4r70w test port for Temp Gauge - Forums at Modded Mustangs
post #1 of 4 Old April 13th, 2009, 09:12 AM Thread Starter
jrfan4life's Avatar
Ok.... I herd and read on the net that i can screw my temp probe for my transmission temp gauge into a test port on the transmission? Does anyone know where I can find this on my tranny?... This is a 4r70w tranny in a 2001 GT.. Thanks guys..
jrfan4life is offline
post #2 of 4 Old April 13th, 2009, 11:30 AM
ajm
Look on the case right above where your 1-2 accumulator piston is. There should be a plug threaded into the case. No guarantee that its gonna work as I have never heard of this before and like you said its something you read on the net so who knows, BUT there is fluid flow to this plug (so youll be able to read temps) as this is where you run the fluid line on the tail shaft lube mod. Weather its going to be the correct size threads for the temp sensor im not sure.
ajm is offline
post #3 of 4 Old April 13th, 2009, 11:40 AM Thread Starter
jrfan4life's Avatar
Found this:
03-21-2009, 08:31 AM
Skinner24
Junior Member Join Date: Aug 2008
Vehicle: 2001 Ford F-150
Trans temp sender location (4R70W)
I have read over several threads on where to put the sender for the trans temp. It seems the overall location has been in the trans cooler line going into the radiator. I have also read to put it in the port on the side of the trans. Just wondering what would give the best readings so that I'm getting good temp numbers. Just curious as I recently bought a newer and bigger boat and tow it with overdrive off. I also just had 4.10 gears installed to help with the pull. It currently turns about 2600 rpm at 60 mph. Just want to make sure I'm not tearing anything up. Thanks for the response. Register today or sign-in to remove these ads!
Ads by GooglePerformaBuilt Trans
Super Sale Now Bad Hot Fords 4R70W,AODE,AOD CALL 570-578-5686
performabuilt.comFord F150 Recall
Ford has issued a recall for your vehicle. Free Recall service at
www. QuirkService. com/ fordFord® Vehicle Parts
Find Parts Made For Your Ford On the Official Ford® Parts Site.
www.Ford.com/PartsAsk a Ford Mechanic Now
17 Ford Mechanics Are Online! Ask a Question, Get an Answer ASAP.
Ford. JustAnswer. com/ F150
#2 03-21-2009, 03:31 PM
20Screw01
Senior Member Join Date: Feb 2008
Vehicle: 2001 Ford F150
What size tires and year truck? Also Just try to stay around 180 degrees and I installed mine in the pan with a bung. It has to be welded to the pan but not a bad project.
2001 5.4 Screw 4x4,4 inch lift,K&n Cold air intake,
Airaid spacer,Lightning grill,A.R.E Tonneau cover,Autometer Tranny temp gauge,Kanamari ram air hood.
#3 03-22-2009, 08:20 AM
Skinner24
Sorry, it's an 01' Screw with the 5.4L. The tire size is 275/55/20. Thanks for the info.
#4 03-22-2009, 09:05 AM
Mark Kovalsky
Senior Member Join Date: Mar 2000
Vehicle: 2002 Ford E350
I like the sender in the test port. It gives temp readings within a few degrees of the pan, sometimes higher, sometimes lower, but always close.
Mark
Former Ford Automatic Transmission Engineer, 1988-2007
#5 03-22-2009, 10:54 AM
Darrin Burch
Senior Member Join Date: Nov 2002
Ideally you would be able to monitor it from a couple locations. Since I deal a lot with performance stuff, I like to see the temp of the fluid coming out of the transmission.
Darrin
#6 03-25-2009, 08:10 PM
str8t six
Senior Member Join Date: Nov 2008
Vehicle: 2001 ford F150
i put mine in the test port. works great!
2001 F150 5.4 ext. cab 4X4, 6" RCD susp. lift, PA body lift, 35" Nitto Mudgrapplers, Superchips Tuner, 3.55 gears
post #4 of 4 Old April 13th, 2009, 12:03 PM
limited's Avatar
problem with the test port is that it is a dead end fluid port. It will be slow to respond to temp changes. ideally you want it where there is flow,like the trans cooler out line. my choices would be the cooler line first,pan second, test port last. they all will work
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1M
Tuned by Joe at http://www.tricktuners.com
limited is offline
Human Verification
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/119173-4r70w-test-port-temp-gauge.html
Looking for ways to keep tranny temp down. - Page 3 - F150online Forums This thread Pingback September 13th, 2011 01:08 AM
