Steering Shaft Noise
Anybody have any noise coming from their steering shaft? If I have the steering wheel straight and barely turn it left or right I hear a clanking noise. It's not bad and it hasn't affected my steering at all, but I'm slightly worried that it could turn into a bigger problem.
did you check the power steering fluid? might have some air in the line and may need to bleed the hydroboost unit.. im having the same problem right now
It's not a fluid problem. Here is what I found out from another member on another site.
"It is the bushings that hold the rack an pinion to the K-member. You will be fine. Hit them with an impact gun." |
Threads Similar to: Steering Shaft Noise
| Steering shaft too short | stano76 | Modular Mustangs | 10 | September 18th, 2007 10:15 PM |
| steering noise | Blackbeauty v601 | V6 Mustangs | 10 | August 10th, 2007 07:24 PM |
| Steering Noise | xx9gt6xx | 96-98 | 10 | June 18th, 2007 11:37 AM |
| power steering noise.... | ibanez570x | 99-04 | 5 | January 25th, 2007 11:33 AM |
| Noise When Steering | MikeD | General Tech | 13 | October 13th, 2006 08:04 AM |
