![]() iTrader: 1 reviews
Limited slip diff?
Does a 2000 mustang gt come with a limited slip differential? if not, what would be the best kind to get?
11.21@123 -150 shot
I believe the GT would have a trac lok which is a clutch type limited slip differential. That should hold up fine for most bolt-on applications.
yes they come with a posi/limited slip/traction lock. All the same stuff that uses clutches and a diaphragm spring. Just different names.
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
+1 also it is a 28 spline diff. i am about to go to a 31 set up in mine
11.21@123 -150 shot
The cast 28 spline axles are definitely the weak link in the rear. I went with 31 spline Mosers and 31 spline trac lok from an Explorer. That only lasted one season. Will be installing a Detroit truetrac later this month.
#6 | |
Official MM Zeppelineers. Crew member #3
#7 | ||
Threads Similar to: Limited slip diff?
| Is mustang 2005 GT stock limited slip diff or not? | Evilspark | 2005 - 2010 | 1 | September 10th, 2007 02:34 PM |
| Rumors (Limited Slip) | mustangman03 | V6 Mustangs | 15 | September 2nd, 2007 05:48 PM |
| limited slip? | cpork | V6 Mustangs | 7 | May 9th, 2007 02:36 PM |
| limited slip differential | burlingtonNC98GT | 96-98 | 6 | April 17th, 2007 12:54 PM |
| Limited Slip | JRubin2000 | 99-04 | 6 | September 21st, 2006 04:59 PM |
