what are some good cheap suspension mods for the twisties? - Page 2
Old April 13th, 2009, 02:16 AM   #21
SilverStang03's Avatar
2003 Mustang Gt
SilverStang03 is on a distinguished road
Send a message via AIM to SilverStang03
Originally Posted by B0B View Post
god theres your first problem.. get some nitto's or bfg KDW's
lol should have seen me at the track. it was like driving on wax. anything past half throttle in first or second had these tires spinning like there was no tomorrow. lol. it reminded me of those big wheels with the big plastic tire in front lol
Old April 13th, 2009, 02:27 AM   #22
2003 Mustang Gt
i would have to do all four tires no?
Old April 13th, 2009, 02:29 AM   #23
mustang_gtr_99's Avatar
1999 3V GT/2007 GT D/D
corner carver
mustang_gtr_99 is a jewel in the roughmustang_gtr_99 is a jewel in the roughmustang_gtr_99 is a jewel in the roughmustang_gtr_99 is a jewel in the rough
you should yes. If you are going to go closed circuit racing and do it right, get another set of rims, dont have to be fancy, and put your choice of tires on them. That way you arnt burning your DD's
OS2 (SW) USN
REAR SEAT DELETE FABRICATOR
"RSD pics in garage"
99 3V GT/2007 GT DD
Old April 13th, 2009, 02:32 AM   #24
2003 Mustang Gt
true. wonder what i can get some stock v6 rims for. must be dirt on ebay
Old April 13th, 2009, 02:38 AM   #25
corner carver
yah, even some GT rims will be cheap as hell
OS2 (SW) USN
99 3V GT/2007 GT DD
Old April 13th, 2009, 02:39 AM   #26
2003 Mustang Gt
for some reason i like those v6 rims, the ones on the 03/04...the chrome ones. i think they look kinda bad ass
Old April 13th, 2009, 02:18 PM   #27
ModMustang97GT's Avatar
1997 Mustang GT
Faster than an s4
ModMustang97GT has a spectacular aura aboutModMustang97GT has a spectacular aura aboutModMustang97GT has a spectacular aura about
The very VERY first thing you should do under any circumstances is get Subframe connectors. Your mustang does not have a 1 piece frame underneath it. It has 2 partial ladder frames that are bolted and welded to your passenger cabin. Its both weak and unpredictable. You should get sub frame connectors (2-300 installed) to fix this. They are basically a set of steel bars that they weld between the front and rear ladder frames of your car. This will make a night and day difference, that will easily make every suspension mod you do from there out, twice as worth it.
Second, I would do sway bars. Sway bars make up from soft shocks and springs and will level the car out, plus add in some greately needed over steer. Your stock car will only over steer at about 20 mph when you floor it in first. otherwise, the car is just going to plow to the outside of the corner.
third would be springs and shocks. These kind of go together, they don't have to, but they go together in the end, so putting them on together will make a big difference.
If you got a little time, read through my posts on the Official Suspension Guide in my sig. look for my posts with Big bold titles and pictures. That should give you a pretty good idea. For the bump steer. I will draw you a picture to make it a little more clear.
Aztec Gold 97GT.
MM CC Plates, Panhard Bar, SFC's & Tower Brace
Eibach Sway Bars
H&R Race Springs/Bilstein Shocks
MAC CAI, LT's, Catted H and Pro-Dumps
KB Boost-a-Spark
04' PI Motor
Author of The Official Suspension Guide
Old April 13th, 2009, 02:58 PM   #28
1997 Mustang GT
Faster than an s4
Here is the drawing. The first is the stock set up. The second is the lowered angles. As you can see the A arms and end-links are already at an angle. if you go over a bump, you will force them even more verticle, this will max out their range, and the car's front tires will toe inwards. Meaning, they will both turn in twords the car, if you happen to be turning at this time, you will lose the ability to turn atleast one of the tires.
The final picture is a lowered car with the bumpsteer kit. The kit as you can see is blue, and corrects the angle, putting the end links, back in parallel with the road, giving you desireable handling again. This doesn't seem to come in to play until you have a 1.5-2" inch drop. And at the 1.5" it, is only noticeable in pretty extreme suspension travel. Something you would be close to bottoming out on anyway. Hope this helps out.
what are some good cheap suspension mods for the twisties?-bump-steer-kit.jpg
Aztec Gold 97GT.
Eibach Sway Bars
KB Boost-a-Spark
04' PI Motor
Old April 13th, 2009, 03:48 PM   #29
schwarzGT's Avatar
2003 GT
schwarzGT is on a distinguished road
+1 nice drawing
StangSuspension.com Series II 2 inch lowering springs, MM Caster Camber Plates, MM Strut Tower Brace, Steeda Bumpsteer Kit, Steeda Clutch Pedal Improvement Kit, Fidanza Aluminum Flywheel, Centerforce Dual Friction Clutch
Old April 13th, 2009, 04:41 PM   #30
corner carver
Originally Posted by mustang_gtr_99 View Post
here is a suspesion guide, should explain a lot
Late Model Mustang Suspension Basics
Just like shown in here as well
OS2 (SW) USN
99 3V GT/2007 GT DD
Threads Similar to: what are some good cheap suspension mods for the twisties?
CHEAP Suspension for my '71 Mach 1 mach1racer Classic Mustangs 2 January 23rd, 2009 09:48 AM
cheap mods 2000roush 99-04 9 March 24th, 2008 02:51 PM
Drag suspension on the cheap ujslost 96-98 0 April 28th, 2007 12:40 AM
Cheap Mods Michael Modular Mustangs 17 November 15th, 2006 03:32 AM
Suspension on the cheap tdurbin General Tech 19 April 11th, 2006 04:36 PM
