREW |
well I don't have much of a choice, I branched it over to follow the fuel line. Where it comes out of the drain plug my exhaust pipe is right there.
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
it will be fine, of course just keep it as far away as possible. if i get a chance to get my car in the garage in the next day or 2, i will get ya some pics of my routing.
^thanks man
mm's nitrous mod
2000 mustang gt
no problem.
2003 Mustang GT
12.28 @ 116
![]() ![]() iTrader: 13 reviews
im going to have my line running through my car. Ill have it go against that kick panel thing against the passenger side
![]() 2003 Sonic Blue GT---SLP Longtubes, SLP X, Magnaflow Magnapack CB, 75mm TB/Plenum, MP2 Performance stage 2 heads, MHS Stage 3R cams, Built rear w/4.30's |
Threads Similar to: Nitrous feed line.
| turbo feed line ran from oil press. unit??? | bretts95gt | General Tech | 9 | January 20th, 2009 03:36 PM |
| Brake line used for Nitrous Line | 04mustang232 | V6 Mustangs | 12 | July 21st, 2008 07:26 AM |
| Nitrous purge line | 07 STROKER | General Tech | 19 | May 5th, 2008 02:04 PM |
| feed line, return line? | 91cobra5.0 | 5.0 Mustangs | 2 | March 10th, 2008 12:45 AM |
| Nitrous fuel line hook up? | mattmoto441 | 99-04 | 1 | July 26th, 2006 01:32 PM |
