Transmission problem??? need help diagnosing the problem...
Old April 11th, 2009, 12:17 PM   #1
Tmac3320's Avatar
Faster than white99stang
Tmac3320 is on a distinguished road
Send a message via AIM to Tmac3320 Send a message via MSN to Tmac3320
When i am in any gear, at a low rpm, if i go from 0% throttle to 25% in a quick blip (tap throttle) it sounds like my whole tranny is rocking back and forth and a loud clicking is occuring. I have a manual t-45. and a polyeurethane tranny mount. I installed the mount to gte rid of the rocking noise. but that didnt take care of it.
My throwout bearing is shot to hell. it is BAD. and my clutch catches about 3/4 of the wayoff the floor. bad, i know. maybe my clutch fork and thorwout bearing are so bad that its rocking from blipping the throttle? idk what to do. all that i know is it shouldnt do that. any thoughts?
thanks
___________
0hp
0tq
Old April 11th, 2009, 12:55 PM   #2
BlckBullitt01's Avatar
TT Bullitt
BlckBullitt01 is on a distinguished road
Hopefully some others can also chime in, but a little bit of "rocking back and forth" is normal. You are driving a ford afterall
Old April 11th, 2009, 01:10 PM   #3
zinc02GT's Avatar
2011 Mustang GT
12.1 @ 116
zinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud of
Do your clutch then see if it's still there.
Mods in garage. New mods, new track times soon.
Old April 11th, 2009, 01:18 PM   #4
mrsinister2424's Avatar
99' Mustang GT
3214@OVER 9000!!!
mrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to behold
Send a message via AIM to mrsinister2424 Send a message via MSN to mrsinister2424
Quick thing to check. Make sure your transmission crossmember is bolted all the way up snug! Right next to your o2 little tray things.
99' Rio Red Mustang GT: --My Garage--
Check garage.
Vortech V-1 intercooled running 9lbs of boost
Life= eat, lift, eat, eat, eat, sleep, repeat
Old April 11th, 2009, 01:18 PM   #5
limited's Avatar
99 limited edition vert
limited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of light
in nuetral or when driving down road? check u-joints. you will feel if it is motor or trans mounts in the shifter
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1M
Tuned by Joe at http://www.tricktuners.com
Old April 11th, 2009, 03:29 PM   #6
Tmac3320's Avatar
^^^yeah thats the thing, its when i'm in gear, and i punch it on and off the throttle really quick, and then it feels like something down there is clicking back and forth (rocking motion) and it is coming from the tranny, but the tranny is not rocking back and forth at all. mount is tight. shifter doesnt move. maybe its inside the transmission?
___________
0hp
0tq
Old April 11th, 2009, 03:30 PM   #7
Tmac3320's Avatar
I want to buy a spec stage 2 clutch and aluminum flywheel anyways. since i'm replacing the fork and TO bearing. maybe that will fix things..... I just wanna know what it is kuz its a pain in the ass driving and feeling like i'm going to die....
___________
0hp
0tq
Old April 11th, 2009, 03:34 PM   #8
limited's Avatar
are you sure it's not the u-joint like I posted earlier?
Old April 11th, 2009, 04:06 PM   #9
Tmac3320's Avatar
i'm like 100% positive, i just installed a brand new aluminum driveshaft, new heavy duty U joints and all..... hmmm
___________
0hp
0tq
Old April 11th, 2009, 04:14 PM   #10
PowerShiftz02GT is just really nicePowerShiftz02GT is just really nicePowerShiftz02GT is just really nicePowerShiftz02GT is just really nice
iTrader: 13 reviews
hey, how do you like the driveshaft? Do you think it was worth it? Think im going to add one very soon....
ohh and you said you are getting an Al Flywheel. a guy at work told me that when ever you buy an Aluminum flywheel it is a good idea to buy a strong bellhouseing unit i think he said because if you ever blow your trans that flywheel will slice through the floor and cut your legs off. Just letting you know.
My trans goes back and forth too. I dont feel it move but it sounds like it. When ever i downshift and im in the wrong gear. Like 4 to 3rd at 30MPH. its probably normal. Like someone said above, we are driving a Ford.
