Heater hose popping off???
Old April 14th, 2009, 04:41 PM   #1
1999 Mustang GT
Regulator is on a distinguished road
Send a message via AIM to Regulator Send a message via Yahoo to Regulator
I've been having this issue since I put my engine back in the car (03 Explorer longblock, HiTech cams, longtubes, stock intake). Occasionally when I'm racing, if I powershift the car I blow a heater hose loose. What would be the cause of this? I have done a head cooling mod at the back of the driver side head, could this be part of it? Also, the heater core hose that is farthest to the passenger side, the stock one had a piece of pipe or restrictor there inside the hose, but when I put the car back together I used different hose without the restrictor. Could this be the cause?
'99 GT FS/FT. Click here for details!
"And I heard a voice in the midst of the four beasts, I looked and behold: a pale horse.
And his name, that sat on him, was Death. And Hell followed with him."
Old April 14th, 2009, 07:33 PM   #2
Moderator
casper gt's Avatar
2010 mustang gt auto
casper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud of
get an oem heater hose, if that doesn't help, rethink your coolant mod.
MM BRACKET RACING CREW CO-FOUNDER
BAMA Performance Drag Team Founder
2010 GT auto
Old April 14th, 2009, 10:15 PM   #3
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
the hoses are locking. the plastic piece is what locks it into place. i bet you that is where the issue is.
Old April 15th, 2009, 12:09 AM   #4
1999 Mustang GT
Clarify?
Old April 15th, 2009, 12:11 AM   #5
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
the hose ends are larger and made of plastic. there are inserts in there as well that lock the hoses onto the fittings of heater core and motor.
Old April 15th, 2009, 09:59 AM   #6
1999 Mustang GT
Well then how should I connect the cooling mod hose to the heater hoses?
Old April 15th, 2009, 01:25 PM   #7
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
T
Old April 27th, 2009, 10:55 AM   #8
1999 Mustang GT
That's how I've got it connected. I'll try and take a picture of it today after work and see if maybe I'm doing it wrong.
Also coolant related, my coolant light keeps coming on intermittently. Sometimes it won't come on at all, sometimes after a few minutes of driving, other times it'll be on as soon as I start the car. The resovoir is full of coolant, but the little float inside just sits at the bottom. Is it a bad sensor or could it be something else?
Threads Similar to: Heater hose popping off???
Heater hose popping off??? Regulator General Tech 0 April 14th, 2009 04:12 PM
heater hose location hopper 5.0 Mustangs 3 February 2nd, 2008 11:44 AM
Return heater hose and inlet hose mu5t4ng 96-98 32 January 5th, 2007 12:19 AM
