1999 Mustang Gt
stalling problem i need help
Ok so i have been trying to figure out was it wrong with my 99 gt. when i come to a stop at a light or even in my driveway the car wants and does stall. some times it hesitates when accelerating. I have replaced the IAC, the egr is working good, new plugs, new fuel filter, i put long tube headers on it and mil eliminators on the 2nd set of o2 sensors. problem existed on a smaller scale before the headers. by the way it is a 5 speed. plz help me any ideas would be great. also forgot to add that when i come to a stop if it doesnt die with still idles erratically from a range of almost dying to revving up to almost 1500 rpm
Last edited by greengoblin; April 2nd, 2009 at 10:14 PM. Reason: add some information |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 4 reviews
Have you tried checking the coils with a dvom? Seems like youve covered all/most of the basics besides that. Also do you have a tune for your long tubes? Some people have had issues after putting on long tubes w/o a tune.
Resident DJ
'01 Cobra Vert.
MAF?
But maf would cause it to run shitty all the time...But it's a thought.
2003 GT
I have seen this problem before and it turned out to be a bad manifold air pressure sensor or MAP sensor for short. It wasnt on a mustang though but if all else fails try that one.
StangSuspension.com Series II 2 inch lowering springs, MM Caster Camber Plates, MM Strut Tower Brace, Steeda Bumpsteer Kit, Steeda Clutch Pedal Improvement Kit, Fidanza Aluminum Flywheel, Centerforce Dual Friction Clutch |
Resident DJ
'01 Cobra Vert.
^Yeah Map sensor could screw with it.
(and it stands for Manifold Absolute Pressure )
#6 | |
2003 GT
I had a simular problem I broke down and took it to the dealer after weeks of not figuring it out. The dealer told me there was a technical service bulletin on the same problem. they said something was wrong with the ecu and had to be reflashed. they did it and it helped. but i later found out my problem was from my cdc shaker adding turbulence through the maf and makin it think there was a bunch of air goin through when threre reall wasnt.
Resident DJ
'01 Cobra Vert.
![]() It's all good bro
yeah but i would check the TSB's and see if that one applies to your car. it might be the problem. unless you have a cdc shaker setup, then i could tell you exactly how to fix it lol.
Bearer of Bad News
I has mustang and legacy.
Slower than my Ruger.
My '03 GT did this completely stock. My Mach has done it since I got the K&N. Pisses me off. I'm just used to it and can keep it from stalling. *kicks car*
I hate my car today, just FYI. FUCK IT. Up it's ass.
~MOD NUTSWINGER~ My Tongue Soothes Razorburn ![]() STOPSAYINGFAIL.COM EVERY FART IS A GAMBLE Just Think Of Me As A White Blood Cell.
#11 | |
2004 Cobra
7.4@97 Eaton
![]() NEW NUMBERS: 609/543 |
my shaker setup didnt have the "baffel" in the airbox where the shaker tube comes in. so it forced the air through the drop in k&n i have and made turbulence past the maf. i had talked to many tuners before finding this out. I made a small baffel and all is good.
Bearer of Bad News
You ready to take some stuff out and replace the timing kit?
: D
2004 Cobra
7.4@97 Eaton
Flat rate of 50 and hour...
Resident DJ
'01 Cobra Vert.
![]() *walks out of thread slowly*
1999 Mustang Gt
thanks for all the input guys. i did forget to mention that i had already tested the maf sensor. where is the map sensor and does a mustang even have one i have heard they dont. also Rihno do you know of someone that has had this problem and had to replace the timing chain, i ask this becuase the car has 102000 miles on it and prolly need a new chain anyways.
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
when my car does it, its always a vacum line. its always been either the iac or left side pcv hose was off or almost off.
1999 Mustang Gt
thanks i will try that. also there is a tube running from the drivers side vavle cover into the air intake. does anyone know what this is and since it seems to be old and loose on my car could that be the cause of my problem
mm's nitrous mod
2000 mustang gt
that is what i am talking about. that is the drivers side pcv, and if leaking, it will cause the issue you talking about.
1999 Mustang Gt
ic so should there be a valve in there or is it simply a tube
Threads Similar to: stalling problem i need help
| Stalling problem | joecool108 | 2.3 Mustangs | 2 | November 23rd, 2008 04:55 PM |
| stalling problem | harrylee | 5.0 Mustangs | 11 | June 3rd, 2008 06:38 PM |
| '01 Stalling problem | LanceD | V6 Mustangs | 11 | March 5th, 2007 01:15 AM |
| Stalling problem need help | Booger | 5.0 Mustangs | 2 | January 7th, 2007 09:07 PM |
| Stalling problem need help | Booger | 5.0 Mustangs | 3 | January 7th, 2007 01:53 AM |