Old April 11th, 2009, 04:19 PM   #11
4.10GT's Avatar
1999 Mustang gt
13.5@102MPH
4.10GT is on a distinguished road
[QUOTE=PowerShiftz02GT;1987868]
ohh and you said you are getting an Al Flywheel. a guy at work told me that when ever you buy an Aluminum flywheel it is a good idea to buy a strong bellhouseing unit i think he said because if you ever blow your trans that flywheel will slice through the floor and cut your legs off. Just letting you know. [QUOTE]
wow that would suck.
2003 True blue Mustang GT
steeda triax , h&r springs , bbk intake , c&l plenum ,frpp tb ,SCT tuned , 4.10's or x-pipe,mac CB , max motorsports sfc, 125 shot ,315 drag radials nt05r's
13.4@104 n/a
RIP:1999 Mustang GT Auto 13.5 @102
Old April 11th, 2009, 04:36 PM   #12
limited's Avatar
it is the clutch disc that normally explode not the flywheel itself
Old April 11th, 2009, 05:06 PM   #13
Tmac3320's Avatar
ummm i'd like to keep my legs.
___________
0hp
0tq
Old April 11th, 2009, 06:08 PM   #14
uspatricm's Avatar
2002 mustang GT
13.99 @ 98.991
uspatricm is on a distinguished road
mine sounds like i have a supercharger when i press in the clutch when im rolling. ill be ordering a new clutch soon not only to eleviate that noise but also to get some better grip.
Old April 11th, 2009, 10:46 PM   #15
Tmac3320's Avatar
lol, ya know i might as well just buy a t-56. wheres the best place to look for em?
___________
0hp
0tq
Old April 12th, 2009, 02:12 AM   #16
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
there is not a mass produced sfi approved bell for the t45 as of yet, well i havent found one.
its always a good idea to get a sfi approved flywheel, wether going to an aluminum or not. i cant recall ever seeing an actuall sfo approved flywheel. more often times i hear of a flywheel coming apart before a clutch disc.
you sure its in the trans??? if you checked everything there, i would pull the shaft off the flange and check the rear end. turn the flange back and forth to see if there is play. i had an issue like this in my truck and the problem was in the rear end.
Old April 12th, 2009, 10:10 PM   #17
Tmac3320's Avatar
hmmm, i think within the next week i'll tear it apart and check the front of the tranny (clutch fork, play, TO bearing) since i need to fix that anyways. but by the rear end you mean where the lsd and gears and axles are? or the rear end of the transmission where the output shaft is.... i think thats where you mean.....(where the DS goes into the transmission. and if it is that then how do i fix the play..?
___________
0hp
0tq
Old April 13th, 2009, 01:26 AM   #18
Tmac3320's Avatar
^^^ i'm prolly gonna go to ford this week and get the new fork too, just incase it looks like i need a new one. I gotta know exactly what to look for and fix though because i'm doing this on friday hopefully.....
thanks
___________
0hp
0tq
Old April 13th, 2009, 01:33 AM   #19
schwarzGT's Avatar
2003 GT
schwarzGT is on a distinguished road
Check your rear control arms, my passenger side upper arm was loose and would make a noise when I blipped the throttle in gear....come to think of it, I heard it again tonight. Time for some new ones!!
StangSuspension.com Series II 2 inch lowering springs, MM Caster Camber Plates, MM Strut Tower Brace, Steeda Bumpsteer Kit, Steeda Clutch Pedal Improvement Kit, Fidanza Aluminum Flywheel, Centerforce Dual Friction Clutch
Old April 13th, 2009, 01:58 AM   #20
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
i talking like pinion nut coming loose or something.
Threads Similar to: Transmission problem??? need help diagnosing the problem...
Transmission Problem HTK241 94-95 7 March 26th, 2008 07:27 PM
Transmission problem help please jtlogruss08 94-95 6 November 3rd, 2007 01:58 PM
Transmission Problem? ricer_slayer 5.0 Mustangs 12 February 26th, 2007 08:32 PM
Transmission Problem 623MUSTANG 99-04 4 August 10th, 2006 04:29 PM
Transmission Problem 173speed 5.0 Mustangs 6 April 13th, 2006 11:57 PM
